Question about Panasonic SC-PM28 CD Shelf System
Hi sir /mad i really have a problem,and it about my panasonic CD stereo system,the model number is (SA-AK37) and the serial number is (DT9J027082) and this system was manufatured in matsushita electric industrial,made in singapore,well the sound IC has been remove from the system board and i cant get the part number for the IC that has been remove from the board so please i want you to help out,so that i can get the part number which i can be able to fix it on the board the system wattage is 140w ....thank your sincelly sampson kofi obiri
5 Suggested Answers
  • 82 Answers
SOURCE: F-61 error,dead panasonic model#sa-ak78
Have you changed the Regulator IC? Also check the IC protector next to regulator, it looks like a fusable resistor.
Posted on Dec 05, 2007
  • 82 Answers
SOURCE: F61 Error Code Panasonic SA-AK500 Audio w/ CD Exchange
The output IC may be defective. Part number RSN35H2-P.
Posted on Mar 23, 2008
SOURCE: error f-61 on SA-AK640
F61 Power Amp IC output abnormal
Upon power on,
DCDET=L after checking
For power.
Press [STOP] on main unit for
next error.
Posted on Oct 20, 2008
SOURCE: my cd stereo system sa-ak630 wont come of demo mode what do i do
there is a button on the left side that says "-demo" on it. hold that button until it stops...
Posted on Jun 14, 2009
  • 12 Answers
SOURCE: I got panasonic- sa-ak240 stereo
You may have the same problem as I had..broken solder joints on power amp board..namely the power relay.
Posted on Nov 21, 2011
0 characters
1 Points
My Panasonic stereo SA-VK850 won't open cd draws, all the top right side buttons won't work, and no front display,The t/deck works and so does the music port but no display.
That, sir, is one sick puppy you have there. Not cost effective to have repaired given the price of new electronics these days. Continue to use like it is or .............................
Sep 05, 2015 | Panasonic Audio Shelf Systems
I need owners manual for Panasonic CD Stereo system SA-PM12
The Panasonic website might have a free PDF of it.
Feb 02, 2012 | Audio Shelf Systems
I require a user manual for a panasonic SA AK 750 stereo system
Hi pjwivell ..
Are you sure that it SA AK 750?
well here is a here for SC AK750
download the manual and try if it works for you..
please give me update if you had any success... thanks
Jun 27, 2011 | Audio Shelf Systems
F61 cd stereo system SA-AK640
F61 is an Error Code,more specifically a Fault in the Power Amp,the Stereo will need to be sent into Panasonic for Repairs.
Jan 09, 2011 | Panasonic SC-AK640 Shelf System
Panasonic cd stereo system sa-ak100
my remote control don't work. I thank it's the remote control signal sensor. what should I do.
Jun 20, 2009 | Panasonic SC-AK100 CD Shelf System
Panasonic SA VK550 - F61 eror
Hi, i had the same problem with a panasonic player, when you see the code F61 in the screen it is because the audio output IC is defective,change that and the set will work perfectly. hope it work.
Feb 05, 2008 | Panasonic SC-AK33 CD Shelf System
Nide code fore a panasonic cd stereo sistem
Most likely the regulator IC is defective. Part # C5BA00000105.
Jan 15, 2008 | Panasonic SC-AK600 CD Shelf System
Panasonic SC-PM28 CD Shelf System Logo
47 people viewed this question
Top Panasonic Audio Shelf Systems Experts
Jonathon summesfield
Are you a Panasonic Audio Shelf System Expert? Answer questions, earn points and help others
