Question about Home
Outdoor motion sensor
I asked question few weeks ago about motion sensor keeps turning on and off every few minutes,tried everything including sens and lux, nothing in way, i wired it up with same colors, i even bought two one better than other but still same,at start when i first installed sensor it was working fine.
    Problem Solver:
  • 11 Answers
Try checking the timer setting, father in law had this problem with his and that was the solution.
Posted on Sep 14, 2013
I have a 180 degree Defiant Outdoor Motion Security Light. It was working fine for 2 weeks, but now it stays on all the time. I've tried toggling it to Test and then back to 1 Minute and no change.
I am having the same problem. The manual says to avoid plugging into the same circuit as motors & fluorescent lights. Mine is on the same circuit as a freezer. I'm going to try changing the AC outlet to see if that helps. Good luck!
Sep 05, 2014 | Defiant Flood Lights. 180 Degree Outdoor...
Why did my motion light stop working and the sensor light is blinking red?
Did you find out why?? I just purchased 2 of these and loved them as they worked for like a week and now both are not working however they are getting power as the red light comes on when there is motion...Please help if you know as I paid 110.00 each for these and I am confused how the bulbs could be blown?
Jun 02, 2014 | Defiant Flood Lights. 180 Degree Outdoor...
I want to replace my existing single bulb porch light with a 2 bulb motion activated light. It would be operated with the existing switch. Is this ok to do?
Yes. Must keep switch turned ON.
Outdoor lights will only come on when motion is detected, otherwise light bulb does not come on. So the indoor wall switch does not work as override since the motion sensor takes over as the sole switch.
Copy following link for wiring illustrations:
http://waterheatertimer.org/How-to-wire-occupancy-switch.html#motion
Other solutions include adding separate motion sensor light nearby and keep porch light so you can turn on-off when desired.
Another option is to add photocell to outdoor light so it turns on automatically at dusk.
Another option is to use outdoor yard timer with dawn-dusk capability:
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
Another option is to replace indoor wall switch with with dawn-dusk timer, that can also be used as ordinary on-off switch so you can turn porch light on-off when desired. Timer such as Intermatic ST01C offers simple 2-wire connection.:
http://waterheatertimer.org/ST01C-program.html
Gene
h
Aug 18, 2013 | Electrical Supplies
User manual for fl09sbk light
It appears this device is rate 10 amps at 230 volts = 2300 watts.
Use at least #14 wire and 15 amp breaker.
Connect wire at connection point on light.
Unit appears to have a transformer, and might make humming sound.
There is override located somewhere on unit. Possibly as a button on the motion sensor
If infrared motion detector requires separate wiring connection, then use following wiring illustration:
http://waterheatertimer.org/images/How-to-wire-motion-sensor-230V.jpg
Motion sensor will probably have 2 settings.
1st setting for sensitivity, so it will not activate when cat walks up driveway.
2nd setting for time duration, selectable from 30 seconds to 7 minutes
ML FL09SBK IP44 36W Fluorescent PIR Floodlight c/w Lamp
IP44 Low Energy Floodlight c/w PIR & Override.
Black finish.
T4 twist and lock lampholder.
36 Watt 6500k T4 spiral compact fluorescent lamp included.
(replacement lamp - product code FL09L).
Electrical termination via 10 Amp connector block within secure enclosure c/w cord grip.
PIR detection range of 12 meters at 2 meter height from ground.
Detection arch of 160 degrees.
Time range 30 seconds to 7 minutes.
Manual override.
Nov 12, 2012 | Woods Outdoor Lighting Timer
LED motion sensor lamp, after installed, does not turn off, it is on all day long
usually motion sensor led lamp is a little different from general led lamp. the work condition will shift from general lighting to motion sensor light. The reason why installed, but can not turn off, might you install in the wrong way. You can see the installation details Pir Sensor Led Tube 4ft f328a61c-a223-4610-b54f-1ba4836154f7.jpg
May 28, 2012 | Home Security
1990 trooper 2.8L V6 Gasoline starts hard if at all,fires then backfires then runs a few sec then dies
Have you cleaned the throttle valve and the air bypass idle speed control valve? If not do that. When they get really gummed up from backwash from the combustion process they cause this problem of stall on cold start.
Mar 16, 2017 | 1990 Isuzu Trooper
About 2-3 weeks ago mouse went couldn't use, then the key board went out about a week ago. Shut down the computer, turn comp. off from back then upluged. after check to make sure everything was still...
Impossible to diagnose remotely. You need to try things like switching the computer off at the mains for a few minutes. If I had the computer I would try a different PSU.
Oct 22, 2017 | Biostar M7VIZ Motherboard
Won't spin the disk
try this link! http://www.techsupportforum.com/gaming-forum/console-gaming-support/77719-ps2-disc-wont-spin.html
Apr 02, 2007 | Sony PlayStation 2 Slimline Console
Home Logo
134 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
