Question about Frigidaire ATF6000ES Front Load Washer
Frigidaire Washing Machine Model 975FS2
I have above Frigidaire Washing Machine Model 975FS2 and recently it has started giving a problem of making noise when running. Kindly advise me. I opened the first rotating part by opening a centre bolt, cleaned and refixed. It is a top loading Machine. Thanks D.S.
    Novelist:
    Champion:
  • 244 Answers
All wsher have bearings which hold the drum centrally if these are worn than the machine will make a noise and get louder on spin and will only get worse sometimes cheaper to replace washer than it is to fix your bearings sorry m8
Posted on Aug 12, 2007
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
AFTER WATER FILL , WASHER HAVE BIG NOISE BUT NOT RUNNING
Good Morning Friend,
I understand that you have to open and close the door numerous times, on your Frigidaire washer, to get it to start. I also see that it is making a big noise before running the cycle. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. If further troubleshooting is needed, please leave me the model number of your washer. Typically, this number can be found on the back of the door or possibly around the edges where the door meets your appliance. Hope this is helpful.
-Best Regards-
WP
Jun 12, 2014 | Frigidaire Washing Machines
SIEMENS WM1000 model timer to be connected.Kindly provide
i have a Siemens washing machine there is washing problem in washing ,some noise r generate like as chunk and wash cycle is not run proper and all function is work properly (darpan jain 9827622024)
Jan 25, 2010 | Siemens Washing Machines
Frigidaire (glws1439fs1) top load washer
If your machine is old means may be brake shoe might be very closes joined make adjustment and correct it otherwise it is a bearing noise kindly replace the bearing along with washer
Dec 24, 2009 | Frigidaire Gallery GLWS1339EC Top Load...
Washer runs until rinse cycle, then starts making
pull problem code from machine. give knob a turn to wake machine-wait 5 seconds-then hold down start and cancel buttons at the same time. Your problem code will come up.
Nov 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front loader makes banging noises in spin cycle
hi there.......if this problem has just recently appeared...its quite possible that 1 of the tub suspension springs has broken resulting in the tub lying at an angle and causing this unbalance....you can check this by tilting the machine and looking at the tub susension points
regards Sir Galahad
Aug 16, 2009 | Frigidaire 14 Cycle Tumble Action Washer
Started a load of laundry water filled fine started washing and agitating and then heard a weird noise like something got stuck and went and it sounds like motor is running but will not agitate or spin and...
Please give a make and model of washing machine. I suspect that something has stripped out between the motor and the transmission, which is the noise you heard.
Jan 24, 2009 | Washing Machines
LG WD-8074FHB frontloader washingmachine, vibration during spinning
As happened to me, it could be that one of the shock absorbers at the base of the unit has come adrift from its securing point.
Jun 23, 2008 | LG Washing Machines
Frigidaire ATF6000ES Front Load Washer Logo
134 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
