Question about Dryers
Our Bosch WTA 2000 drier has a 'Low Heat' switch which seems to have a mind of it's own. what is the operating sequence for this switch and Is there a high heat setting?Andy
  • 126 Answers
SOURCE: Dryer produces low heat but not high heat
check the vent outside it seems to be getting too hot and cycling the element off and on your safety therm.
Posted on Dec 13, 2007
mikedurland
  • 481 Answers
SOURCE: low heatworks, high heat does not.
it sounds like you need a set of thermo switches. one may have stopped functioning. a service tech can test them easily. should be low cost
Posted on Jun 29, 2008
  • 1253 Answers
SOURCE: my dryer does not not produce enough heat when in operation. It seems like it is just running and generating very low heat. Please help.
Really sounds like an element is burnt out or a safety has malfuctioned. Possible loss of power so check plug, recept., and breaker. Look for burnt terminals and reset breaker even if it does not look tripped. Dryer usually have 2 elements. One for low heat and both for hi heat. May want to check this out. Please keep in mind that some repairs can cost more than buying a new dryer. I got one at Lowes for about $200 and it works great. I don't think you can get a repair guy out and to the repairs for that amount. Just depends on how many whistles, buzzers, and bells you want on your machine.
Good Luck.
Posted on May 09, 2009
canbruce75
  • 1776 Answers
SOURCE: bosch tumble dryer, model wta 4100 , no heat,
If the dryer isn't heating, check for a blown thermal fuse or a faulty heating element. Both components can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty component. Both components are located in the rear of the dryer. The thermal fuse is about an inch long and is usually attached to or near the exhaust duct. Hope this helped and best wishes.
Posted on Sep 12, 2009
heatman101
  • 43501 Answers
SOURCE: bosch wta 3100 no heat
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on May 06, 2010
I replaced the heating element on my Bosh WTA 2000 tumble dryer , but it still doesn't heat up? Is there other components that could be damaged?
There are multiple thermal protectors on the circuit. Make sure they are all ok. Double check your connections
Aug 08, 2013 | Bosch Dryers
Dryer doesn't power-on.
Simple answer: way too much dryer lint. Worth cleaning out.
Mar 04, 2018 | Bosch Axxis WTA 3510 Electric Dryer
In heat mode but heat strips don't come on and the air handler fan dose not turn off
Maybe a bad sequencer.unplugged wire from sequencer and see it unit shut off .Sequencer is typically a relay
Feb 23, 2018 | Goodman GMS90703BXA Heater
My bosch wta3500 dryer is not heating to dry the close. any idea what it might be
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Feb 22, 2011 | Bosch Axxis WTA 3500 Dryer
Bosch wta 3100 no heat
heatman101
May 03, 2010 | Bosch Axxis WTA 3003 Electric Dryer
Why does my bosch dryer wta 2910 only blow cold air?
If the exhaust vent tubes have never been removed and thoroughly cleaned in years this will cause the sensor to keep the heat off in your dryer. If clean the moister sensor is at fault
May 02, 2010 | Bosch Axxis WTA 3500 Dryer
The tumble dryer drum turns but there's no heat on either low heat or full heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Mar 13, 2010 | Bosch Axxis WTA 3003 Electric Dryer
Bosch wta 2000 dryer, heats but drum not turning
If you can hear the motor running then the belt has came off or it is broken. If you cant hear the motor then you possibly have a bad motor.
Mar 08, 2010 | Dryers
Dryers Logo
74 people viewed this question
Top Dryers Experts
