Question about Angelcare Deluxe Movement Sensor & Sound Baby Monitor
LCD Screen on Angel Care Monitor - has gone bad
Both of the Displays on my Parent Monitors have gone Bad... It still works to "monitor" what is going on in the baby's room - but the Display is not lighting up all the way - same thing with both parent units - the system is a little over 2 years old - and I want to use it for baby # 2... Is this fixable or covered under warranty?
caroldon
  • 17130 Answers
SOURCE: THE PARENT UNIT DOESNT SEEM
The units are not locking in to the same frequency and if this is new it must be referrred back . However if this was working earlier then there could be a shift in the communicating frequencies between the master and slave.
So remove battery of allthe units and replace after 15 minutes.,Try a reset if desccribed in the manual or the procedure for intial set up once again .
Posted on Sep 19, 2010
  • 3 Answers
SOURCE: Angel care unit is beeping every 3 seconds
Press MENU once.
Press UP arrow until the swinging tick indicator is no longer showing (just movement and sound)
Press SELECT.
Posted on Sep 24, 2011
  • 6771 Answers
SOURCE: base not charging parent monitor
The rechargeable battery will need to be replaced.
Posted on Mar 20, 2012
SOURCE: I got 1 parent unit and 1 nursery unit of Angel
hi,
please tell me how to pair AC1100 the nursery and parent units
please for help..
best regards to all
Posted on Jul 04, 2012
abraao_anton
SOURCE: How to pair AngelCare AC1100 the nursery and parent unit?
thanks, this reel solve the problem
Posted on Dec 19, 2013
Hp g6 screen fades out
The lcd screen or video card inside the computer is going bad. To isolate the problem connect an external monitor to the laptop. Borrow a monitor from a neighbor, friend, relative or co-worker to connect to the laptop.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If the external monitor displays without a probem that proves your video card is ok and your lcd screen is going bad. If the external monitor displays by fading in and out like your lcd screen, then your video card inside the computer is going bad.
The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 25, 2012 | HP Computers & Internet
VX924 (Silver, Black) 19" LCD Monitor: monitor has suddenly gone white...
My VX924 did the same thing but now displays nothing and power switch light just blinks. According to an answer listed on previous page, it may have bad capacitors. I may have to take a look at them. Viewsonic repair facility examination of this monitor runs $70.
May 17, 2010 | ViewSonic VX924 19" LCD Monitor
I rebooted my PC and now screen is darker and my colors are off
Check the contrast (darkness/lightness) on your Samsung LCD. There's a menu button on the monitor, press that and select contrast setting from the Menu.
Apr 29, 2010 | Samsung SyncMaster 932B LCD Monitor
Blank screen the screen has been working for over a year and all of a sudden went blank its not my pc as i plugged my pc into another screen and worked fine.... the standby flashing stops flashing when i...
Since you have tried another monitor with your computer, then we can only assume that your LCD monitor had gone bad.
If the light is green but you can't see anything on the screen, then most likely the backlight has gone bad. Unless you want to take the monitor apart, I would suggest buying a new monitor.
Apr 19, 2010 | Samsung SyncMaster 203B LCD Monitor
My become like horzantal lines+become not
Disconnect the Monitor from the PC, and keep it still powered on. If it displays horizontal lines, it means monitor has gone bad. If not then go to PC's BIOS, if it shows lines there then your graphics card/chipset has gone bad. Else its your graphics driver/operating system. Can try an update/reinstallation of driver.
Regards,
Shrey
Oct 09, 2009 | Dell UltraSharp 2000FP 20.1" Flat Panel...
Monitor starts then goes off, no signal
I would check the LCD against another monitor. It does not have to be a LCD, a regular monitor will do.
This will tell you 2 things, 1. The Video card is good or bad, 2. The Cable is sendinf a good signal.
If when you startup the monitor, you see a display and then after a few seconds it display's a no signal message, this is consistant with a Bad cable or cable ends. or Bad VGA card from computer.
Hope this helps. Good luck..
P.S. If you have move the PC, you may want to open the unit, and re-seat the Card. If the card is not making a solid connect on the board, it will display these syptoms.
Sep 05, 2009 | HP w1907 LCD Monitor
Monitor displays breifly then goes to blank screen
The power -inverter board probably needs an overhaul.
I redo many of these.
If the screen was pinkish or flickering before it finally got to this point, it is possible that a bulb has gone bad.
Fran
Sep 07, 2008 | Proview PL926WBi 19" LCD Monitor
Monitor displays properly then screen goes blank
it seems tht the monitor has gone bad & needs to be replaced....try running a monitor self test by unplugging the monitor cable frm the back of the cmputer & make sure the monitor is receving power frm the wall outlet....chk if the monitor displays anything......let me knw if it wrks
Jul 11, 2008 | Dell 1703FPs 17" TFT LCD Flat Panel...
Monitor
hi,
Unplug the monitor from the back of your computer tower. If the LCD is not displaying any Video the monitor has gone bad. If it displays self test feature check window. It could be a graphic card driver problem.
Mar 22, 2008 | Dell E176FP 17" LCD Monitor
Angelcare Deluxe Movement Sensor & Sound Baby Monitor Logo
71 people viewed this question
Top Angelcare Baby Gear Experts
Dorel UK
Dorel UK
Shehu Pro
Shehu Pro
Are you an Angelcare Baby Gear Expert? Answer questions, earn points and help others
