Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Top Burner Ignitors
How do you change/replace the top burner ignitors?
    President:
  • 331 Answers
Remove the burner grates. Remove the caps off of the burners. You'll see three screws on each burner, remove these and lift the burner heads out. Now you can lift the cook top up (like lifting the hood on a car) and have access to the wiring for the igniters. The part number you need is #WB13K10003. These are kinda pricey at ~$42.00 ea. at your local appliance parts retailer.
Posted on Aug 12, 2007
New ignitors in Viking range oven do not heat up
You will need to measure for 110 VAC at the control switch located on the thermostat. Pleazer Appliance...
Apr 15, 2014 | Viking Kitchen Ranges
I have a Whirlpool Super Capacity 465 Gas Range. However all the burners on top will not click to ignite. I turned the breaker off and that back on again and it worked for a day or two. Now nothing will...
Power for the ignitors goes straight from the input power to the burner switches then on to the ignition module. The burner switches are in series parallel. Any one of them actuated will provide power to the ignition module.
See the schematic in this pdf file page 22 but page labeled pg 20: https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/ca8e028c60d9804f85256a8c00621f04/$FILE/4322089.pdf
When the ANY burner control is turned on all 4 ignitors do cycle.
Does the oven burner light? If not you most likely have a bad ignition control unit. Item 35 this link: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=242126&diagram_id=32025#d32025
If the oven burner lights then you most likely have a wiring problem to the burner controls. There is ONE power lead that if it comes loose will cause all of the ignitors not to work.
You can use the https:// manual link above to gain access to the top of your oven. See page 15 of the .pdf file.
The igniton system is explained starting on page 19 of the pdf file.
Thanks for choosing FixYa.
Kelly
Aug 18, 2010 | Whirlpool Kitchen Ranges
Electronic ignitors won't stop clicking
Pull the burner caps, etc off the stove and completely dry the area ..Be sure to inspect each ignitor contact for cleanliness as well. If the ignitors have soapy buildup or water, around them, they can act like this.
You should be able to pull the burner caps and flame diffusers off and clean with a paper towel, and if needed, a light scouring sponge. Be careful not to scratch the surfaces, but scour the top of the ignitors carefully if you need to clean them.
Jul 31, 2010 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Viking gas stove top ignitors sparking incorrectly
all ignitors spark at the same time no matter which burner is turned on. If you are having trouble with one burner not lighting try cleaning around the ignitor with a small screw driver so the spark has a good path to ground.
Mar 19, 2010 | Viking Kitchen Ranges
Stove top burners won't light.
Susan, there is no pilot flame on the Spectra models of ranges. However, the possibility that the electronic ignitors have gotten soaked and are shorting out is quite likely.
You should disconnect the power to the oven and remove the burner grates, burner caps, and the burner assembly cores to expose the ignitor posts. Check to see if there is any remaining water there and clean off and dry the ignitors and burners completely, as they might have something on them causing them to short out against the stove top, rather than spark properly, as they should.
Once you've cleaned and replaced the stove top parts, restore power and try to light each burner, one at a time. If none of them spark or light, then you need to check to make sure you haven't tripped a breaker for the stove or a GFCI outlet that the outlet that the stove might be plugged into, somewhere in the Kitchen.
Hope you find this Very Helpful and best regards!
Sep 10, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
How do you light the pilot on a GE stove The top of the stove works
Hi, If this model has a standing pilot, use a lighter and put the flame to the back center next to the burner assembly. Most newer models have electric ignitors now. It is fastened to the burner assmbly on the laft side.
If this an electric ignitor, turn the oven on and see if the ignitor glows. These ignitors are a very common problem and will probavly need replaced.
Please let me know if I can assist youu further.
Vic
Jul 03, 2009 | GE JGRP17 Gas Single Oven
G.E Profile gas cook top #JGP640 ignitor.
It is sparking because the module does not sense the heat which would normally cause the sparking to stop.
It can be caused by a poor ground, make sure the ignitor at that burner is clean and free from any obstructions. If it is then it could either be a defective ignitor or spark module.
Mar 12, 2009 | GE Cooktops
Stove Top Ignition will not turn off
all ignitors lite thats the way the stove works thats a safty feature..but im thinking your question is they wont go off,,if thats the case replace spark module...if not im here onthejob
Dec 04, 2008 | Whirlpool SF367 Gas Kitchen Range
Top Burner Ignitors
This is real quite simple. You just grab the electrode top and pull up while twisting back and forth. Be careful to pull up slowly. It will pull out and then you can detach the wire by pulling off and reverse order to install new electrodes.
Aug 11, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
268 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
