Question about Sony KV-35S42 35" TV
Sony trinitron i have a sony trinitron model kv-35s42 with no picture. i do have sound. before the picture went completely black, if i let the tv warm up for 10-15 minutes the picture would come on. what do i need? is it worth my time to repair? thank you [email protected]
  • kmorin7 Aug 23, 2007
    what is a "trc"
Change the trc
Posted on Aug 11, 2007
6ya staff
SOURCE:
Code programming trinitron sony fd trinitron wega kv 27fs100 27 tv
You need to be a little more explicit about what you need Jackie. Code programming? for what? what device? or name . . or something more . . try again. You'll probably get plenty of help on this one.
Mar 16, 2014 | Sony KV-35S42 35" TV
I have a tv sony trinitron model KV-32FX68E 32''.
try to plug the tv to other socket that is working before suspecting the tv set
Jul 18, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony kv 35s42 sound but black screen and constantly blinking stand by/timer red light
Your vertical IC will need resoldering. If you can take this board out and inspect the pins under the vertical IC, you will see rings around the IC. This is a common problem for you model of TV. Hope this helps...show a few hands of support.
Dec 14, 2010 | Sony KV-35S42 35" TV
My Trinitron KV-35S42 picture folds up.
Hi this fault due to a capacitor in the frame (field) output stage going low value / the one to look for is a 680uf 63v ( might be 50v) it is mounted to the right of the frame out put ic.Hope this will help regards, windyhouse.
Nov 14, 2010 | Sony KV-35S42 35" TV
Sony trinitron
check the heater as your tv is ON, there must be a yellow light at the rear of the CRT tube. If the heater is ok then check the IC jungle side. resoldering the leads sometimes will solve. If not refer to your local Tech.
Jul 31, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony FD Trinitron Wega model KV-34BR800
Sony Wega Triniton KV-32FS100 TV
For the last week my TV has been going to a black screen for 10 seconds or so then the picture returns. It has been continual. Last night it stopped going to black screen, but now the standby light flashes 5 consecutive times and the color went haywire. A lot of red and everything that is suppose to be black is green.
I did a soft and hard reset with no success. What's wrong and is it worth fixing? Bought new in November 2002.
Aug 01, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
TV Sound through stereo speakers while watching tv.
All the above connected method is correct. Need to change the option in the stereo system as md or auillary depends upon the model. Go through user manual for stereo system.
May 27, 2008 | Sony KV-35S42 35" TV
Sony kv-35s42 no picture, good sound timer light flashing
Usually, the CRT is bad......re-juvenation is a temporary fix at best........try adjusting screen control on CRT socket module.
Only other possibility is solder pins of vertical output IC.
Mar 20, 2008 | Sony KV-35S42 35" TV
Screen went BLACK!
My Sony FD Trinitron TV did samething, started flashing, then eventually went completely black with volume. I got on internet searched found a solution, i tried it, it worked. unplug tv, remove all screws, remove back. towards bottom right theres a transmitter with a couple of knobs, we plugged tv in and moved knobs around and it worked. Also was extremally dusty, we used computer duster for a better connection. hope it helps you
Jan 26, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
Sony KV-35S42 35" TV Logo
209 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
