Question about Garden
Troybilt tb320 I just bought the rearwheeled propelled push mower because I have a somewhat hilly backyard (<1/3 acre). The mower came with the STA-BIL Ethanol Treatment as well as SAE 30 for small engines. I mowed my lawn now 3 times and all 3 times I noticed that the next time I went to mow and I checked the oil, the engine was nearly out of oil. Is this usual for a brand new push mower, or do I possibly have a lemon? Or am I perhaps not using enough Ethanol Stabilizer? Appreciate some advice. Don
SOURCE: lawn mower motor just stalls for no reason
Check for water in gas tank and filter.
Posted on May 09, 2009
#1 Taper
  • 1040 Answers
SOURCE: Need help with belt on Troybilt self propelled push mower
Try removing the pulley in order to put the belt back on.
Jim
Posted on May 30, 2009
  • 61 Answers
SOURCE: white smoke
White smoke is most likely cause there is to much in the engine.. Only takes about half quart.. Clean with degreaser and garden hose on the outside..
Posted on Jul 04, 2009
SOURCE: I have had my Poulan Lawn Mower for 4 years. The
Four years without adding or changing the oil?!
I think that was the problem right there.
Mowers need oil changes to protect the cylinder walls and valve guides every 25 hours of operation. Thats usually about one season if your yard is under an 1/3 of an acre.
Your mower ran on almost no oil for the last two years. The normal lawn mower only holds 20 ounces of oil. You topped off with 16 ounces! The four ounces still in the motor were probably so full of dirt and metal particles that it was grease! Which is no help to an engine that gets its lubrication by splash oiling.
Your mower should be oiled with 30 weight non detergent oil. Multi Vis oils are for engines with tighter machined tolerances. Your oil choice is going to go right past the piston rings and valve guides creating gobs of smoke! Go get some 30W ND oil at your parts store and put it in....but run the mower first so you can clean out all the gunk in the oil sump. Run it long enough for the oil to flow easily.
Once you put in the right oil you can run it and try to clear out the remaining multi vis oil.
If it keeps smoking...I would say you have permanent damage to the cylinder wall or valve guides.
Good luck and be careful!
Posted on Jul 02, 2010
  • 11800 Answers
SOURCE: My Cub Cadet self propelled lawn mower, with
Transmission problem - either the clutch plate is worn out (you will need to replace it and correctly readjust the lever) or the belt is slipping, either because it's loose (the tension spring is worn out and has softened (replace it) or the pivot points are rusted and no longer move freely - oil it) or it has aged and it will have to be replaced.
You will need to dismantle the transmission for that.
Posted on May 28, 2011
How do you replace a drive cable on a troy bilt push mower model 12av834q711
I am assuming you want to replace the drive cable on this mover.
You can view this in detail in this video
https://www.youtube.com/watch?v=PbwO2ygfS0k
If you need the manual you can download from this site
Manual Troybilt Rotary mower 12AV834Q711
If not then please send a comment clarifying which cable you are referring to.
Parts can be purchased from this site
http://www.searspartsdirect.com/partsdirect/part-model/Troybilt-Parts/Walk-behind-lawn-mower-Parts/Model-12AV834Q711/1307/1500600/P0601106/00002
Aug 12, 2014 | Troy Bilt 5.5hp Self Propelled Mower
Troybilt self propelled mower front wheels lock up when pulling back
most have small leaf springs that let it toggle back and forward, if they brake can cause this problem. Then it may just need the wheels removed, clean the parts and lubed
May 31, 2014 | Troy Bilt 5.5hp Self Propelled Mower
Husband says thinks it is starter cable has stretched and needs new one...does this sound correct and how to install it on Troybilt self-propelled push mower?
I'd love to help you, but I think you need to rephrase your question. There is no "Starter Cable" on this mower. Sorry.
James
May 22, 2011 | Troy Bilt 5.5hp Self Propelled Mower
I need a owners manuel for a troybilt lawn mower
For Troy-Built USA, use this link and submit your model number and serial number to find and download your manual:
http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10001
For Troy-Built Canada, use this link and submit your model and serial number to find and download your manual:
http://www.troybilt.ca/troybilt/troybilt_manual_search.asp
All other countries use this page and find the applicable website or email address then go to the applicable website or email the contact point:
http://www.troybilt.ca/troybilt/contact-world.asp
Thanks for choosing FixYa,
Kelly
Oct 04, 2010 | Troy Bilt 5.5hp Self Propelled Mower
My Troybilt starts, idles, then stops. What is
1st thing to try is clean and rebuild carb(easy job) ...good luck
Apr 07, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Noisy Transmission getting worse.
Does it still move? Make sure you don't have a stick or something stuck in the transmissions pulley/fan. Check idler pulley's too.
What kind of noise?
Sep 03, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Troybilt 6.5 wont start without some help
Check to see of where the canles connect to the linkage, there are usually thumb nuts you can adjust similiar to that of the brakes on a bicycle handle bar.
May 30, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Jim
May 29, 2009 | Troy Garden
How many HP?
* If your yard is up to an acre in size, the ideal cutting width is 30-42" (76-106cm). To avoid being underpowered, or putting too much strain on the engine, make sure your mower or tractor offers a minimum 14 horsepower. Riding mowers are the most commonly purchased for lawns this size. * For a yard that is between one and three acres, you’ll reduce your mowing time with a cutting width of 42-46" (106-116cm) and a strong engine up to 16 HP. Typically people purchase lawn tractors for yards of this size. * If you’re mowing more than three acres, you’ll need to look at the garden tractors, with cutting widths up to 54" (137cm) and at least an 18 HP engine, preferably bigger.
Aug 27, 2008 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
109 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
