Question about Acer X243W 24" TFT wide format screen 24 inch LCD Monitor
Acer x243w hdmi dvi
Input not supported
SOURCE: connecting dvi cable straight to acer monitor
The cable box is probably outputting a resolution the monitor is not compatible with. Computer monitor and television resolutions are usually different, and not cross compatible in some cases.
For example, wide screen monitors are usually 16:10 aspect ratio, while TV is usually 16:9 aspect.
The AL2216wbd is a 1680x1050 display, while HD TV is either 720p (1280x720) or 1080i (1920x1080).
If your cable box is set to 1080i that would be too high for the monitor. You will need to set it to output at 720p, and even then you will probably get a vertically stretched picture since the monitor has a taller aspect.
Posted on Jul 28, 2008
mediarich
  • 188 Answers
SOURCE: Acer X243w monitor as a TV Pic great but "not supported" box
My assumtion is that the monitor is not displaying in 1920x1080 but has defaulted to a resolution that it can handle so as to display something. Step down the resolutions on the monitor until the gray box disappears. If you're satisfied with the picture your watching then hopefully you will be happy when you find the resolution the monitor is actually displaying.
Posted on Sep 20, 2008
  • 201 Answers
SOURCE: Acer T230 H monitor Hdmi ConnectionProblem
I don't think your doing nothing wrong, but I may be wrong. I would just stick with the other connections. HOpe this helps!?
Please rate solution - Thanks.
Posted on May 14, 2010
damnor01
  • 1179 Answers
SOURCE: I have my PS3 hooked to the HDMI port, but the
There are a varity of HDMI cables, ensure that your version is supported also using the input touch "button" to change the input through VGA, DVI and HDMI.
damnor01
Posted on Nov 22, 2010
  • 3 Answers
SOURCE: Acer AL2216W 22" LCD monitor. DVI input apparently
Not Good..
After you've checked that the video cable is connected properly, make sure that all the pins in the video cable plugs are straight and not broken off. Then test on another PC. Make sure your CMOS battery has not gone flat, as some PC's will fail to load basic drivers if CMOS memory is lost. The battery should show no less than 2.5v, if it's marked 3 volts when tested on a multimeter. If you can't test it, just buy a new one at the supermarket or hardware, usually around $4.00.
Next thing to try is your Video Card . If it is an on board one like most are now, there isn't anything you can do but try another card in an expansion slot or fit a new motherboard. At this point, I'm sad to say, you're better taking it to a PC shop where they will have a few things at their disposal to try.
Posted on Jan 30, 2011
How do I connect my PS3 to my sanyo dp50747 in hdmi? I have everything hooked up correctly, but its not coming up on the TV. What do I do?????
If you see a no signal message, then it means that the signal output format of the PS3 does not match . It happens if you have previous used it on another tv and now connected it to a different tv. To resolve this, turn off the PS3 . Press and hold the power button on the PS3 till you hear three BEEPS. The PS3 should automatically detect the tv's resolution and the initial setup screen should appear. After that you should just follow on-screen instructions to set it up.
Sep 26, 2011 | Sanyo DP50747 50 in. Plasma TV
How do I set my Dell laptop to Samsung TV using HDMI
If you have a HDMI output on your laptop, then you should be able to plug a HDMI cable into a HDMI input on your T.V then change your input source on the t.v. If you don't have a HDMI output on your laptop then you should be able to use a DVI cable as long as your t.v has a DVI input, they also make a DVI to HDMI adapters, but keep in mind that DVI cables/adapters do not support audio.
Jun 25, 2011 | Samsung Televison & Video
I just purchased an ACER P236H-BD monitor described as full HD 1080 but does not have an HDMI input. Does a DVI input give full HD 1080?
Yes dvi can output 1080p video. There is no signal conversation when using hdmi and dvi. Vga however has lower picture quality because signal conversation do exist.
Mar 20, 2011 | Computers & Internet
I have my PS3 hooked to the HDMI port, but the monitor won't switch inputs to the HDMI port. If I have something plugged into the dvi port it works fine, but I currently need only the HDMI port, and do...
damnor01
Nov 22, 2010 | Acer H233H bmid Monitor
Acer al2216w problem
wronge connection check it
May 01, 2010 | Acer AL2216W LCD Monitor
I have a Samsung Series 6-650 LCD TV (Model # LN46A650A1F). I am trying to connect my Laptop to use the TV as a monitor and have done everything to make it work, using a VGA/HDMI cable, but the TV refuses...
Why do you use VGA-HDMI cable? This TV works fine with VGA cable - it has VGA plug.
Or if your notebook has DVI output, then you can use DVI/HDMI cable and connect it to the TV to plug named DVI/HDMI (only one HDMI input is marked as DVI on TV).
I suppose that over HDMI the TV supports only some standard resolutions, but over VGA it supports almost every resolution laptops use. You can find supported resolutions for each input in the TV manual. Try setting the same resolution on the laptop.
Feb 28, 2010 | Samsung LN46A650 46 in. LCD HDTV
Sep 19, 2008 | Acer Computers & Internet
Dvi input for watching tv
the DVI input must be HDCP compatible in order for HDMI to work. It's a DRM encryption protocol. Condolences. Blame hollywood for it. The monitor model is too old to have had HDCP support built in to the DVI input.
Jul 30, 2008 | Dell W3000 30 in. HD-Ready LCD Television
Acer X243W 24" TFT wide format screen   24 inch LCD Monitor Logo
46 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
