Question about Ariens 54in Garden Tractor 25hp Kohler ES
Ariens 54" Hydrostatic 25hp Koehler won't crank
Replaced the battery and won't crank. No sound, no clicks, even tried to jump from my vehicle and nothing. Any help appreciated.
2 Suggested Answers
kevin_getz
  • 1031 Answers
SOURCE: 2 year old Ariens tractor won't start
It could be anything from a carb issue to a spark plug or bad fuel.
Posted on May 25, 2012
When I try to start my 60" Ariens rider all I get is a loud clattering sound. I just replaced the battery 2 months ago. What's wrong with my mower?
Joel, Recheck battery to make sure it has good charge >12 v and all battery and starter wiring,plugs,connections are clean,tight and undamaged. If you remove spark plug and engine spins freely from the key, the engine compression release or valve clearance needs adjusted. It is probable the solenoid or starter is faulty, the starter Bendix/drive may be sticking. If you can, give the starter a couple sharp raps with a hammer or bar and then try to start.
Check the attached links,instruction and guides to help diagnose starting issue. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://troybilt.custhelp.com/app/answers/detail/a_id/86/~/clicking-sound-while-attempting-to-key-start---riding-mower
What Are the Symptoms of Bad Starter Motor on Riding Mower Engine
My Bolens lawn tractor won start It just clicks when turn the key even...
Craftsman riding mower won start Just clicks the starter motor
Aug 27, 2016 | Ariens MaxZoom60 60" 25HP Kohler Zero Turn...
I can jump it off and it will crank but when I take the jumper cables off it goes dead. Would a blown fuse do this?
sounds like a short in your battery. even when your jumping it your still going through your cables. so I wouldn't think the fuse is bad. having jumpers on is like putting a good battery in yours.
Sep 15, 2013 | Husqvarna 25HP Hydrostatic 54"Cut Garden...
Car won't start without a jump but battery okay
wont crank or wont start.??
no car starts , if it cant crank. (unless push starter (M/T magic)
that is not a trans sensor its the PRN switch.
ill answer for, wont CRANK !
it wont crank even with a good battery (charged) or jump started.
1: bad start
2: bad wires to same.
so hot wire the starter small wire, the key start line is tiny.
cranks. , starter good, no crank starter bad or cables bad.
if it cranks hot wired, then the key line is dead.
easy, huh?
Feb 11, 2013 | Suzuki Forenza Cars & Trucks
Bad gas
drain tand at end of hose.remove and clean plug. crank engine so bad gas is out of cylinders.drain ard ob bommto bowl(unscrew lightly)i /2 can heet premium gas replace plug and mow
Oct 01, 2012 | Husqvarna 25HP Hydrostatic 54"Cut Garden...
May 24, 2012 | Ariens Garden
I have a husqvarna lgt2554 mower ... wont start, whines. Makes the whiney sound when I try to start it with the key or when I try to jump it by the solenoid. Does this mean its a bad starter??
It could well be the starter motor, but you need to check the gear on the end of the motor, it maybe the teeth half worn, this part will be a lot cheaper than changing the complete motor.
Mar 11, 2012 | Husqvarna 25HP Hydrostatic 54"Cut Garden...
No power when trying to start
No power as in it won't even crank over? Is the battery ok? Try jumping it or putting it on the battery charger. If that seems ok, maybe a bad connection at the battery post. Does it even click or try to do something.
Feb 11, 2012 | Cars & Trucks
My mower discharge when the blades are ingauge
The wires connected to your PTO are the key to your problem. The electric pto is designed to run off the engine charging system when it is engaged and will run your battery down if it isn't. The fact your battery will charge and hold a charge tells me it is probably ok. You will need a wiring diagram to figure this out. You might check outdoordistributors.com. They have pdf files that you can view online for most lawn tractors. Good luck Tim
May 31, 2011 | Husqvarna 25HP Hydrostatic 54"Cut Garden...
Trying to use my mower for the first time this season. Initiaaly the battery was low, but was able to jump start, but to late to finish the yard. Next day the machine cranks, fired initially for a...
Sounds to me you need to CHARGE the battery. How old is it? If it sits through the winter months & you don't charge it, it will not last very long. 3-4years is about par for the life of a battery and are pushing it after that.
Did you fill up with new gas? Perhaps you have condensation in Carb. bowl. Shut off fuel line. drop the fuel bowl and see if there is water droplets in the gas that is in the bowl.If this is all good , remove the air filter and spray carb. cleaner / starting fluid in carb.
May 02, 2011 | Troy Bilt 25HP VTwin Hydrostatic 50" Zero...
When I turn key on I get nothing. No lights , no engine hours, no nothing.
If the battery is fully charged you most likely have a blown main fuse. If you can't find it send me the model of the mower and I will try to assist you. Regards Phil.
Apr 26, 2011 | Husqvarna 25HP Hydrostatic 54"Cut Garden...
Ariens 54in Garden Tractor 25hp Kohler ES Logo
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Paul Sikkema
Paul Sikkema
Are you an Ariens Garden Expert? Answer questions, earn points and help others
