Question about Black & Decker T1029 Classic Chrome 2-Slice Toaster
Black & Decker T-1029 2-slice Toaster - lever broken
I just started using my new toaster. I toasted 2 bagels with no problems. We went to toast some bread and now the lever that you press down in order to turn it on won't lock. I need to know whether it's broken or something jammed in there that can be fixed.
  • davek18 Nov 09, 2008
    sometimes will not lock have shaken crumbs out and it is better but I am not sure.
  • Anonymous Mar 25, 2014
    Back in the 50's, you knew your baby doll had met her end when your thumb went through her gummy, rubber stomach. The blue "egg" handle on this toaster lever feels exactly the same. It looks as though it's been directly molded to the lever, however. I don't know how to get it off, or what to use in its place if B&D does not offer replacement blue "eggs". This was a very high-end design toaster in its day, and it works really well. I just can't put it in a land fill.
  • 69 Answers
Main problem with these is crumbs, they get stuck between the 2 surfaces of the small electromagnet that keeps the lever down, consequently it does not stick anymore, try drop kicking it in the drection of the garbage can, this sort fright may just scare it into working again.
Posted on Sep 25, 2007
  • rustie1958
    rustie1958 Mar 22, 2013
    TY James! At least one side is working. I banged the heck out of it and u wouldn't believe the crumbs that came out. And I am usually the clean buff. TY once again
Why does my toaster ony toast one side of the bread
Because the nichrome wire on one side of the toast has broken.
Its time to get a new toaster.
Mar 17, 2015 | Baking
Received 2 slice toaster (kitchenaid) as a gift - from the very 1st time it was used, only the outer coils would heat up, so only 1/2 of each slice ever gets toasted!!! Anyone who could help solve this...
I think it is set to cook bagels. Check the control settings.
Most toasters have a bagel setting which only cooks the
sliced side of the bagel. This model is designed to accept bagels. Hope this helps.
Jul 22, 2011 | KitchenAid KMTT200OB 2-Slice Toaster
The lever doesn't stay down..for Toast-It-All T2200 toaster
is the power working at the receptacle which it is plugged into ??
try another receptacle, you may have a blown fuse or circuit breaker off
Feb 14, 2011 | Black & Decker T2200 Toast-It-All 2-Slice...
Black & Decker Toaster, model 3550: Pressing the handle down to lower the bread and start the toasting doesn't lock in place anymore. The toaster will toast, but you have to hold the handle down so...
The fact that pressing down the lever fails, means the toaster contact will not function and can not be repaired. Since a two slice toaster is only $15 at Target, why bother fixing a toaster?
Feb 20, 2018 | Black & Decker Toast-It-All Plus T3550...
Black and /decker toaster model T3550. The outside elements work but the middle ones do not. so only one side of the bread is toaster.And the handle must be held down the whole time to toast
The heating element wire is really thin and there is a great posssibilty of breakage. There is also a spring switch in which the lever locks when toasting. needs replacement.
May 11, 2009 | Black & Decker Toast-It-All Plus T3550...
Toaster only toasts on one side
Please ensure that the "Bagel" function is not selected (LED is not lit up). The Bagel function will toast one side of the bread while only warming the other side.
Mar 13, 2009 | KitchenAid KTT261 Ultra Power Plus 2-Slice...
Only toasts one side of toast
The cancel button is stuck in the in position
Jan 13, 2009 | Hamilton Beach 22502 Digital 2-Slice...
Bagel setting stuck on.
Mechanism slight is the problem and spring give way.
Rdgs
alan
Dec 15, 2007 | Tefal Avante Deluxe 4 Slice Toaster
Duraband 4 slice toaster manual model # TS-5221
if u need a manual for a toaster, then u r really in trouble...espcially for the amt of money u paid for it.
ok...
if u need instructions on how to use a toaster...here goes:
When:
A toaster is used to heat slices of bread, bagels, waffles, etc. to a hot, crispy consistency. Most toasters allow the user to set the toasting length to ensure the toasted bread comes out to temperature and crispiness to the user’s likes.
Where:
Toasters should be used on a flat, uncluttered surface near an electrical outlet but far from sinks, or running/standing water.
How:
To toast bread in a toaster, follow these instructions:
1. Place slices of toast, one each, in the slots on the top of the toaster.
2. Find the toast setting (a knob or lever) and adjust to the desired wellness of the toast. (Generally, there is a scale printed near the knob or lever ranging from light to dark toast).
3. Push down the toasting lever (moving the slices of bread down into the toaster between the heating elements.
4. When the toast is finished, the slices will “pop” up automatically.
5. Remove the toast from the toaster.
WARNING:
If the bread should get stuck inside the toaster, DO NOT PUT ANYTHING INSIDE THE TOASTER in attempt to dig it out. UNPLUG the toaster, turn it upside down and shake. If the toast does not fall out, use a plastic fork or knife to gently remove it from the toaster. Using metal utensils could damage the heating elements. NEVER stick anything in the toaster while it is plugged in.
*For further safety, it is recommended that the toaster be unplugged after each use.
I wish u luck and happy toasting.
Oct 14, 2007 | Kitchen Appliances - Others
Black & Decker T1029 Classic Chrome 2-Slice Toaster Logo
527 people viewed this question
Top Black & Decker Kitchen Appliances - Others Experts
Irene Tulloch
nanisacan
Level 1 Expert
Are you a Black & Decker Kitchen Appliances - Other Expert? Answer questions, earn points and help others
