Question about Garden
Hydrostatic oil level john deere f910
How do you check the level
    New Friend:
  • 6 Answers
While at the front of the mower look under the mower between the two lift cylinders. You will see a sight tube which maybe hard to see the level depending on if it is using the Hy Gard Fluid or Type F, etc. The level in the tube should be approximately in the middle when the mower is sitting level. If you are using Hy Gard and have a hard time seeing the level add the some hydrostat oil dye to it. I use John Deere MT3668 dye.
Posted on Aug 14, 2014
2 Suggested Answers
  • 6 Answers
SOURCE: John Deere tractor stalls when I let up on the clutch.
when you let the clutch out and it stop engine it could be a safty switch. but a safty switch would not make it stop after it was runnig unless you have a short in the wire.
Posted on Jul 08, 2009
John Deere 430 lawn tractor hydrostatic transmission will not work in forward or reverse even with no weight on the axle. New filter and oil did not fix. What should I check next?
Some have a procedure for "burping" air from the hydraulic system. Changing engine oil and filter won't affect it- independent system.
Apr 02, 2017 | John Deere Garden
My John Deere rinding lawn mower won't go forword or backwards
John Deere mowers, for the most part, use hydrostatic transmissions. These use an oil of some type (they vary by model) in the transaxle to provide hydraulic pressure to move the tractor. Older tractors will eventually experience some oil leakage over time due to seal wear. If the level gets too low, then you fail to move. Check the oil level in the transaxle. The location of the reservoir varies from model to model. If it is low, after determining the correct oil to use, fill to proper level. Then, start the tractor and work the hydrostatic drive lever forward and backward slowly and continuously until you get full speed operations in both forward and reverse. This can take a few minutes until all the air has been purged from the system.
Oct 03, 2016 | John Deere Garden
How to check the hydrostatic oil on a lt 116 john deere lawn mower
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Jun 09, 2016 | John Deere Garden
How to change the oil
Scott, look for drain plug, low on engine block or under engine. Drain oil into waste container, remove and change oil filter if equipped.
Refill oil to proper level using specified oil.
Apr 18, 2016 | John Deere D140 48 in. 22 HP Hydrostatic...
The Hydrostatic transmission on my Lt150 mower is making a screeching noise when I push on the forward/reverse pedal. The mower will move very slow then stop. It is not the drive belt!
Check trans. oil for debris and quantity. If level is low try topping up first and if this works it would pay to disassemble in the near future, clean the oil filter and fill with clean oil.
Oct 01, 2014 | John Deere Garden
John deere lx188
a lot of hydrostatic problems can be fixed by changing the oil and filter so try that first see if it helps
Mar 01, 2014 | John Deere Garden
No power when engage mower deck John Deere F910
Mine acted the same way. Found out I had lost a cylinder. I would check your compression before doing anything else.
Aug 12, 2012 | John Deere Garden
I have a john deere 316, the other day i was moving snow with it and all of the sudden it lost all power to the hydrostatic and to the front end quick attach. I was wonder what would cause this and how to...
First check level of hydraulic oil. Sight plastic tube just above and to the right of the hitch. Should be in the middle of the tube.
How long since you changed the hydrostatic oil filter under the seat deck?
Next see if the small splined shaft is turning btween the seat deck and the transaxle from the rear of the tractor. If not, it sheered a key in the hydrostatic drive shaft from the motor to the drive. (Had this happen to me)
Check the lever under the right side fender that disables the hydrostatic transmission to allow the tractor to to be moved without dragging the wheels. Make sure its not in the wrong position.
If all these are ok then the hydrostatic pump has failed.
Jan 01, 2011 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
221 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
