Question about Refrigerators
Liebherr ice maker
Leaking ice maker
catriver
  • 878 Answers
SOURCE: ice maker leaking
Twodogs, I can't bring anything up with this model number but let me give you a couple scenerios of what could be wrong. The mold itself could be rotting out and leaking on fill, The fill valve in back of the refer might not be seating correctly and therefore you have an overfill. The fill tube might not be set in the trough causing it to spill over. Some models have a fill adjustment screw on the module of the ice-maker, I can't tell if yours does because of the incomplete model number. Catriver, post back.
Posted on Aug 09, 2006
  • 531 Answers
SOURCE: Blue substance in Liebherr ice maker cubes
flush the water on till it get clean
Posted on Mar 31, 2009
SOURCE: blue ice from ice maker
I have this problem too. Seems to be a couple of blue paper washers in the unit that the water filters through and they break up. Ive had this issue go on for more than a year now with Liebherr trying over and over not to claim responsibility. Ive sent them the blue washers and photos and all to get analyzed and they simply do not call me back. Their service center didnt even know there were 2 blue washers in the unit. Seems to be a mess. In any case I still have a very large amount of blue paper dust in my ice and its unuseable. Any solutions?
Posted on Dec 16, 2009
  • 50 Answers
SOURCE: I have a new Liebherr refrigerator. It says to
not familiar with brand but you will pop a cover off the icemakerfront and either push dial to start or jumper it some how. some models cant be jump started but i assume if you must bleed it then it has to have a way to start the icemaker.
Posted on Aug 01, 2010
ZJLimited
  • 17970 Answers
SOURCE: Liebherr bio fresh fridge/freezer model
This ice maker can be cycled manually to help determine the problem. To cycle this ice maker, pull the front cover off of the ice maker. You will now have access to the module which has some test terminals marked on it (I'm sending you a picture). Using a well insulated jumper, place it between T-H and the ice maker should start to cycle.
Be careful this is a hot (live) check. If the ice maker starts, after about 5 seconds remove the jumper. It will take a few minutes for it to break the ice free and if it cycles completely and refills the ice maker will need to be replaced. This indicates it's not starting on its own. If it just stops on the ice, the mold heater may be open. You should be able to feel the bottom of the ice maker to see if it's getting warm but be careful, if you touch the mold heater, it can be very hot. If the mold heater is not hot, again the ice maker will need to be replaced. If the ice maker never cycles with the jumper, there may not be any voltage getting to the ice maker. Some voltage checks will need to be made and a technician will be needed to make these checks.
Hope this helps.
Posted on Nov 15, 2010
A small piece fell out of my Liebherr ice maker and now it doesn't make ice how do I put it back and where do I put it back?
FIXYA has no clue as to what fell out nor where it goes back to . call a local repair service
Nov 13, 2017 | Liebherr Refrigerators
Liebherr ice maker not making ice. Switched on but nothing happening
Hello Irene Booth,
There are several things you can do to check the suitability of your freezer settings ... (eg: if you put a small container of water in the freezer...
Is it mostly frozen in about 45 minutes??
Things that would aid in trouble shooting...
Liebherr nomenclature: model number...???
New... or new to you?
Had previously worked... Never worked.
General observations... Frost forming in back of freezer area
Doors square and fitting properly...
Gasket in full contact (visibly) all the way around the freezer door/drawer... and is in good condition
- (can physically check by pulling a dollar around the gasket).
If the Ice Maker has EVER worked ... We can skip the basics of checking the water supply is hooked up and TURNED ON.
If you can fit your fingers in the ice tray to feel for water or ice in
the tray ... that would also be helpful.
Finally... for new models... check that all packing tape & materials around the ice-maker have been remove.
Although your model appears to be a TWIST TRAY type of ice-maker... there is still a sweep or fill bar that is supposed to check the fill level of your ice bin.
A single chip of ice can hold that from moving freely... your ice maker will not work ... !!
Hope this helps
Carnac the Magnificent
Jan 04, 2017 | Liebherr Refrigerators
Where is the water filter for Liebherr CI1650 located?
There isn't a water filter. You should install an inline filter to the water line that comes in to feed the ice maker.
Jun 18, 2014 | Liebherr CI1650 30" Built-in...
I have a Liebherr free standing french door frig (two freezer drawers). The plastic component that shapes the ice cubes has fallen out of the ice maker into the ice receptacle below. I don't know how to...
I don't know about this ice maker, but you could always check the Owner's Manual (either the one that came with fridge, or an online copy) for re-attachment info. That's something basic that the manual may very well cover.
Sep 18, 2013 | Liebherr CS2062 Bottom Freezer French Door...
Ice maker is not making ice
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Oct 15, 2010 | Liebherr European Right Hinge Fully...
The ice maker appears not to be working can not
heatman101
May 31, 2010 | Liebherr KIKNV3056 Bottom Freezer...
I have a liebherr freezer with ice maker. ice maker broken
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Apr 17, 2010 | Freezers
Refrigerators Logo
55 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
