Question about Canon Office Equipment & Supplies
Can the canon Pixma mp280 printer print card stock paper?
I've been trying to print my tickets on cardstock paper, but it's not printing, so i think it's because it's on cardstock paper,so i was wondering if there is anything i could do to make it print? is this printer able to print on cardstock paper?
  • 24 Answers
SOURCE: Printing on heavy cardstock
HP recommends papers with ratings of at least 90 for brightness and 75 g/m2 (20 pound) weight. before u proceed....remove the rear access door to reveal the rollers.Take a slightly wet cotton cloth and wipe the rollers in the upward direction 4 times.Close the rear access door. now do as said - START -PRINTERS & FAXES -CHOOSE THE PRINTER ICON THAT HAS BEEN HIGHLIGHTED WITH A CORRECT MARK. - RIGHT CLICK - PRINTING PREFERANCES - PAPER/QUALITY TAB - CUSTOM -Create a new custom paper size that is dependable on the paper you are using - type a name & SAVE -ok -ok -try printing if the problem still insists the report back and do mention which tool you are using for the printout. if its heavy pearlized paper then i do not think th eprinter would accept it . it maintains its own standard weight to detect the paper.
Posted on Sep 24, 2007
map9966
  • 2351 Answers
SOURCE: Printing Business Cards on Cardstock
Yes, the roller system will only open wide enough for semi thick cardstock. If you read through you're manual you'll find the recommended card stock you can use. HP supports HP paper.
Here is a list of supported HP paper.
http://h10025.www1.hp.com/ewfrf/wc/prodTopCategory?product=16118&lc=en&cc=us&dlc=en&dest_page=product
See the user manual on page 45.
Papers to avoid when printing
It would not hurt to remove the rear door & clean the rollers. (No soap). Dried soap film will cause paper to stick to the rollers. You can go to Wallmart or a local hardware store & buy a bottle of Grease Lighting. This heavy duty cleaner (When dry), does not leave any soap film. Great for cleaning just about anything.
If you wish to download the user manual from HP (It's easer to see & find information faster. Just click on this link:
http://h10032.www1.hp.com/ctg/Manual/c00461378.pdf
Good Luck!
Mike
Posted on Jun 13, 2008
Ajkill
  • 2035 Answers
SOURCE: brother laser printer wont print
If there printer is not able to print on card stock then check the recommend
card stock paper thickness, if the printer works with normal paper but not card stock then there is problem in the card stock and by using this paper may also damage the rollers on the printer and make the printer useless ...
Good luck...
Posted on Feb 09, 2009
  • 451 Answers
SOURCE: I have a Canon Pixma iP2072 printer. When I try to print a document, the paper feeds a few inches in, stops, and then says there's a paper jam. I've checked to see if there are any paper bits stuck, b
try cleaning the rollers or removing any dust from them by using scotch tape on the rollers to lift off the dust.
Posted on Feb 17, 2012
Geekman
  • 32281 Answers
SOURCE: can i use cardstock paper in my canon imageclass d880?
There maybe an adjustment on the rollers for different types of paper grades. If so adjust it for heavier paper weight.
Posted on Mar 02, 2012
I am researching the Canon MX922. Will it print on cardstock and if so what weight? Also, is it compatible with Vista.
If you wantCanon Printer Customer Service Phone Number, then you can contact with us Canon Printer Tech Support Phone Number#1877-778-8@9@6@9.We are always here with tech team for your help. For further information Click: https://goo.gl/ZYjDqq
Aug 15, 2016 | Canon Pixma MX922
Why is my hp 5610v not printing on cardstock?
Are you print through manual bypass? If not try doing it that way. Card stock is very thick and by using manual bypass it doesn't require as many turns for the card stock.
Apr 26, 2014 | HP Office Equipment & Supplies
Will not print evenly on cardstock business cards
This can be caused by the cardstock slipping to one side as it prints. Make sure when you print you are using the card stock settings found under your printer setup - paper type. Check to make sure that the paper you are usng is meant for your printer, most printers are meant for up to a certain pound of paper eg 120lbs. and going over this could mean that the paper is too heavy for your printer which causes the rollers to slip as it pulls the paper through your printer.
May 30, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
When i got to print it does not feed in
could be your feeder, or it does not like the card stock, try feeding regular paper if the regular paper feeds then the stock your using might be to thick for the unit.
Let me know ether way
please do leave ratigns and fededback
May 08, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Brother laser printer wont print on cardstock My brother printer won't feed teh card stock paper. It used to work but now it won't feed it, normal paper works fine. Even if i nudge the card stock paper,...
Good luck...
Feb 09, 2009 | Brother MFC-5840CN All-In-One InkJet...
Paper keeps jamming
To print card stock you must us the manual slot in the front of the printer and feed one at a time. Also open the back flap door so the card stock can exit out the back instead of trying to bend around for the try. That will give you the staight paper path that your thick stock needs.
Jul 08, 2008 | Brother HL 1440 Laser Printer
160 people viewed this question
old marine
old marine
