Canon mx310 How to put a paper to this printer
  • 542 Answers
Check the manual page 11
Posted on May 09, 2013
Ajkill
  • 2035 Answers
SOURCE: printing a banner via canon mx310
  1. Access the printing preferences by opening the printer Properties / Preferences:
    For Windows Vista
    • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, Click 'Printers' directly from the 'Control Panel'.
    • Click your right mouse button on the listing for your printer, and then select 'Preferences' from the menu that appears.
    For Windows XP Home Edition
    • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.'
    For Windows XP Professional Edition
    • Click 'Start' from the bottom left of the Windows screen, and 'Printers and Faxes.'
    For Windows 2000/Me/98
    • Click / Select 'Start' from the bottom left of the Windows screen, and 'Settings,' then 'Printers.'
    • Click your right mouse button on the listing for your printer, and then select 'Properties' from the menu that appears.
  2. Click the Page Setup tab.
and select printing banner and then apply ok then start printing
Posted on Oct 12, 2008
SOURCE: Paper won't load on Canon MX310 printer
well, you should first know where the paper should go. (open the cover on the back) If the paper is in there and it is still not working, then it could be defective. Is it a new printer? If it is an old printer, try cleaning the rollers that grab the paper with a q-tip wit some alcohol on it.
Posted on Jan 07, 2009
  • 13433 Answers
SOURCE: i lost my cd to install canon mx310 printer to my computer
Hey,
you can get it from here
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=15603
Click on drivers and downloads
then select your windows version and download the files
install the printer
Let me know if you need anything else.
Thanks,
Ekse
Posted on Feb 17, 2009
  • 13433 Answers
SOURCE: my canon mx310 keeps showing a paper jam alarm and there is no paper jam. how do I fix it?
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Posted on Jun 12, 2009
dmbgo
  • 58 Answers
SOURCE: Canon Pixma MX310: misfeeds
Hi Paper misfeeds are normally caused by something obstructing the paper path. Look really carefully both above and below the path that the paper takes through the printer. The jammed paper itself can give you a clue about which side the obstruction is on, there wiil often be some sign, such as a bent corner on the page etc. Also check the sliding guides that keep the paper straight, they should be slid in until they are a snug fit with the paper, but not so tight that they stop it from feeding
Posted on Jun 21, 2009
Why does my Canon printer MX310 show paper jam when there is no paper jammed?
Hi
try switching printer off & on. If that doesn't work, check the paper path for stray bits of paper or another obstruction.
Sep 20, 2014 | Canon PIXMA MX310 All-In-One Printer
I'm trying to fax with my Canon MX310, do the fax papers I'm sending go up or down? thanks
Documents need to be face down if you put them on the glass or face up if you have an ADF (automatic document feeder) for single sided pages.
When you put the document on the glass line up the upper right corner of the page (as looking at the back of the paper) with the marker at the left back corner of the glass. If you are using the ADF, put the paper in such that the bottom of the page goes into the ADF first.
I hope this helps.
Sep 16, 2011 | Canon PIXMA MX310 All-In-One Printer
Hi Where do I load the paper in my Canon MX310?
The MX310 is a straight through printer. So you put the paper in the rear tray after opening it. Pull out the paper support and adjust the lever for the paper thickness to match your paper specifications. The lever goes to the left unless printing envelopes and T-shirt transfers. Also pull out the paper output tray and set the output tray extension.
Align the 4 corners of the paper stack (if loading more than one sheet) and bend to uncurl the paper (if needed) before inserting in the rear tray. For photo paper and other pages with a print side and a back, place the pages with the print side facing up. Align the paper against the right side of the rear tray and then pinch the paper guide and slide it to the left side of the paper stack. Make sure to adjust the paper size to match in the computer's printer properties (paper size) or in the copy settings on the all-in-one before either printing or copying.
Specific directions and pictures are in the Quick Start Guide that is available as a PDF here: http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx310#BrochuresAndManuals .
I hope this helps.
Dec 10, 2010 | Canon PIXMA MX310 All-In-One Printer
How do i load the paper in to canon mx310
Please follow you printer userguide.If you are have no user guide then download www.canon printer support.com
Sep 07, 2009 | Canon PIXMA MX310 All-In-One Printer
Paper feeder isnt ligned up in the middle canon mx310
There is some kind of mechanical lock on it. Push, Pull, Tip or Slide to correct position. It is only plastig. Look under and behind it to figure it out.
Mar 26, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon mx310 feeds paper w/out printing
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 09, 2009 | Canon PIXMA MX310 All-In-One Printer
Jan 05, 2009 | Canon PIXMA MX310 All-In-One Printer
Printer problem
My Canon MX310 doesn't like recycled ink cartridges, but doesn't do this.
Rjams
Jun 18, 2008 | Canon PIXMA MX310 All-In-One Printer
Where do i put the paper on a PIXMA MX310?
Go to this link. Type "how to load paper" in the Search box and click Search. Now click on the "How do I load the paper?" link, and you will get specific, illustrated instructions for loading paper.
Jun 10, 2008 | Canon PIXMA MX310 All-In-One Printer
65 people viewed this question
jasbo
jasbo
