How do I remove the brush roll
SOURCE: Bissell Momentum roller brush doesn't roll w/ pressure
This is going to sound funny, but check the wheels. Sounds like the pin or shaft that holds them is broke. Also check the tension on your belt. If the tension is to loose then the brush will have a hard time spinning.Good luck
SOURCE: will not cyclone any more. brush on botton will
That means that you need to replace the belt. Here is a link to the belt you need and a manual you can view with instructions:
Bissell Pet Hair Eraser Belts and Manual
SOURCE: Info on how to operate a Bissell Turbo Brush Model 7901-P.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
345erw
SOURCE: The floor brush will not
I recently had a similar problem where the vacuum would turn on but the brush would not rotate. I could hear the motor turn on and the belt was in tact, but the brushes would not turn. I took out the brushroll and it would not turn by hand either. There is a white cap on one end of the roll and a black one on the other. Use a hammer and a punch (or sturdy screwdriver) on the metal rod from the white end to knock the metal rod out of the roll. There is a bearing and wave washer on each end. I cleaned all of the hair and gunk out of both bearings and it rotated much better. I actually bought a couple of new bearings (trade # 608 - same size as what's in rollerblades) and lightly sanded the surfaces where the roll and caps meet so I hopefully won't have to do this again for a while. I heard of people putting WD-40 on the rims of the caps, but I wouldn't recommend this because I don't think the plastic would react well to it. Hope this helps.
