Question about Coleman RoadTrip LX Grill 9941-765
Bypass regulator want to connect grill to easy connect propane connection on a 2013 fleetwood rv... double regulator situation... any ideas?
5 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: cannot conect regulator to small 16.4 oz propane tank
It must have some sort of packing spacer you need to remove from the hose to attach the tank. LOL
Posted on Apr 12, 2009
  • 34 Answers
SOURCE: need a propane regulator for my road trip grill
Try their web site and you chould be able to get one from there.
Posted on Apr 17, 2010
  • 2557 Answers
SOURCE: need pressure regulator for portable grill that
try national energy or propane company , home hardware,
Posted on May 16, 2010
  • 91 Answers
SOURCE: how do I connect the propane to the grill?
if it uses the little one pound green gas cylinders they normally push and click on the gas inlet and stay in place due to two small little metal pressure bands which release when you pull the gas cylinder back off. make sure its in the off position when you are putting it on. good luck.
Posted on May 30, 2010
Where can I find a replacement oring for the regulator end that screws into the grill
Your local propane supplier. They are made of a special material so that propane won't react with it.
Jul 12, 2014 | Coleman Roadtrip Grill LXE 9949-750
Hooked up proane tank used once then no flame on grill. There is propane in the tank but no propane flows out of it either when hooked up to the grill or when opening the valve directly on the tank. This...
The valve on the tank has an internal valve that will not allow you to release propane into the atmosphere. It must be connected to a regulator line in order to open.
It sounds like your regulator has failed. Remove the regulator assembly, inspect it carefully for blockage or hose kinks. If there none, try replacing the regulator assembly.
Gary
Sep 24, 2011 | Weber Genesis E-310 Gas Grill
Unable to get gas our of 'Blue Rhino" propane
The problem is an easy fix. Replace the current Hose/Regulator Assembly with a new one. They run about $30.00, at home centers and hardware stores that sell grills and accessories.
Once you install the new one and connect it to the gas tank, open the gas tank valve Very Very Slowly (Slow Motion, Slow) until it's fully open. If you don't do it this, the new regulator will lockup.
Hope this helps you & thanks for choosing FixYa.
Aug 25, 2011 | Weber Spirit? E-310 Propane Grill
My webber genesis 1000 has been loosing power the past few days (yes the tank is full) it will not warm up past 200 -250. any idea what may be the prob? thank you
If your grill runs on propane, it may be a failing regulator. Try replacing the regulator and hose, not very expensive and easy to do.
Jul 13, 2011 | Weber Genesis Silver B Grill
We converted our weber Q q120 so it would work off our RV propane tank. It has a very low flame. We took the regulator off the grill and are using quick connect and a 15 ft hose to the grill. Help?
Your RV Propane System works on a different pressure than your, gas grill. Reinstalling the regulator may correct the pressure difference. Then install a short pipe nipple into the regulator and install a shutoff valve. After the shutoff valve, reinstall your quick disconnect hose. from here on after, each time you connect the hose to the grill, be sure the shutoff valve is OFF before making the connection. Then open the shutoff valve very, very, slowly, so as not to lock up the regulator.
Hope this helped you. Please let me know. Happy Grilling!!
Jun 24, 2011 | Weber Q Grill
Connecting Reddy HD30 to RV Propane Tank
pipe feed could be too small poor flow of gas or flamesafety is cutting in
May 26, 2010 | Reddy HD30 Heater
Dual fuel thermos m#461262006 swicth back to propane
You can get the manual on the link below. Make sure you have the right regulator for the propane and not one for Natural Gas.
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0807110.pdf
Apr 28, 2010 | Thermos Stainless Steel Gas Grill
Can use gas for my liquid porpane grill
Yes you can as long as your home uses LPG. You can not use 2 regulators. If your outside line is after your home regulator you need to eliminate the regulator on your grill. LPG products operate on 11" of water column, that's about 1/2" PSI.
Thanks for using Fixya
Jerry
Mar 30, 2009 | Frigidaire FD26LPDC (LP) Grill
I have a Weber Gas Go-Anywhere Grill that I want to connect to a propane tap on my travel trailer. The problem is that the tap is low pressure, it's located after the regulator. the Go-Anywhere has a...
You can buy a "T" fitting that connects to the LP tank with a valve allowing you to pull LP gas off for your BBQ before the RV regulator
Most any RV shop can get them from NTP Distirbution
Jul 08, 2008 | Weber Gas Go-Anywhere Grill
Propane tank
yes, you need to buy an accessory cord that connects your tank to the regulator
Jul 03, 2008 | Coleman Roadtrip Grill LXE 9949-750
Coleman RoadTrip LX Grill 9941-765 Logo
29 people viewed this question
Top Coleman Grilling Experts
Dan Webster
Dan Webster
Paul Carew
Raymond Ramirez
Raymond Ramirez
Are you a Coleman Grilling Expert? Answer questions, earn points and help others
