2000 lx470 when i put the key in to start,the key goes all around.doesnot say or do anything.
The ignition crank shaft is broken inside the Steering Column Lock Assy. You will need to buy a new assy (cost appr. $202.21) and 2 steering lock bolts (cost appr. $4.96 ea) at a Toyota or Lexus dealer. Call either dealer for best price and availability. To replace you'll need to remove the black snap-on panel below speedometer then remove the screws securing the driver side dash. Behind the dash is a steel plate. Remove that and remove the steering column covers by turning the steering wheel to access the screws. You'll see that the SCLA is secured by 2 break-away bolt (this is an anti-theft feature). Use a dremel tool with cutting disc to make a notch in the screw head to remove with a flathead screwdriver. If this doesn't work your other option is to cut the bolts where the assy bolts together. Remove the broken SCLA and remove the key FOB and install into new SCLA. If your mechanically incline this should take about 2-3 hrs. and save you $300-400 in labor cost.
Part numbers are same at Toyota and Lexus dealers.
Steering Column Lock Assy: 45280-60510
Steering Lock Bolt: 45897-12020 (need qty. 2)
Ignition switch is bad needs to be replaced
