Question about Minn Kota Fortrex 80 Bow-Mount Trolling Motor - 24v-80lb.-52 (Minn Kota)
Minn Kota problems
Water in motor. Motor not working
SOURCE: minn kota turbo 35 27lb thrush trolling motor
I have a minn kota turbo 35 27lb thrush trolling motor after 3 hours of running it the motor dies
Posted on Aug 03, 2008
SOURCE: The Minn Kota trolling motor
Mine did the same thing and i think that it could be the relay under the switch cause i had power when i directly touched both neg. and pos. so i would diffently take a look at that.
Posted on Oct 02, 2008
  • 11 Answers
SOURCE: minn kota problem
Same deal with mine, was using it with no problems until I turned up the trust alittle and it just quit, never turned back on nor did the circuit breaker pop. Talked to Minn Kota thy said the board might be fried as well. So took it to a authorized dealer. I had 2 issues (only minor with the motor) Easy fix for mine was under the button on the foot pedal is a small round magnet about half the size of a pencil in diameter or so. The tech said it got recessed down to far and if it should happen again just pull it up again. So took it back home re-installed and no luck, just heard a tiny ticking noise from the foot pedal, no prop movement. SO I checked the batteeries, all good. Even though the connectons had very minor corrosion I decided to disconnect all and clean them. Re-connected them and now I am back in business. Dont understand it, but hey it works until I actually test it out on the lake. Hope it helped
Posted on May 01, 2009
  • 10 Answers
SOURCE: Minn Kota electric motor MKJI1033962
Best to call Minn Kota direct for the manual Youll need your serial number thrust of motor and shaft length..
800-227-6433 they will help you with any technical questions.
Parts can be purchased from this dealer...There are schematics on the site for review....
http://www.northlandmarine.com/MinnKotaQuickRef.htm
=100){IAjax.Pop('/WorkArea/showcontent.aspx?id='+id);}else{__LoadTaxonomy(IAjax.getArguements(),'pagerequest=showcontent&__ecmid='+id+'&control=ctl00_ctl00_ctl00_skin_body_variant_body_nav_body_Directory1&__ecmdiv='+tag);}}function OnDirectoryItemBubble(id,width,event){__LoadTaxonomy(IAjax.getArguements(),'pagerequest=bubble&__ecmid='+id+'&control=ctl00_ctl00_ctl00_skin_body_variant_body_nav_body_Directory1&bubblewidth='+width+'&X='+EBubble.EventX(event)+'&Y='+EBubble.EventY(event));} function DmsMenuInit(){ dmsDynamicContentBox = false; dmsCommunityDocuments = false; }function OnAddCategory(name, selectedTreeId, parentId, action, id, type, share){__LoadTaxonomy(IAjax.getArguements(),'pagerequest=addworkspacecategory&__categoryname='+name+'&control=ctl00_ctl00_ctl00_skin_body_variant_body_nav_body_Directory1&__selectedTreeId='+selectedTreeId+'&__folderId='+parentId+'&__action='+action+'&__taxonomyId='+id+'&type='+type+'&share='+share);}ektj$(document).ready(function(){DmsMenuInit();}); // --> .EkTB_overlayMacFFBGHack {background: url(/WorkArea/images/application/macFFBgHack.png) repeat;}
Posted on May 08, 2009
SOURCE: Trolling motor doens't work
I have a trolling motor and can't seem to get it to come on. I seen it work when I got the boat. But now it won't come on.
Posted on Aug 09, 2009
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    WHO STOCKS A 2991251 CABLE FOR A MINN KOTA
    Sherry, I think there may be a new Minn Kota part # . Check the attached links. Good luck
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
    Minn Kota Power Drive Non Auto Pilot Coil Cord Assembly 2991283
    Minn Kota Trolling Motor Part COIL CORD STRN RLF PD48 54 2991283
    http://minnkota.com.au/wp-content/uploads/2014/07/55-PowerDrive.pdf
    Can get replacement parts for my Minn Kota trolling motor FAQs
    Apr 13, 2016 | Minn Kota Boating
    My minn kota 70lb thrust motor is 2 years old. Brand new batteries and it will turn left & right, but the prop will not work.????
    Minn kota 74 lbs. prop runs when head turns when rotating motor from centre to right, but stops when you turn motor from centre to left. The light on top stays on.
    Aug 30, 2010 | Minn Kota Maxxum 70 Freshwater Bow Mount...
    MINN KOTA MAXXUM TROLLING MOTOR WON'T WORK PROPERLY
    I'm having the same problem - does the motor have brushes and could this be the problem? mjj2103
    Jun 27, 2010 | Minn Kota Maxxum 70 Freshwater Bow Mount...
    Motor works then stops. If I pull the motor up
    I have the exact problem with my Minn Kota 70 - did you find an answer? Thanks, MJJ
    Jun 23, 2010 | Minn Kota Maxxum 70 Freshwater Bow Mount...
    Lookinf for a manual for a minn kota model 55d
    call 800 number for minn kota on your motor. they are very helpful and will fax or emial you a manual for the motor. good luck.
    May 28, 2010 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    Built in transducer is not picking up/transferring depth to graph
    I havew a Minn Kota trolling motor on a Z21 Ranger. Minn Kota has a built in (puck type) transducer on the motor. I have a lowrance 135x on the front. The lowrance will read the temp but will blink the depth. I switched out the depth finder with another 135x with the same results. I have a 522c gps unit networked together and mounted on the console that works fine. Any suggestions on the problem with the 135x?
    Jul 27, 2009 | Minn Kota Maxxum 70 Universal Motor/Sonar...
    Overheated Minn Kota Endura28
    This sounds like a fairly big deal. You need to check it water got into the motor. Turn it upside down and see if water comes out of the handle end of the motor. This may be a shop deal.
    May 31, 2009 | Minn Kota Endura 30 Freshwater Transom...
    May 06, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    Minn Kota Fortrex 80 Bow-Mount Trolling Motor - 24v-80lb.-52 (Minn Kota) Logo
    22 people viewed this question
    Top Minn Kota Boating Experts
    Colin Stickland
    Colin Stickland
    Andrew Taylor
    Andrew Taylor
    Phil Walker
    Phil Walker
    Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
