Question about Garmin StreetPilot C330 GPS Receiver
No signal Hardly used one year old c330. It doesn't work and shows "Acquiring Satellites" with a question mark (?) in the center of screen. It worked perfectly fine until this happened although I use it rarely. I did pressed "re-set" button under front cover, but that has no effect.
    Problem Solver:
Try and replace the antenna
Posted on Aug 16, 2007
I had the same problem: the C330 was working fine for about a month the it suddenly had great difficulty aquiring satellites. The software update was the correct fix. Follow this link to get the 5.70 update: http://www8.garmin.com/support/download_details.jsp?id=831
Posted on Sep 15, 2007
Be sure to update I updated to 5.50 and had the same problem. Garmin has just released 5.70 to fix the sattelite aquisition problem.
Posted on Aug 25, 2007
My C330 acted the same way. I updated the software and pushed the reset twice and it once again came to life. Before it quit, I had updated the software previously, so I think the software may have had a clitch in it.
Posted on Aug 24, 2007
Garmin c330 says trouble tracking satelites, not acquiring signal. what to do?
If your StreetPilot c300 or c500 series device is no longer acquiring satellites please read the article linked below to ensure that this is not being caused by something in your environment:
Why won't my unit acquire satellites?
If after reading the above article your unit is still having problems, please ensure that your unit's software is up to date. You can do this by using our WebUpdater® program.
If you have tried all of the above suggestions and your unit is still not acquiring satellites, you can perform a master reset by doing the following:
Note: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings.
  1. Start with the unit powered OFF and unplugged from power.
  2. Touch and hold the bottom right corner of the touchscreen.
  3. Power the unit ON and continue pressing the screen until a new message displays, "Do You Really Want To Erase All User Data?".
  4. Touch Yes and go through the set up again.
Take the unit outside and let it set with a clear view of the sky for 3-5 minutes to acquire satellites. If the unit still does not acquire satellites after this, please contact Garmin Product Support.
Nov 17, 2010 | Garmin StreetPilot C330 GPS Receiver
Tip
How  OTRdriver's solution worked for me to clear up my StreetPilot C330 when it...
1- Turn off unit.  2- press and hold the bottom right corner of the screen. 3-While still pressing and holding bottom right corner, press and hold power button and continue holding both until a white screen appears with a black dot. 4- follow the on screen directions and your unit will be back to the day you first got it.
on Jan 09, 2008 | Garmin StreetPilot C330 GPS Receiver
I have had a Garmin Nuvi 660 for 2 years now. While travelling in Florida last week with the unit on my dash and working properly I encountered heavy cloud cover. The unit said something like "poor...
if you havent gotten the December 2008 update for your 660, install the update and try again..this is a common problem with the nuvi series. you can get your update here
its near the bottom of the page.
Jul 24, 2009 | GPS
Cannot acquire satellites and freezes
use the web-updater at garmin
or update the firmware at garmin,
turn WAAS on
turn GPS signal off
go outside after the update
turn GPS signal back on ( takes upto 15 mins to locate satelites )
should be good
Regards
Richard.
Apr 21, 2009 | Garmin StreetPilot C330 GPS Receiver
My Garmin c330 has difficulty acquiring satellites in my new 2009 Camry XLE. Does it have something to do with Bluetooth? Does it interfere? Ever since we bought the 2009 Camry XLE in June, the Street...
The C330 does not have bluetooth capability. Regardless, this has nothing to do with the unit's ability to acquire satellites. Nor should the type of vehicle you purchased, unless the unit is unable to receive due to some feature, like something in the windshield, which is preventing the unit from receiving a proper signal. Does the unit work outside the vehicle?
Aug 02, 2008 | Garmin StreetPilot C330 GPS Receiver
New Garmin 330 stuck on kansas
Take the unit outside and turn it on. Then select View Maps, at the top of the screen it will say either "Locating satellites" or "Acquiring Satellites". Once the garmin has locked onto the overhead satellites, then it will say "Ready to Navigate".
Locating Satellites take longer than Acquiring Satellites.
Jun 10, 2008 | Garmin StreetPilot C330 GPS Receiver
Wont acquire any satellites
Have you tried an external antenna? The flip antenna's are known to give problems,
May 12, 2008 | Garmin nuvi 350 GPS Receiver
Trouble acquiring satellites
Garmin nuvi
will not acquire satellites
Apr 30, 2008 | Garmin StreetPilot C330 GPS Receiver
Aquiring satellites
Are you outside with a clear view of the sky? It should find satellites once the unit is turned on. Does it say "Looking for satellites" or "Acquiring satellites"?
If it is "looking for satellites" then it means that the unit have lost all data (time, date, location). If it is "acquiring satellites" then it have date and time, but not location.
Looking for satellites require a longer setup time (could be as much as 15 minutes). Acquiring satellites is much faster (not more than 2 minutes).
Date and time is updated from satellites once the unit gets a satellite lock.
Jan 31, 2008 | Garmin StreetPilot C330 GPS Receiver
No signal
There are three forms of resets on the unit.
The first is the reset under the front face plate. The second is where you hold the power button for a long time (30 seconds).
The last and potentially warranty voiding solution is to pull off the front face plate. Remove the four tiny philips head screws. The front face plate can now be lifted off. There you will see a battery and a little connector with 2 or 3 wires attached to it. Disconnect it. Wait a while... 30 seconds.... 30 minutes... overnight.... and plug it back in.
I've read some reports about the web updater software flaking out, so I recommend flashing through the SD card slot if possible.
Nov 26, 2007 | Garmin StreetPilot c550 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
227 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
