Question about Garden
MDT model 13as695g372 w/18.5 hp - Garden
Pto want start on a mdt tractor
jump it with stronger battery from car
Aug 17, 2014 | Garden
MDT Tiller starts and runs but tines won't turn
-Won out drive or driven gears.
Good luck
Mai
Jun 28, 2014 | Mantis 2-Cycle Tiller
Drops ice without being called for
Is the machine dispensing ice just after the cup is removed in front of the hands free sensors? If so then you need to add MDT portion controlled dispensing kit. A time - delay relay kit is now available for addition to the MDT3,MDT4, MDT5 and MDT6. The purpose of the kit is to limit the amount of ice dispensed per activation. The kit number is KPC-MDT. The kit includes a time delay relay and potentiometer. When the touch-free dispense system is activated, the time relay powers the dispense motor and / or door solenoid for a limited time. That time is adjustable to accommodate the cup or glass being used. a typical application for the kit is a high volume dispense situation where the amount of ice spilled is unacceptable. Spilled ice is usually caused by overfilling the container during dispensing,followed by the extra ice being dumped into the units drip tray.Adding the kit allows the amount of ice per per dispense to be set to match the amount an individual needs,so there is less waste. This is especially helpful on the MDT6, which is a high volume,rapid dispensing model. Now if the machine is just dumping ice when no one is around it, then replace the hands free sensor.
Apr 14, 2014 | Scotsman MDT5N40A-1H 523 Lb Touchfree...
I need a manual for device
here is the operator manual for the MC8 hydroclave:
file:///C:/Users/212035112/Desktop/harvey_hydroclv_mc__8_10_user_man.pdf
Apr 06, 2014 | MDT Harvey Hydroclave SC8
Harvey Autoclave Hydroclave Mc8 "reservoir low message"
need to clean your screens and filters.. also clean out your chamber and pay attention to the sensors there...
Feb 19, 2014 | MDT Harvey Hydroclave SC8
Mdt model 13an772g
check the drive belt
Aug 31, 2013 | Mtd Garden
I have an 18"hp MDT
Hi, there are two safety switches on your mower, one on the seat and one on the reverse position of the gear lever. One of these will be shorted and faulty. Locate these switches and bypass them one at a time by removing the wires from the spade connectors until your mower runs with the blades engaged. Then replace the faulty switch. Hope this helps, regards Phil.
May 22, 2011 | Garden
I have purchased an ASUS ASUS P5K SE Motherboard. I want to run a MDT RAM at 667 Mhz DDR2, is it possible as it says nothing in the asus website The ASUS P5K SE Motherboard Qualified Vendors List (QVL)...
"The Asus P5K SE Motherboard Qualified Vendors List (QVL) says that it only runs ram at 1066MHz and MDT is not on the list"
Really? I beg to differ.
The motherboard manual states,
" The chipset officially supports the memory frequency up to DDR2 800MHz. Tuned by the Asus Super Memspeed Technology, this motherboard natively supports up to DDR2 1066MHz."
1) Notice the 'Up To'.
Supports UP TO 800MHz, and with the SMT it supports UP TO 1066MegaHertz.
It will support DDR2 at 667MHz, 800MHz, and 1066MHz (With SMT)
The QVL doesn't encompass all ram memory that is available out there.
The Ram Memory used has to be;
A) Unbuffered
B) DRAM chips used cannot be any larger than 64MB
[DRAM chip.
http://en.wikipedia.org/wiki/File:Generic_DDR_Memory_%28Xytram%29.jpg
The Black rectangular chips, shown on the module of DDR Sdram example above, are DRAM chips.
http://en.wikipedia.org/wiki/DRAM
C) Should follow the JEDEC standard for DDR2 Sdram.
For one, it should follow the JEDEC standard for DDR2 voltage.
1.8 Volts.
Some high performance ram is set to use a slightly higher voltage. The Asus motherboard is set to use DDR2 at 1.8 Volts by default. (Factory settings=Default)
The MDT DDR2 at 667MHz is not high performance ram memory. It will be set to use 1.8 Volts.
Asus Support>Downloads,
http://support.asus.com/download/download.aspx?SLanguage=en-us
Up to the Left side of the page is the heading - Download, in white.
Under it is the - Input Model to Search, box.
Put your mouse cursor in the box, leave it there.
Left-click once.
Type - P5K SE
Go to the Select Category box below it, and left-click on the down arrow, on the right side of the box.
In the drop down list click on - Manual
Now click on - Search info, below it.
Left-click on the blue P5K SE to the left.
Choose the Operating System. Left-click on the down arrow on the right side of the box. I chose Windows XP in the drop down list..
It doesn't matter.
Left-click on Search below.
Now scroll the next page down to Version E3202
Left-click on Global (DLM)
In the security box that pops up, make sure you use capital letters for the letters shown.
Left-click on Submit.
It's a PDF file download. Make take up to 30 seconds before you see the first page. May also take time to fully download. Advise letting it download before looking through it.
I posted the link so that if you have a motherboard manual, and it does not have the information this one has, then you now have the official Asus version.
Ram Memory information starts on Page 37.
Page 40 shows the QVL for DDR2 at 800MHz.
Page 41 shows the QVL for DDR2 at 667MHz.
This QVL does not list MDT either.
It's okay, it will work. The MDT ram memory has SPD support.
[Serial Presense Detect
http://en.wikipedia.org/wiki/Serial_presence_detect
Maximum Total Amount of ram memory is 8GB. You better have an O/S that will recognize 8GB, however, to realize this.
Has to be a 64bit O/S. (Operating System)
Windows XP Home, and Pro that are 32bit versions, will only recognize 3.2 to 3.5GB of ram memory.
Maximum Amount for EACH ram slot is 2GB.
If you only install one ram memory module, make sure it is in Slot 1. (DIMM A1 on that motherboard. The ram memory slot that is closest to the Processor)
350 Watt PSU? Not planning on gaming I see.
Depends on what PSU you have (Power Supply Unit), but it could be old enough to be just putting out 70 percent, of the maximum rated wattage.
245 Watts.
Continued in an additional Comment
Jun 07, 2010 | Computers & Internet
Garden Logo
35 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
