Question about Ingersoll Rand - Rand Type - 30 Reciprocating Air Compressor - 5 Hp, 230 Volt 1 Phase, Model - 2340L5
I HAVE A INGERSOLL RAND TYPE 30 MODEL 242-5D SINGLE PHASE 220 & I NEED A WIRING DIAGRAM & OIL INFORAMTION. I KNOW THIS COMPRESSOR WAS MADE IN THE EARLY 70'S & DONT THINK THAT SYNTHENIC OIL WAS EVER PUT IN THIS COMPRESSOR. I WOULD LIKE TO RUN SYNTHETIC BUT NEED TO KNOW IF I CAN JUST CHANGE IT OVER OR DO I NEED TO FLUSH THE COMPRESSOR FIRST. THANKS, WILL
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 33 Answers
It will need flushing the oil we use in reciprcating compressors is 2100
Posted on Oct 16, 2014
  • 52 Answers
SOURCE: Compressor wired wrong from the factory and will not run.
I cannot find any diagram from this description. do you have a model # of motor?
Posted on Mar 10, 2009
compman66
  • 169 Answers
SOURCE: i have a ingersoll rand type-30,model#2475 7.5
from what you are describing it sounds like you are missing a couple wires somewhere or you do not know what you are looking for. The pressure switch, low oil switch motor starter coil, and overload relay should be wired in series to provide a control circuit for the motor starter. I would highly advise seeking the help of a certified electrician if you are not experienced in working with these machines. You can not only risk personal injury, but also damage a lot of expensive electrical item's real quick if it is not done correctly.
Posted on Dec 06, 2009
  • 17 Answers
SOURCE: need compressor parts for type 30 Ingersoll-Rand Compressor
contact ingersoll rand they are helpful http://company.ingersollrand.com/Pages/default.aspx
Posted on Dec 31, 2009
compman66
  • 169 Answers
SOURCE: what type of oil for ingersoll rand model 2475 air
Ingersoll Rand likes you to buy their all season select oil for their air compressors, most piston air compressors use an R+O 100 oil it is equivalent to n SAE 30 wt oil.
Posted on May 12, 2010
  • 99 Answers
SOURCE: trying to rewire my ingersoll
Please check out the Web Site Below. It is a Quick Start manual for IR Compressors.
It should have everything you need. It DOES NOT Show you any wiring connections AT the motor.
Hope this helps....Jim
http://www.irtechpubs.com/ir_pdfs/Compressed%20Air/Air%20Compressors/Reciprocating%20Compressor/80445703.PDF
Posted on Feb 19, 2011
SINGLE PHASE WIRING DIGRAM
You need a single phase motor to do that. A 3 phase motor cannot be made to run on one phase.
May 16, 2013 | Ingersoll Rand - Rand Type - 30...
Need plug hook up diagram for 220 for Ingersoll Rand 2475N7.5 Type 30 2-Stage Air Compressor
Hi dcrouch537
Found these pictures on another webpage..
This should make your wiring much easier
"A picture is worth a thousand words" Please take time to rate mehunter19_46m_1.jpghunter19_46m_2.jpg
Sep 07, 2011 | Ingersoll Rand Type - 30 Reciprocating Air...
I NEED THE WIRING DIAGRAM TO HOOK-UP AN INGERSOLL-RAND TYPE 30, MODEL V 234 N4, SER. # 30T 37128 I UNDERSTAND THAT IT CAN BE WIRED FOR 110 VOLT OR 220 VOLT POWER.
The wiring diagram is on the outside of the
motor case, on most motors,on the label
Also on the inside of the wiring connection
cover
May 25, 2011 | Ingersoll Rand Type 30 Reciprocating Air...
Trying to rewire my ingersoll rand air compressor motor, psi switch motor starter, need some kind of diagram, it has a 5hp single phase 220
Feb 18, 2011 | Ingersoll Rand - Rand Type - 30...
I want to take to my home but I only have single phase 220, what can I do.
You can build or buy a single to three phase converter....
http://www.metalwebnews.com/howto/ph-conv/ph-conv.html
If you want to buy then just do a search and many will come up...
You size them by amp. draw... the amp. draw will be listed on the motor nameplate...
heatman101
Feb 04, 2011 | Ingersoll Rand - Rand Type - 30...
I have a new ingersol rand 80 gal 7.5hp air compressor 230volt single phase and was wondering what size breaker it needs to be put on
Your owners manual spec sheet should give you that answer. However since that unit at max loads should pull 32 to 35 amps I recommend 1.5 times max amps. So approximately a 50 amp breaker. This all based on standard wire size and length of wire run. Also when checking your voltage at load you should be showing 235 to 240 volts.
Jan 09, 2011 | Ingersoll Rand - Rand Type - 30...
IR 2475E Wont start up 220 everywhere No LOP switch
did you check for a motor reset button on the motor??
Feb 20, 2010 | Ingersoll Rand - Rand Type - 30...
I have a ingersoll rand type-30,model#2475 7.5 hp,3 phase.need a wire diagram or how do you wire up the low oil and pressure switch? this is a used compressor with wiring still conected, has 3 leads to the...
Dec 04, 2009 | Ingersoll Rand - Rand Type - 30...
Mar 08, 2009 | Ingersoll Rand Type 30 Electric Driven Two...
Ingersoll Rand - Rand Type - 30 Reciprocating Air Compressor - 5 Hp, 230 Volt 1 Phase, Model - 2340L5 Logo
392 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
