When I am using the vacuum, the beater bar does not seem to be working. I have cleaned all debri (hair, dust, fuzz, string) but it still doesn't roll when I move the vacuum back & forth. Also, the two switches to change the suction from carpet to tile/linoleum suction have no variance. There used to be a distinct sound when you changed from one switch to the other. What do you suggest?
SOURCE: beater bar on Dyson upright won't turn when handle is lowered
I have finally fixed my sister's dyson dc 15 beater bar problem. It was just 2 tiny broken wires connect to circuit board lead to the beater bar. The wires broke where they go through the black rubber gommet. You need a torx screwdriver tx 15 to remove 2 plastic covers to access the wires. When looking at the front of the vacuum, the gray covers located on the right side of the vacuum. 1 big cover with a black rubber gasket and other small gray cover is on the rotating ball area.
This my new year resolution is to warn people not to buy Dyson vacuum cleaner ( Junk) design to break down! Shame on you Dyson!!!! Save your money find good old vacuum cleaner with metal parts.
OLD IS IN NEW IS JUNK!
Happy New Year!
SOURCE: Suction loss when handle is tipped back to clean carpet
Ours did the same thing. I cleaned the filter and canister thoroughly. It needed to be cleaned, but that didn't fix the problem. I removed the plate under the carpet brush bar (three quarter-turn screws) and removed all hair, lint and threads from the rollers and brush. THEN my husband found the real problem: a piece of flexible hose running from the head into the hose (on the left side when behind the vacuum) was completely clogged. The hose will detach from the head, and you can remove debris. Once that clog was removed, the hose easily re-attaches, and we had great suction once again.
SOURCE: I took the vacuum apart, and cleaned the filter,
Check its assembled correctly . Sounds like something is out....
SOURCE: When switching the vacuum (DC17 Animal) over to
The drive belt has probably broken. You can get a replacement belt here:
Dyson DC17 Belt
SOURCE: beater brush bar will not work
they are not made to work in the upright position. the beater bar only runs when in the non upright position
