Question about Garden
John deere lx 279 mower loses power
When i try to engage mower engine slows down
  • 127 Answers
SOURCE: john deere mower won't engage
on the engine there is a shaft with 2 pullys ,drive belt goes to the top closet to the engine lower pully is for the deck
there also is a saftey switch located on the deck which should shut down blade operation when raised. check the mandrels for broken bearings by grabbing the pully and wiggle them back and forth looking for movement could be possible that one madrel is shot giving you that bad sound which is crushed bearings
Posted on Jun 30, 2009
mickey813
  • 472 Answers
SOURCE: John Deere 160 riding mower. When I try to engage
CK THE SEAT SWICH OR THE BRAKE SWICH ONE OFEM IS BAD
Posted on Oct 02, 2009
mickey813
  • 472 Answers
SOURCE: John Deere L120. Engine dies when PTO switch is pulled.
sounds like the seat switch is bad
Posted on Mar 02, 2010
wireguy212
  • 1627 Answers
SOURCE: john deere gt 235 electric blade engagment but
One of two possible causes;either the PTO switch is defective or the switch for the reverse peddle is out of adjustment .The only other thing i have seen cause the PTO to shut down is a lack of battery power due to the machine not charging.
Posted on Mar 21, 2010
  • 183 Answers
SOURCE: John Deere GX85 Riding Mower engine surges
did you drain the gas before putting it away last season? If not, I would drain all of the gas and put in fresh gas, also replace any in line gas filters
Posted on Apr 06, 2010
GOOD MORNING, I HAVE A D140 JOHN DEERE LAWN MOW,IT RUN WELL WHEN NOT MOWING BUT WHEN ENGAGED IT SLOW DOWN AS THOUGH IT HAS TO CATCH IT'S BREATH LESS THAN THREE YEARS OLD
Make sure there isn't anything binding the deck belt or blades. Check the spindles for free movenent. If all that is good then it might be the linkage that is supposed to adjust the throttle when the engine is under load or it might be a carb issue...especially if you run ethanol gas in it.
Aug 27, 2016 | John Deere D140 22HP V-Twin Foot Pedal...
John Deere loses power under pressure what can cause this
what is the unit? have you checked fuel filters air filter? is the tank outlet blocked with debris?
Sep 14, 2014 | Garden
On john deere la150, if i sit on seat and engage blades,,,nothing, but when i lift of seat, blades engage and motor shuts off. Replaced seat switch and did not fix problem
"On john deere la150, if i sit on seat and engage blades,,,nothing, but when i lift of seat, blades engage and motor shuts off. Replaced seat switch and did not fix problem" Okay, what I'm hearing is that "nothing" means the blades-driving PTO won't engage (declutch) when you switch on mower; but then, (say) as you start to dismount the mower (seat) the mower (drive clutch) engages even as the deadman switch (seat switch) kills the engine (and the drive/pto shaft starts to slow down. The key here seems to be that at full engine torque the clutch is unable to remain engaged but, rather, slips so that mower blade inertia (resistence) cannot be overcome...but as engine/pto rotation slows the clutch is able not to slip. First place to consider is the clutch gap which is probably to0 large (possibly from wear and tear, possibly not). So check specs and how-to from manual or factory and reset the pto drive clutch gap...not hard to do. If clutch gap is not the problem then most likely rehab or replacement of the clutch assy will be needed...is the mower has many years use sufficient to wear out the clutch. Another possiblity is an electic (wring/switching/grounding) problem involving mower and deadman switches.
Aug 19, 2014 | Garden
Why does the engine slows down when engaging the blade
check fuel filter and pump pressure starving for gas
Jul 02, 2014 | John Deere Garden
JD lx 279 need to replace gas line diagram
Go to John Deere .com for diagrams and parts list.
Apr 11, 2014 | Garden
Engine seems to run fine but when mower is engaged it loses power. It is a john deere 325.
Check to see if the mowing deck spins free or somewhat free with the engine off, It might be wrapped up with twine or something stopping from spinning, this will bog down the engine. Hope this helps.
May 29, 2011 | John Deere Garden
What would cause the mower to hold back and make roaring noise and hardly go john deere model lx 279
A stuck brake maybe.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Jul 19, 2010 | John Deere 195HP Hydrostatic 42" Cut...
Blades stopped can't restart now engine won't turn over
Check battery voltage should be 12v or above. Battery could have gone bad or charging system bad. Voltage draw of electric clutch pulled battery down.
Sep 25, 2017 | John Deere 420,1020,2010,2020,2510,2520...
Oct 02, 2009 | John Deere Garden
Garden Logo
51 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
