Question about Beko Wm1510w, Wm6142w, Wm6152w Washing Machine Inner Door Trim 2804930100
Wash programme wont start
Wash programme will not start lights come on and pump sound like it is going to start but drum not turning
2 Suggested Answers
  • 23 Answers
SOURCE: my beko washing machine wont start the programme all that happens is the start light just starts flashing
Hello
Hope this link helps you:
https://www.youtube.com/watch?v=8C4J3leArY0
Posted on Dec 02, 2014
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
Zanussi zwf1621s washing machine not working.
IT SOUNDS AS THOUGH THE MOTHER BOARD HAS SHORTED OUT OR YOUR DRUM HAS COME AWAY FROM ITS MOUNT
Dec 27, 2013 | Washing Machines
I have a Zanussi zwf1621s washing machine which is approx 6 yrs old. When spinning today it made a strange noise so i turned the machine off. When I went to restart the machine all the lights came on but...
it really depends on the sound it made, if it was a rumble or a screech it could be the motor, or grinding it could be the bearing or something is in the drum, if it was on a drain cycle it could be the pump or something in the pump blocking/catching on the fins in the pump ( hair can affect the pump). coins can sometimes get to the drum housing and cause damage, ie catch the heating element, this can make the washer not start as the washer has a earthing sensor on the element resistance. hope this helps.
Nov 06, 2017 | Zanussi ZWF1420W Front Load Washer
Hoover nextra washing machine door wont lock / cycle start
sounds like the door lock mechanism. if this cannot signal it has engaged, to the board, no other function will work (you don't want the washer going with the door open, trust me :) )
Nov 08, 2013 | Hoover Nextra 160 HNWF 3137 Front Load...
Indeset washing machine has stopped working. You select the programme the green light comes on but nothing happens. It in not filling up/ draining/ spining nothin, Can you help????
this may sound silly but just had the same problem changed the pump and it works fine now, if the pump does not work it wont let the washer start
Oct 18, 2010 | Indesit W 123 Front Load Washer
Haier HWc1460tve wont enter spin mode, water pump etc ok, drum turns but wont go faster than distribute speed for whole of spin programme
check the sensor that normally is attached to the motor. If it has come loose, speed becomes erattic .If good, suggest brush check as well.
Sep 08, 2010 | Haier Washing Machines
My LG 7kg wm10240f does not compete its cycle leaving the drum full of water and the temp and option lights flashing we then cant run any programme option, this has been a bit on and off is the programmer...
This might just be a an intermittent problem with the pump.When the pump starts to wear out it can pump out sometimes & sometimes not.The impellor in the pump can start making chattering sounds & not get goin.therefore not pump out.Worth repairing if it's just the pump.
May 29, 2010 | Washing Machines
Bosh washing machine won't do any programmes
If it fills then the next phase is to agitate.
To do that the motor must drive
Can you hear a whirring sound from the machine if you get close to it if so then the belt driving driving drum may have snapped.
If not then the motor brushes may have stuck or have worn out.
Does the machine programmer advance by itself or are you turning the dial
May 23, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Fills up ok,but wont wash,,has a humming sound.
Yes, you need to fit new brushes, if motor still does not go, then it is probably faulty.
Please rate my fixya solution.
Thanks.
Feb 04, 2009 | GE Washing Machines
Zanussi washing machine wont spin
check the drain hole when you start the machine if the water is coming back out , if yes that means your dump valve is bad.
Apr 23, 2008 | Zanussi ZWF1430W Front Load Washer
Beko Wm1510w, Wm6142w, Wm6152w Washing Machine Inner Door Trim 2804930100 Logo
23 people viewed this question
Top Beko Washing Machines Experts
micky dee
janman
Domenico Grillo
Are you a Beko Washing Machine Expert? Answer questions, earn points and help others
