I had my battery replaced in my Timex Expedition and it seemed to be working fine. However, when I set my alarm to go off it didn't make any sound. When I pull out the alarm knob (one or two notches out), it used to beep each time. Everything else seems to be working but that!
You will find an arrow head on the outside back of your watch where all the printing is. When you put this lid back on, this arrow needs to be aligned with a notch on the inside edge where the cover goes on. As you are looking at the watch from the back with the cover off this notch is in a northwesterly direction. If you doubt it then just hold the back on without popping it in all the way and hit your mode button to make sure that you hear the beeps again. If you do, then you've found the right spot.
Make sure to put the sticker back on. I threw mine out and had to use a tape. The alrm wouldn't work until I taped it.
