Question about Garden
How do I fix my John deer s82 loose steering?
  • 86 Answers
SOURCE: John Deere riding mower SRX95 - Steering wheel is sticking
You need to replace your Ball Joints! On the front steering rods There are two sometimes three !
Posted on May 09, 2009
SOURCE: john deere runs then stops
I fixed my mower stalling issues on the L111 by loosening the gas cap. I ultimately drilled a hole in the gas cap and screened the hole. Sounds ridiculous but without that venting the engine would run approximately 20 mins and die. It was also much more difficult to start the next time. Something else to pass along to whomever might view this... I replaced the cranking battery with a battery that had allot more cranking amps and I no longer had hard start issues ( this was after I vented the gas cap). Hope this helps.
Posted on Aug 11, 2009
mowerman1857
  • 389 Answers
SOURCE: cant remove steering wheel from john deere rx 95
At the bottom of the steering wheel you should see a screw that goes crossways through the steering wheel and shaft. It will have a nut on one side and a phillips head on the other. Do not try to unscrew this bolt! Use a punch and tap it out from the nut side being careful not to damage the end of it. It is serated and will not turn with a phillips screwdriver. Once this is removed the steering wheel should just pull off. If it doesn't, post your model/serial number and I will check to see why.
Posted on Sep 23, 2009
SOURCE: Why would my sst18 john deere zero turn steer in
there is a servo under the main body on the right side win sitting in seat thats broken from the_w4ezv@yahoo.com
Posted on Oct 22, 2009
  • 66 Answers
SOURCE: L120 JOHN DEERE
There should be adjustments on the tie rod ends connecting to the front axles. Loosen set bolt, make the adjustment and re-tighten set bold.
Posted on May 30, 2010
I just want a diagram/photo that shows how to install the v-belt properly on a John Deere s82 riding mower.
type question into google and click images. failing that there may be a video on u tube
May 08, 2016 | John Deere Garden
Steering is loose and slips on my John Deere LA140 is it hard to fix
The steering gears are striping out. There are two gears that mesh to steer unit.
May 06, 2014 | Garden
The rod on my John Deere tractor fell off that makes it steer...how do I fix it ?
sounds like the ball joint on the steering link is worn and dropped out some models have replaceable ball joints and some you must replace the entire steering rod in either case check all ball joints for wear and replace as they are worn as well
Oct 25, 2012 | John Deere Garden
Hit stick in year, now my S82 John Deere will not go into drive or reverse
did it pop the belt off?did it push the lever that you release that allows you to push it?
Apr 18, 2012 | Garden
Loose steering on a la165 john deere tractor
Check out this web page might help ya
http://www.mytractorforum.com/showthread.php?t=187272&highlight=LA165&page=1
Apr 01, 2012 | John Deere Garden
Manual for a 1988 s82 john deere lawn tractor
Where the fuse box on a john deere s82
Feb 28, 2012 | Garden
Peg perego john deere steering repair
you need spst8119r, let me know if you need me to order you one
Jan 07, 2012 | Peg Perego John Deere Gator HPX Ride on...
John Deere Gator steering
I need to fix a sticking steering wheel
May 07, 2009 | Peg Perego John Deere Gator HPX
Garden Logo
74 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
