Question about Robotoolz Laser Level With Simultaneous Plumb + Square
RT-7690-2 RF remote control/laser detector
Just keeps beeping and won't read the laser
2 Suggested Answers
  • 30 Answers
SOURCE: RF Remote for RT-7690-2 Unit
I've never come across that with mine, but I have a couple thoughts that you might try ........
First, check and make sure there are no buttons stuck down. And the second thing is take the battery out for a minute or so and see if it clears it. In fact, you might also want to check the battery voltage. I suppose there's a chance that low voltage could do that??
Hope one of those helps!
Ed
Posted on Jul 25, 2011
Uniden uh015sx won't receive or scan
FM Detector/demodulation issue. These radios have a problem in this department. I have had a few come through work that were on mine sites and no longer receive or scan. On the display it will show the signal bars fully lit as if there is a strong signal, but no RF is heard. The giveaway is being able to hear button press beeps and alike but no signal noise is ever heard.
If the unit is still under warranty send it back and have it repaired. If no longer under warranty, then it's spare parts.
Jul 28, 2012 | Radio Communications
RF Remote for RT-7690-2 Unit will not respond to either the horizontal or verical Buttons and keeps beeping and the arrow flashing in the horizontal mode.
Ed
Jul 23, 2011 | Robotoolz Laser Detector/Receiver
Won't print System Error E100 in window
E100 means a beam detect failure of the laser that "writes" the image to the drum. There are 3 logical causes. The laser scanner unit has failed.Next down the list is the DC controller has failed.Last, the Image Processing Board has failed. The code indicates the laser is not coming on which would lead you believe that it would be the primary cause.The laser unit has a detector inside that looks for the laser and reports success or failure to the image processing board.The DC controller is resposible for turning on the laser and its ouput. That's why there are at least 3 variables.
Jul 09, 2011 | Canon imageRUNNER 2010F Copier
I want to disable the remote sensor function on the first alert sa302. My tv remote keeps setting off my smoke detector
First you need to remove the battery, hold test button down while re-installing battery, when detector beeps,it disarms remote feature. Normal detector then. this should dissable the remote feature. this is a very common complaint. If for some reason it wont turn the remote off get a piece of tape to cover the sensor.
If your happy with this solution a vote for the thumb up would be greatly appreciated. Thanks for using Fix Ya
Jul 05, 2011 | First Alert SA302 Dual System Smoke...
My Robotoolz : RT-7210-1 was stored improperly and now the lazer beam is dim and hard to see in bright sunlight... Could really use info on repair or info on a place that can repair it for me.
Improper storage (I've done it too), usually means that the batteries have become too hot - and
therefore weak. The first thing I'd try is changing the batteries.
The 635nm laser operates on (4) AA batteries, and the rotary uses (1) 9V battery.
The online reviews for this a horrifically bad - see:
http://www.gosale.com/4364289/porter-cable-robotoolz-rt
May 17, 2011 | Robotoolz RT-7210-1G Robolaser,...
I use a Logitech G7 Laser cordless (RF) gaming mouse. The operation has become intermittent, with the mouse freezing, sometime every couple of seconds, sometimes every couple of minutes. I normally use...
It's possible the Firefly remote is interfering. It's also possible the mouse is going bad (G7s have been around for a while). I'd contact Logitech and see what they can do for you - their warranty support for mice is terrific.
Feb 28, 2011 | Logitech Inc G7 Cordless Laser Gaming...
Hi I need a manual for porter cable robotoolz RT-7690-2 blaser level . Thank you.
You can get the manual on the link below please give it time to download. It is a large file.
http://www.ferramentaonline.com/shop/az/futtura/RT-7690-2%20series%20user%20guide.pdf
Good Luck and please rate 4 thumbs up for the free answer.
Jul 01, 2010 | Garden
Motorcycle Laser Detector False signal
This is a power noise issue caused by alternator whine. There are two solutions. First, you could try wiring the RD's power directly to the bike's battery terminal. Or you can get a snap-on RF filter which is available at your local radio shack. Loop the RD's 12V power wire around the snap-on RF filter two or three times and then snap the filter closed. The RF filter is simply a ferrite choke. It should block the alternator whine sufficiently to stop the laser falses. If the RF filter doesn't do the trick, then you will need to get a noise filter from a car stereo shop. The cheapest one will do, as long as it says that it will attenuate noise by 30dB or more. Come to think of it, a car stereo shop could have a RF filter installed on your bike in less than 20 minutes. So perhaps that might be the way to go.
Mar 31, 2009 | Cruisader Radar Detector
Robotoolz Laser Level With Simultaneous Plumb + Square Logo
24 people viewed this question
Top Robotoolz Measuring Tools & Sensors Experts
Jim Parker
Jim Parker
 Mikey
Mikey
Tom Chichester
Are you a Robotoolz Measuring Tool and Sensor Expert? Answer questions, earn points and help others
