SOURCE: Washer continuously fills but drains at the same time during rinse cycle.
you have the drain pipe too low into tthe house drain pipe, raise the washers drain pipe up , you only need four inches down into the hous drain
also the house drain pipe needs to be as high as the lid of the machine before you put the washer drain tube into the house drain
you have a syphoning effect
SOURCE: lg wm2277h has low water level
The water level is very low on front load machines. (Below the bottom of the door) While the washer is running, push and hold the "spin speed" and "soil level" buttons at the time. Display should be between 230 and 255.(normal) If you do this while the machine is filling, you will see the numbers change. This machine only uses about 12 gallons of water for an entire cycle, vs. about 45 for some top loading machines. THIS IS NORMAL ! The machine will adjust the amount of water based on the type and volume of clothes in your washer. On a large load, you will see wet clothes, but no water sloshing around. PS. Because the machine uses so little water, make sure you use only one tablespoon of HE detergent (and only one teaspoon of fabric softner if you use it). This is very important.
If this info was helpful, please rate it as a "FixYa". Thanks.
SOURCE: LG Tromm WM2277HW Water level to low
this is normal the pic are all photo shop water you clothes are clean right?
SOURCE: water running out when washing machine is filling?
Hi jojolevaokah
Water siphoning out the drain line
If the water is
continues to fill and water is draining while it is filling or
agitating, Check the height of the stand pipe. It should be about 36"
above the floor. If the height is correct it may need to have an
anti-siphoning valve installed into the drain line.
SOURCE: My washing machine is SANYO ASW-90WRTP. showes E4
Check on the machine there is a schamatic and it has error codes on it. it may be on the in side panel.
Testimonial: "cool thanks for that just empty the tub then will check for skidmatics"
