Polar 78x guillotine
Error " no position counter impulses (654)"
3 Suggested Answers
erdnasetab
SOURCE: hello we have a polar guillotine
Hi.
Its caused by the clutch disc binding on the shaft. Usually a strip down and clean up sorts the fault.
07808 901184
Andre Bates
Independent Polar guillotine engineeer
Posted on Feb 20, 2013
erdnasetab
SOURCE: safety bolt locked on polar guillotine
I can fix that.
07808 901184
Andre Bates
Polar guillotine engineer
Any one know 4by4 Mitsubishi triton no codes cranks need help urgent
the tachometer ( rev counter) get its impulses from the ignition system or in the case of a diesel from the crankshaft position sensor
if it runs with introduced fuel ( dangerous for a diesel) but then dies, that indicates insufficient fuel pressure to the injectors
could be a diesel pressure pump ( test to 25,000 psi) not producing sufficient pressure to work injectors
problem fuel supply to pump, tank venting, filters , air in system etc
Oct 05, 2016 | Mitsubishi Cars & Trucks
Has thrown 2 codes out on autozones code reader P0341: CAMSHAFT POSITION SENSOR CIRCUIT RANGE/PERFORMANCE P0301: CYLINDER NUMBER 1 MISFIRE DETECTED
code p 0341 refers to camshaft position sensor (CMP) sensor A bank 1--range /performance problem=== causes --insecure sensor/ rotor --- air gap--- wiring ---CMP sensor
you will have 2 camshaft position sensors ( one for each cam shaft but they should be the same unit
the sensor receives an impulse from the rotor on the cam shaft and that impulse has to be within the set parameters in the ECM
the air gap is critical to that impulse
Sep 10, 2016 | Cars & Trucks
Polar 115EM,1987 guillotine
The machine may not handle compressed board well. If it works well with othe stock, the answer may be to stop trying to cut it. I know with my manual paper cutters some material does not cut well.
Nov 15, 2013 | Kitchen Appliances - Others
Clamp is stuck in the down position on Ideal guillotine 7228A
hi my dear friends
i have one cutter ideal 7228A
but my machine panel is broken and don’t working
please help me thanks a lot
Feb 01, 2013 | Cars & Trucks
Safety bolt locked on polar guillotine
Bolt locks are pretty cheap and don't usually cost more than $10. You can get a new one.
Nov 14, 2012 | Cars & Trucks
Polar 78x how to wind knife up manually
HOW TO FIX COME ERROR LIKE THIS
WARNING ! KNIFE AFTERRUN (703)
MACHINE POLAR 78X
KINDLY ASSIST ME
Aug 11, 2011 | Office Equipment & Supplies
46 people viewed this question
k24674
jasbo
jasbo
