Question about Dryers
Siemens dryer is dead
My siemans dryer ultra sense wtxd5321us is completely dead, no lights nothing. I have confirmed 220VAC at the plug.
BerkelUSA
  • 24 Answers
SOURCE: completely dead
One of 4 things.. bad power to unit (1/2 blown breaker) blown fuse behind the lower front panel ($12), broken motor switch or bad door switch..
Go with the cheap parts first.. door switch and fuse. test your power in with a meter..
mine does this.. 3 beeps and once in a while goes completely dead.. doing the hair-dryer trick fixes it every time but only temporarily...
http://www.youtube.com/watch?v=tq3k22cqjR8
SEE VIDEO !
Posted on May 20, 2008
SOURCE: Whirlpool Cabrio dryer won't start - the "sensing" light is on
where are the answers on those stupid site
Posted on Oct 21, 2009
heatman101
  • 43501 Answers
SOURCE: GE drsr483ed1ww dryer runs but does not
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 12, 2010
blueextc3221
  • 15935 Answers
SOURCE: Whirlpoold Duet dryer "sensing" lights up but will not run?
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
  • 552 Answers
SOURCE: I have a siemens ultra
This means there is an air flow issue most likely. Try running the dryer without the vent connected. If the dryer runs, the vent needs to be cleaned in the wall. If the dryer still does not, the thermistor on the front bulkhead will probably need to be cleaned or replaced.
Posted on Apr 13, 2011
How do I find a siemans tumble dryer manual
A google search, with the model number and the words ''user manual'' will very likely turn one up for you.
Aug 17, 2014 | Siemens WT46W568GB Condenser Tumble Dryer,...
What is the problem with my dryer?
The motor starting circuit is failing. Confirm this by giving the drum a push start when it hums. Most likely, the centrifugal switch on the motor is sticking (due to lint buildup) or broken. It has a mechanical component that operates an electrical switch. Check the mechanical operation, then check the switch. Also, check that the motor electrical connector is seated completely.
Apr 02, 2017 | Whirlpool Dryers
Dryer with no heat
If it's a 220vac dryer make sure you hace 220vac at the wall plug. If that's there check the element for breaks and verify there are no burned off wires or loose connections. If element is good (check with ohm meter) check for thermal overload open on the side of the element.
Jan 04, 2014 | Kenmore Dryers
Siemens ultra sense dryer stopped working, found broken belt, replaced belt but dryer still won't run!
-There are couple things that cause a dryer not working:
-Thermal fuse.
-Heater element.
-Timer switch.
-Door switch.
-start switch.
-Or the motor.
Check these components.
Good Luck
Mai
Dec 05, 2013 | Kenmore Elite HE4 Electric Dryer
Replaced control board on dryer still getting e61 code
The problem is not with the dryer as confirmed by the other identical dryer brought by the dealer. The problem is in the wiring of the receptacle where the dryer is being plugged in as characterized by error code E61 which means the control board is receiving a high voltage. The dryer operates both on 110VAC for the controls including the motor and 220VAC dedicated for the heating circuit. The receptacle must be configured according to the specifications of the dryer. Refer to the diagrams below and configure the receptacle according the plug that came with the dryer. Voltage across L1 and L2 is 220VAC, L1 and Neutral is 110VAC, L2 and Neutral is 110VAC.
Nov 17, 2012 | Frigidaire Electric Dryer
Just bought a dryer, can i put a 120v plug on it? My plugs are 120v.
No. Electric dryers run on 220vac
If you do not have a 220vac plug at the wall, you will neede an electrician to install one for you.
Hope this helps...
Aug 27, 2011 | Maytag Dryers
Brand new Frigidaire Electric Dryer gives Error E61. Store brought out another identical dryer with same result. Help please!
Note: You may need the service of a certified electrician for this task.
Jul 13, 2011 | Frigidaire Electric Dryer
I have a siemens ultra sense dryer and has started to show a code E01 I have checked the hose and cleaned the lint out I always clean the lint filter what next. It automatically shuts off and sends that...
Apr 13, 2011 | Dryers
Dryers Logo
42 people viewed this question
Top Dryers Experts
