Question about Samsung HT-X20 Home Cinema 600W Theater System
Protection Mode in Aux
My Samsung HT-E330 keeps going to protection mode, while using the AUX function, all other functions work normally. I took it back to the shop where I bought it and had it checked, but they didn't find anything. The saddest part is that I bought it about two weeks ago, which means it's broken from the start. What should I do?
5 Suggested Answers
  • 4 Answers
SOURCE: Problem with SAMSUNG HT-X20!!
The fan is going bad and when u play dvd's the spining of the cd is acting as a fan witch is why they play longer then any other mode i had the same problem 2 times the second time samsung wanted 160$!!! thats bull because it keeps going out so what u do is open the case and remove the cover over all the capaciters and whatnot and replace that fan in the back then cut a hole in the top of the metal case directly about the cap's that warm up and install a aditional fan to act as a chimney a little noisy but i did this and the player had been runing in aux and radio mode for a few days stright now no problems at all it's alot of work and skill but for 2 5-15 dolar fans sure beats the 160 for repair or buying a new recever!
Posted on May 24, 2009
  • 56 Answers
SOURCE: dvd turns off after displaying ''protection''
protection error message means that your unit's fan is not working
it is a feature to keep your unit from overheating
check if there is anything blocking the fan of your unit from rotation or replace the fan
Posted on Jul 02, 2009
  • 18 Answers
SOURCE: After 20-30 minutes work in the USB or AUX mode,
  • make sure the speakers are plugged in correctly
  • if you tried that already check if your system gets hot when it turns off
  • maybe you need more ventalation on your system...
Posted on Jan 17, 2010
dunnbiker
  • 8546 Answers
SOURCE: My HT-X20 keeps on going
Suspect heat.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Sep 01, 2011
Power problem
If the protect function works but is causing you problems, cancelling the protection function should help, and it will be possible to enter the self-diagnostic function mode. This should disable all functions of the protection mode, excluding the 'excess electrical current detection' feature.
While pressing the "Tone Control" and "Info" keys, try pressing the power key to turn on the power. Keep pressing those 2 keys for 3 seconds longer.
this should activate the Self Diagnostic function, with your Protection Mode disabled.
in this mode the 'sleep' section on the tv's fluorescent display flashes to indicate that the mode is properly activated.
just be very aware, this function is normally there as a safety feature and i cant guarantee that disabling it altogether won't cause other problems down the road. best of luck!
Jun 06, 2014 | Yamaha Audio Players & Recorders
What's your problem?powerprotection mode unlock
If the protect function works and causes hindrance to trouble shoot, cancel the protection function as described below, and it will be possible to enter the self-diagnostic function mode. (The protection functions other than the excess current dtect function will be disabled.)
While pressing the "Tone Control" and "Info" keys, press the "Power" key to turn on the power and keep pressing those 2 keys for 3 seconds longer.
The seld-diagnostic function mode is activated with the protection functions disabled.
In this mode, the "Sleep" segment of the Flourescent Display flashes to indicate that the mode is self-diagnostic function mode with the protection functions disabled.
Caution!!!! Usiong this product with the protection function disabled may cause further damage to your unit, so use special care when using this mode.
Apr 18, 2012 | Yamaha RX-V671 7 Channel AV Receiver -...
Pluged samsung HT-D6750w speaks into pioneer vsx-520 amp and no sound is coming out
Please check the mode you selected or some call it FUNCTION.There are many jacks in ur amp such as Phono Tuner AUX in and so on.IF you have connected the player out to Aux in ,u must select Aux in the Amp.And check the cables used.
Sep 15, 2011 | Audio Players & Recorders
I have a Pioneer DEH-P5200 and i plugged the aux chords in the back to my ipod but dont know how to switch to the aux mode on radio...
OK - had the same problem and got it finally figured out. Power the unit on the ignition key. Press and hold the source button so the unit shuts off. With the unit shut off press and hold the function button (the key is to hold the function button down) The clock, aux etc will show on the screen. Press (but do not hold) the function button and it will move to each function. When you get to the AUX press the ^ button and the will switch the AUX to "on". Once you know, like everything else, it's pretty easy.
Nov 29, 2010 | Pioneer DEH-P5200 CD Player
After 20-30 minutes work in the USB or AUX mode, the unit turns off. At display panel says PROTECTION. After that this problem (when I turn on) repeats after 3-5 minutes.
Jan 16, 2010 | Samsung HT-X20 Home Cinema 600W Theater...
Dvd turns off after displaying ''protection''
May 29, 2009 | Samsung Audio Players & Recorders
No sound thru surround sound system in TV Mode
You need to connect your TV to the AUX connection in the back of your HT system. Then set your HT system on AUX 1 and wait about 5 seconds for the TV sound to come through. If it does not work on AUX 1, you may have to try on AUX 2 or AUX 3 settings on your HT system. Make sure the A/V cable you use is good and in working order and is a good quality cable.
Hope that helps, Gary
Jan 30, 2009 | Samsung HTZ-510 Theater System
Nov 11, 2008 | Samsung HT-X20 Home Cinema 600W Theater...
Samsung HT-X20 Home Cinema 600W Theater System Logo
115 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
