Three blinks to Panasonic Plasmas denote a fault with 3.3v SOS D Board. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. Type in the brand name to your device to its search box, can be located at the top right of the display window. It will make search easy. More than Nine Lakh viewers cannot be wrong.http://electronicshelponline.blogspot.com/
SOURCE: Panasonic 50 inch Plasma
it could have over heated you can try to reset it first unplug it for about five minutes and try to turn it on if that dont work the remote might have a set button try holding that down until the red light flashes twice, then turn it on if not then hold the power button down on the set for a good five seconds to see if that resets it. if none of that works you will have to go to panasonic .com for the reset instructions.with the red light blinking the power supply is most likely good you just need to reset i.
SOURCE: 50 inch Plasma panasonic TH-50PZ80U.
if you have a warranty let them check it out before opening the panels, it may void it.... may be an internal power short.
SOURCE: panasonic th-50pc77u red light blinks 8 times in cycle
Ur power board it dead,need it replaced.
SOURCE: plasma 50 inches dont turn on
The power supply board is dead.Tries the websites like Shopjimmy.com,Ebay.com to buy the refurbish power supply board for the replacement.
