Question about Motorola Mobility RAZR V3
Motorola V3 Facia Replacement
Is it hard to replace the facia (key pad panel) on the V3. Some "dealers and traders are quoting me ridiculous prices to fit a new key pad to my black v3. LIKE £25 & £30 "PACKAGES" this can't be right.
    Brigadier General:
  • 7,752 Answers
Take the phone to mobile service center and have them replace it for you.
Posted on Apr 15, 2008
Disassemble Miele fascia panel and control
There' s three reasons I can think of for removing a facia plate.
1- replacing a damaged original
2- accessing the control module
3-changing the language
On older models you may have to unplug the unit and remove the top to access screws that hold the facia housing. Then remove the housing to access the facia.
On newer models the screws were placed under the facia so the techs' don't have to remove the top.
Use a plastic paint scraper thin enough to get in between the facia and the housing. Pick a spot along the top or bottom and push straight into the gap. You can only go in about 1 mm until you stop. While still holding pressure inward pry the tool's back end away from the facia - up if your in the top edge or down if your in the bottom edge, until you access the inner step of the housing. Once your tool slips past the step, slide the tool left or right to find the locking tabs and pop them open. The facia will bend a bit. Watch that you don't drop it or it may scratch. The first is the hardest so be vigilant.
If you bought a new Miele Facia panel you should call their customer service support team. That's what they are for. They will be glad to guide you by telephone.
If your just curious to see what's underneath don't bother, unless you like looking at mounting screws for the plastic housing.
Nov 07, 2014 | Washing Machines
What is the cost of nokia 2730 facia ?
The approximate rate is $7.14 as on 04/05/12.
May 03, 2012 | Nokia 2730 Cell Phone
Error code F2EO
Hello Marie,
The F2EO error code means that button on the keypad has shorted out and the keypad(touchpad) needs to be replaced.
Nov 06, 2011 | KitchenAid KGSA906PSS Gas Kitchen Range
Detachable face does not work.
Unfortunatley, detachable facias do fail from time to time.
The important thing is to ensure the facia is locking "tightly" to the head unit and making good contact with the copper pins.
If your model facia is not the pin connection type, but has the ribbon cable, then the ribbon cables are easily relaceable (these were a common repair item).
If there is an internal issue with your facia, then have it checked for "dry joints" - this is where over time, a solder joint has dried up and not making proper contact.
Whichever repair is required, always price up a replacement facia first, as this is sometimes cheaper than paying someone to inspect and repair your faulty facia.
Jun 14, 2011 | Dual Electronics XDM6400 CD Player
How do you remove the front facia door of a Teknik integral dishwasher
I have just replaced the facia on mine. It is a TKD795/4 so I would imagine yours would be very similar. Around the inside of the door are 10 starhead screws; 4 along the top and 3 down each side. On mine it is the 2 end screws along the top and the 2 middle screws down the sides that hold the facia on. It is best to remove one screw at a time to establish which ones hold the facia on and which hold the door together. The short screws hold the door together and should be replaced and left in place. It is the longer screws that hold the facia on; these only need to be undone enough to release the facia panel. Once you have undone the relevant screws, the facia will lift up enabling you to release the 2 clips at the bottom. Replacement is reverse of removal. Hope this helps.
Feb 26, 2011 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Climatronic button facia
you carnt replace them they are part of the control head
Oct 23, 2008 | 1999 Volkswagen New Jetta
Fan Switch needs replacement
You can try to have access removing center facia panel
(then disconnect air temperature switch connector).
Aug 09, 2008 | 2000 Hyundai Sonata
How to change the housing on my Motorola KRZR k1
May 24, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
If you have the new facia cover it is easier than you think. Take a flathead screw driver and gently start lifting the facia up from the key pad.
May 23, 2008 | Nokia N73 Cellular Phone
Renewing Facia
Motorola V3's are not made to be taken apart. The best you can do is find your nearest cell phone accessory store and see if they carry face plates or "skins" for your phone.
But do yourself a favor and dont atempt to pull the phone apart ... You'll just wind up having to buy a new phone at an ugly price.
Dec 27, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
54 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
