Question about Christie Roadster X6 Multimedia Projector
Service Menu Password - Christie Roadster X6 Multimedia Projector
Toshiba e-Studio 3540c we cant go in to service mode. 08 enter show this USER NAME. (SERVICE). PASSWORD. HOW DO WE BYPASS THIS
CHANGE USER PASSWORD
When the MFP Local Authentication function is enabled, users can change their authentication password that has been entered in the authentication screen from this menu.
? [CHANGE USER PASSWORD] is available only when the MFP Local Authentication function is
enabled.
? For instructions on how to display the CHANGE USER PASSWORD screen, see the following page:
? P.8 “Accessing the User Menu”
Change the password.
1) Press [OLD PASSWORD] to enter the current password. 2) Press [NEW PASSWORD] to enter the new password.
3) Press [RETYPE NEW PASSWORD] to enter the new password again. 4) Press [OK] to save the new password.
You will be returned to the USER menu screen.
? When you press [OLD PASSWORD], [NEW PASSWORD], or [RETYPE NEW PASSWORD], the on-screen keyboard is displayed.
For details of the on-screen keyboard, see the following page:
? P.158 “On-screen keyboard”
? The input password appears as asterisks (*) in the [OLD PASSWORD], [NEW PASSWORD], and [RETYPE NEW PASSWORD] boxes.
Oct 23, 2016 | Toshiba 3540c Color Copier
Best way to remove a parental lock from a lg plasma tv
LG Service Menu Instructions
Method 1
Press and Hold <OK> button on remote as well as TV panel at the same time for a few seconds.
Method 2
Press and hold the {MENU} button on the remote and the {MENU} button on the TV at the same time for at least 5-7 seconds.
Method 3
Press and hold the {MENU} button ON THE REMOTE until a 4-digit password screen is displayed.
LG Service Menu PIN/Password Codes
  • 8 7 4 1
  • 8 7 4 3
  • 7 7 7 7
  • 0 0 0 0
  • 8 8 7 8
  • 0 4 1 3
LG LCD Monitor Service Menu Instructions
  1. First turn off the lcd monitor, then press and hold the "MENU" button, then turn on the monitor. Release MENU button after the monitor is turn on.
  2. Press "MENU" button to open the OSD menu, at the bottom of menu, you can see a new selection to go into the factory service mode. Inside the factory service mode, you can see useful information like, product model, manufacturer date, F-ENGINE chipset version, lcd panel number and etc.
Mar 16, 2016 | LG Televison & Video
How to enter service mode konica minolta magicolor 7450
1. Display [SERVICE MENU] on the menu screen and press the MENU/SELECT key.
2. [ENTER PASSWORD] message is displayed.
3. Set first digit of password with the up key??/down key?? and press the right key??.
4. Repeat the above procedures to set up to seventh digit of password.
Enter "KMM7450" for service password. Press the MENU/SELECT key.
5. Press the MENU/SELECT key.
Jun 20, 2012 | Konica Minolta magicolor 7450 Laser...
Unlocking lg rumour 2 / lg265 phone
CODES i found to work on this phone are:
##123456# = service program menu (no password needed)
##3282# = 3G menu
##2739# = AMS menu
##2769737# = browser settings (IP, Proxy , homepage , ETC.)
##2342# =CDG2 menu (lot diff catagories)
##7764726# =programming menu
##786# = RTN menu ( only phone info ) no password needed
Nov 29, 2011 | Cell Phones
How to activate call barring service in nokia 7210
Hi There and Welcome to Fixya.
For you to activate the call barring service of your Nokia 7210, follow these steps as you navigate to the menu :
  • Select "Menu" key
  • Choose "Settings"
  • Choose "Security"
  • Go to "Call Barring Service"
Please note that this feature requires a Barring Password. In order for you to change/create a barring password, navigate through the same menu options but choose "Access Codes" under the "Security" menu.
For your convenience, here's the link that will take you straight to the user's guide :
N7210
Hope this helps and Thank you for using FixYa.
Mar 30, 2011 | Cell Phones
Password manual service tv konka k1418c
bagaimana pasword menu servis konka model k1418c
Dec 16, 2009 | Konka K1398U 13" TV
Sony PCS-1 dont remember admin password
1. Access the Setup menu as follows:
Press and hold the MENU button on the remote commander.
2. Select Dial using the �� button on the remote commander.
3. Access the Service menu as follows:
Press 7 then 2 on the remote commander (without pressing the
PUSH ENTER button).
The Service menu appears. (See Figure 1.)
NOTE: To cancel Service mode and return to the Setup menu,
select Cancel using the arrow buttons, and press RETURN
Clear setup and FINISH
Bye Zamani Ali
azamani@iooc.co.ir
Nov 24, 2008 | Sony PCS-1 (PCS1) Video Conference
Vchip
This is from the service manual:
If you forget your V-Chip Password
- Omnipotence V-Chip Password: 8205.
Using the “Change Password” item
- When enter the “Parental” menu, select “Change Password”.
- Press ▲ or ▼ button to highlight the “Change Password” item.
- Press Enter button to confirm and pop up a menu.
- Use 0~9 buttons input the omnipotence password(8205), then Press Enter button to enter and
pop up a menu.
- Use 0~9 buttons input your new password.
- Press ▼ button to move to confirm blank.
- Use 0~9 buttons input your new password again.
- Suggest: Change to your familiar Password again.
Hope that helps.
Jun 23, 2008 | Akai PDP4206EA Television
Unlocked european phone MMS
wrong! ive got an unlocked european phone and i got these settings that cingular WOULD NOT give me off the net
-= MMS Web Session =-
Menu -> Web Access -> Web Sessions -> Menu -> New
Homepage: http://device.home
Service type 1: WAP
Gateway IP 1: 066.209.011.061
Port 1: 9201
Domain 1: (blank)
Service Type 2: WAP
Gateway Type 2: 000.000.000.000
Port 2: 0
Domain 2: (blank)
DNS 1: 000.000.000.000
DNS 2: 000.000.000.000
Timeout: 10 minutes
CSD No. 1: (blank)
User Name: (blank)
password 1: (blank)
Speed (Bps) 1: 9600
Line Type 1: ISDN
CSD No. 2: (blank)
User Name 2: (blank)
Password 2: (blank)
Speed (Bps) 2: 9600
Line Type 2: ISDN
GPRS APN: wap.cingular
User Name: WAP@CINGULARGPRS.COM
Password: CINGULAR1
-= Message Setup =-
Main Menu -> messages -> Menu -> Message Setup
MMS Message Setup (This is very critical)
Inbox View: Sender
Srvce Center No: +13123149810
Auto Cleanup: 5 days
Email Gateway: 36245
SMS Alert: On
Use GPRS: Yes
-= MMS Message Setup =-
Main Menu -> Messages -> Menu -> Message Setup ->
MMS Message Setup -> Server Info -> Menu -> New ->
Service Name: CINGULAR MMS
Server Name: http://mmsc.cingular.com
Web Session Name: (Choose the Web Session you created for MMS)
set to default
Mar 10, 2008 | Motorola Mobility RAZR V3
PCS-1
Reset password sony pcs-1
PUSH ENTER button).
select Cancel using the arrow buttons, and press RETURN.
Jan 18, 2008 | Sony PCS-1 (PCS1) Video Conference
Christie Roadster X6 Multimedia Projector Logo
116 people viewed this question
Top Christie Office Equipment & Supplies Experts
jasbo
jasbo
Lawrence Oravetz
Are you a Christie Office Equipment and Supply Expert? Answer questions, earn points and help others
