Question about Samsung RF26XAERS 26 Cu. ft. French Door Refrigerator - Stainless
Samsung RF26XAERS chute door stays open
How do I replace chute door. It's not closing
2 Suggested Answers
SOURCE: rs2556sh side by side samsung - fridge side door will not stay shut
i have the exact same problem. Let me know if you find a solution.
Posted on Jul 26, 2008
How do I open the front control panel of my Samsung side by side refrigerator?
I tried to reply on my question, when you asked, I don't think it worked. First of all it sounds like you have a bad control board, or you may have a loose connection. On back of the fridge is your main control board, I think its the first wire at the top to the right, if that wire is disconnected the door will open and close. When I was running some test, I took this wire off and it began to do this. As for taking the display off, simple, took a while to find this out but all you do is take the one screw out, grab the ice shoot and just give it a firm tug, it should pop right out. you have the hose attached and theirs a wire connected so be careful, but that all it takes.
Jun 06, 2015 | Samsung RSG307AARS Stainless Steel Side by...
Why is my Samsung RF26XAERS refrigerator repetitively chiming, and how can I fix it?
NOISE? from the fridge inside? or from the outside compressor? In overstressed compressor or low freon level will make weird noises? a bad fan in freezer will? Even seen bad ice makers make weird noises? if the ice making is hindered by obstructions?
Aug 20, 2014 | Samsung RF26XAERS 26 Cu. ft. French Door...
Rear passenger door won't stay closed
Door latch on door itself is in closed position if it will not close at all. In this case, open door and pull outside handle hard to pop open door latch. If you have door opening at random, door latch needs replacing or door catch on body is loose.
Jul 29, 2012 | 2003 Chevrolet TrailBlazer
Rs21fcns ice shute door not closing
That's normally the solinoid that is defective when the chute won't close which is above that door and is a pain in the a_ _ to repair so I would call a tech to handle that problem.
Sep 26, 2011 | Samsung Refrigerators
Only in the summer, frost forms in the freezer compartment of my side by side fridge. It is on the bottom of the ice compartment and on the dispenser chute. You would think it is the thermostat, but it...
most likely the ice chute door isn't fully closing,if you open the freezer door and look into the chute and see ANY light coming through the chutedoor is the problem
Jul 21, 2011 | Kenmore Side by Side Refrigerator
Ice build up in the dispenser chute
That means the ice door is not closing or its broken. When you look down the chute with the door open can you see the ice door closed? It can be a couple things that break in there to cause the door not to close. The only way to figure out what broke is to take it apart! You can put a small towel in the chute from the top to stop the frosting untill your ready to take it apart.
If this helps please rate me.. thank you..
Jun 27, 2011 | Amana Refrigerators
Door dhute not opening to let ice fall
on the right hand side of the door chute there is a little metal barrel that needs to be attached to the end of the arm that holds the ice door. this is attached to the spring that opens and closes the door chute.
Apr 16, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Ice dispenser chute
most flaps have a solinard that opens and closes the flap,if you can replace or get in there to lube it you should me ok,let me know more-mike
Sep 29, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice dispenser flap/door will not close properly
I have a similar problem. The repair guy took a look at it and stated everything is working and did not order any solenoid or any other parts. After he left the problem returned where ice comes down the chute it tends to lodge and keep the door open. I am disagreement with the repair guy and am leaning toward the idea that the spring has lost tension and is just too weak to close with any authority. There is a video on how to replace the spring on youtube. This is what I will be doing next weekend and will try to return to post results.
Jun 10, 2008 | GE Monogram® ZISS420DMSS Side by Side...
Samsung RF26XAERS 26 Cu. ft. French Door Refrigerator - Stainless Logo
46 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
