Question about Sony KP-61HS10 61" Rear Projection Television
Sony kdf-e50a12u rear projection lcd bravia. red...shadows
Hi there .. i have the above mentioned tv .every thing is ok when i am watching my sky hd, there is no shadows, but whenever i turn on my ps3 or hd dvd player i get red red shadows to the left hand side of items on the screen like a ghosting. i have tryed new hdmi cables and still nothing changes. sometimes when i go to turn on my hd dvd player it wont turn on until i disconect the hdmi cable, but once i put it back in it works ok but still the shadows. even when i watch a dvd through my ps3 it still has the shadows... please help........ thanks 4 your time
  • Anonymous Jan 22, 2008
    Hi
    Got the same problem and was told that the tv and ps3 were running at different speeds and there was nothing I could do about it! Then went somewhere else and spent over £100 on different cables but still have the problem. I am going to contact sony themselves today, will let you know what they say ....!!??
Hello - I had the same problem. If you call a tech they will say that the picture tube is broken and that it will cost $350 + labor to fix it because Sony does not make the part! Do not believe that cock and bull story.
All you need to do it to remove the front lower panel where the speakers are located. Behind it there is a cardboard / plywood board fixed on to the TV with 4 screws. Remove this board. you will then find a switch that contains 6 bolts/screws that can be adjusted:- 3 (upper) and 3 (lower) sets of adjustment knobs or large screws that are probably marked as G(for green), R(for red) and B(for blue). You will probably have to adjust them very slightly while the TV is on. Be careful so that you dont shock your self! And Voila, the problem will be fixed!!
I am not an electrical engineer, but work as an IT professional. It saved me a bunch of money, not to say a happy family/household!
Posted on Dec 10, 2007
Try this http://www.avforums.com/forums/showthread.php?t=459681
Posted on Oct 02, 2007
Picture all blurred when playing bluray
Connect the blu-ray player into the HDMI port that currently has sky on it. Does it work then? if so the port you were using has failed. If not the blu ray player has failed.
Dec 28, 2013 | Sony Televison & Video
I have sony lcd hd ready 50inch rear projector tv model number KDF-E50A12U tv comes on after couple minuets tv clicks off to stand by then red light in stand by flashs 3 times gos back to green repets
Hello
Three blinks of standby light to Sony TVs indicates that the regulated voltage output from power regulator board is above thatn normal. The problem is with its power supply regulator board. Replace all the electrolytic cpacitors on that board with new ones. Replace all of them including small and large ones, at one time. OK.
Feb 04, 2012 | Televison & Video
Hi i have a sony lcd projection kdf-e50a12u and as i turn it on the green light flashes for a few minutes untill it turns to red along with the light next to it and stays red?
Sir check the lamp of your projection if already damage, if damage replace the lamp and reset also the lamp hour meter. Remove the screws to open the panel labeled "lamp" on the back of the Sony TV. Remove the screws that hold the lamp in place inside the TV. Pull the lamp out. Let me know what is your observation to the lamp so I can guide you. Good day and best regards.
Sep 15, 2011 | Sony KDF-E50A12U 50" LCD HDTV
Sony bravia KDF-E50A12U rear projecion tv wont turn on
Hi it sounds like it could be an issue with board that powers the lamp ,it's called the ballast.When you put a new lamp in the ballast has to provide more power ,when it starts to go weak it will not light up.Sometimes you can put your old lamp in and will work fine.Try partstore.com they might have it right there.Hvae a blessed one!
Mar 02, 2010 | Televison & Video
Fuzzy picture
You can't make SD look like HD thats why HD came out, the best you can do is adjust the picture controls to get the optium picture
Apr 11, 2008 | Sony KP-57WS500 57" Rear Projection...
Shadowing on screen
You should get a good surge protector. Sometimes some areas have a spike in the power. That will cause interference in the TV signal coming from your PS 3. Try out different surge protectors that should solve your problem.
bimmerhp
Jan 23, 2008 | Sony Playstation 3 (PS3) Console
Sony kdf-e50a12u rear projection lcd bravia. red shadows
This is due to you having a projection tv, some projection tvs are really bad for game playing and especially if you have a hdtv. even in the p23 manual it says that you shouldnt use with a projection tv cause it can damage your tv's screen permanently. I personally still play mine but, thats likly the problem.
Aug 11, 2007 | Sony KP-61HS10 61" Rear Projection...
Sony KP-61HS10 61" Rear Projection Television Logo
238 people viewed this question
Top Sony Televison & Video Experts
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
