Question about Brother FAX-575 Plain Paper Thermal
Copying I can send a fax but cannot make a copy. Please let me know where I should place the document to be copied and the paper it should make a copy to. I have read the manual but for some reason when I hit copy it doesn't work.
    President:
  • 2,961 Answers
You place the paper in the same place as if you were faxing and the paper it's printer in the rear most carrier, but one press of the button indicates you want one copy, pressing it again should then do one copy.
Posted on Aug 11, 2007
  • andrew pester
    andrew pester Aug 11, 2007
    Sorry you may have to press copy, then the number 1 then press copy again, if 2 copies press copy then number 2 then copy
I keep getting a black line about 2 inches along the right side of the paper if copying as well any faxes sent are also getting that blac line. Brother fax machine intel 4750e
Well you said the Lines are present when you are copying and when you are sending from the fax unit. Copying and sending functions both uses the scanning unit. What you lift open the document feeder for original documents. In there you should see rollers and a glass. clean this glass with cotton swab and alcohol for left to right the entire glass. Close the unit and try copying or sending, documents should now be clean.
Apr 04, 2011 | Office Equipment & Supplies
How to do copies,ie what buttons do i press
Making a Single Copy
Place the original face down in the ADF.
2 Press Copy/Help twice.
To cancel, press Stop.
Do NOT pull on the paper while copying is in progress.
Copy Options: Single or Multiple Copies,
Reduce/Enlarge, Sort/Stack
You can choose additional copy options. First, you can select the number of copies. Next, you can
choose whether multiple copies will be STACKED (all copies of page 1, then all copies of page 2, etc.)
or SORTED (collated). Finally, you can choose an enlargement or reduction ratio. To automatically
reduce the copy to the paper size you have set for the paper tray, select AUTO. To reduce the copy by
a fixed percentage, choose 93%, 87%, 75% or 50%. Or, to enlarge the copy, select 150%, 125% or
120%. To copy a document at its original size, select 100%.
1 Place the original face down in the ADF.
2 Press Copy/Help.
3 Enter the number of copies you want (1-99).
For example: Press 9 for nine copies.
To start copying now, press Copy/Help.
If you would like to select additional copy options, like
SORT, ENLARGE or REDUCE, press Menu/Set.
Oct 02, 2009 | Brother FAX-T74 Plain Paper Thermal...
HP6110 All in one
When the HP Office jet series all-in-one front panel screen displays Memory Full, the HP Office jet all-in-one is not able to send, receive or forward faxes. Copying will also not work. WORKAROUND: Though the memory buffer should clear itself automatically after proceeding with the next task, like receiving a fax or starting a copy job, these suggestions below may help you clearing the memory buffer by:
  • Add paper to the HP Officejet series paper tray
  • Clear a possible print jam and proceed printing the fax.
  • Reduce the copying or faxing resolution via the front panel's menu.
  • Use the HP Manager to send a (group) fax or making a copy. More memory is available this way, as the HP Manager utilizes the PC memory. When sending a group fax, the HP Officejet all-in-one's memory is filled to capacity. To copy in color is only possible from the HP Officejet Manager.
  • Press START to clear the message. If this message persists, unplug the power cord, and after at least 15 seconds plug the power cord in.
CAUSE: The HP Officejet series memory may be full due to: Copying on Photo quality or sending a group dial, which will use an extensive part of the internal memory's capacity. No paper in the paper supply tray, while receiving a fax. This may result that the data remains in the buffer. Print jam while receiving a fax or copying. The data is still stored in the buffer. System error displayed on the HP Officejet display window. SUMMARY: The HP Officejet series will not fax or copy without sufficient memory to store the data of the page in the buffer before printing the receiving fax or the copy.
May 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
How can we tell if our fax machine is working
basically if the fax is well kept, its dialing properties will remain ok. what you need to check is the quality of print out. to test the quality of print out just try to copy a sample document. if your fax is a thermal type, change the paper first before proceeding with copying. if your fax has a menu and help button try pressing the menu first before help for the fax to print a helplist.
Mar 28, 2009 | Office Equipment & Supplies
I can't use Print function for ByPass or Document Feeder?
The document feeder is used for copying and scanning ,it is a unit in a copier where you can placed your documents or originals for copying and scanning. The bypass tray is used for copying and printing, the bypass tray is used for types of paper like plain paper, acetates etc and customized papers. If you want to used the bypass tray for printing you should go to printer properties or configuration and select the tray you want to used like bypass tray .
Feb 22, 2009 | Sharp AR-5316 Advanced Digital Imager...
Copying and fax sending problem
  1. Just check & clean the dust in the original feeding area.
  2. if not solved, clean the Document feed sensor or replace the same. But for this you need to open the body of the fax machine.
Mar 11, 2008 | Canon FAX-B820 Plain Paper Bubblejet
Muratec MFX 2500 copies have lines
need to be more specific, printing have both hor. and vert. lines aas well as copying ???
Dec 18, 2007 | Muratec MFX-2500 Plain Paper Laser Fax
SCX-6320F Samsung
Dear ,
Do u need to pull out the paper or  it comes on it's know,
THE ADF SENSOR OR
THE ADF ASSEMBLY CABLE SEEMS FAULTY..
PLEASE REPLACE AND CHECK..
HAPPY FAXING/COPYING/PRINTING
OMNIPRESENT
Oct 10, 2007 | Samsung SCX-6320F All-In-One Laser Printer
Copying
You should be able to open the machine up easily and see the jam. It is a very small unit and no plece for the paper to hide. Does the unit use a film ribbon to print from. If so, remove the ribbon to see the jam.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 09, 2007 | Sharp UX P100 Plain Paper Thermal transfer...
Brother FAX-575 Plain Paper Thermal Logo
117 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
