Question about Skylink Group Ad433 - Skylink Voice Dialer
Where can i get a manual for Skylink Group Ad433 - Skylink Voice Dialer
  • 542 Answers
From the skylink website
Posted on May 09, 2013
Why doesn't it connect to sensors?
From your description, it seems that the transmitter section of SC-001 is working properly. What you have done to reinstall the system may not be thorough. And it is unclear whether the control panel is not responding to keychain transmitter or sensor or both.
I assume that you have followed the instructions in the manual to clear the zones. Simply unplugging the AC power and removing battery will not clear the zones. Note that sensors can be programmed into zones 1 to 4. Keychain transmitter can be programmed into zone 5 only. There is no LED indication for zone 5.
Secondly, follow the instructions to program the sensor or keychain transmitter to the control panel. The corresponding zone LED will be flashing during programming. There is sound indication as well for successful programming of the device.
If you do not program the sensor or keychain transmitter to the control panel after clearing the zones, the control panel will no longer respond to the device.
The dialer and siren is not cleared on the control panel. They can be cleared only from the dialer or siren itself.
Dec 11, 2015 | Skylink Group Skylink Sc-100 Security...
Skylink sc-100 goes off when i input pin
The question is unclear. There are several possible cause for the control panel to go off after entering the PIN.
The control panel gives user four chances to enter the correct password. After the forth wrong password entry, the control panel will go off.
There is a silent alert command in which the control panel will activate the dialer and/or external siren alarm but the control panel remains silent. This is useful under duress condition.
The control panel has a tamper switch. If the control panel is disarmed, it will be ignored. If the control panel clamshell is opened and then the system is armed, the alarm will go off. The tamper switch prevents the burglar's attempt to remove the internal backup battery to shut down the system.
Oct 09, 2013 | Skylink Group Skylink Sc-100 Security...
How do i reset the keypad
Refer to the answer of question, "If I take out the battery on my skylink sc-100 does it reset it back to factory settings."
Aug 23, 2013 | Skylink Group Skylink Sc-100 Security...
Cannot clear zone, how to factory reset SC-100 skylink
There is no factory reset for the zones. User must follow instructions in the manual to clear all the devices in a zone.
Search the manual for "ADVANCED PROGRAMMING". Then look for "TO CLEAR A ZONE". Follow the instructions to clear a zone. Note that zones 1, 2, 3, and 4 are for sensors and zone 5 is for remotes. Each zone can accommodate a maximum of six devices.
Each command can erase one zone. If more than one zone is to be erased, repeat the command for each zone.
Jul 26, 2012 | Skylink Group Skylink Sc-100 Security...
I guess the question is about the control panel SC-001.
If power is totally removed (disconnecting DC jack and removing battery) from the control panel, user settings will be restored to factory default. These include all passwords and zone settings. Master PIN will be reset to "000" and secondary PINs will be deleted. Home, Away, and Night sequence default zone setting can be found in the manual.
However, all programmed sensors and remote controls will remain intact. This means that all programmed sensors would still trigger the control panel if activated. And programmed remotes would still operate the control panel. To remove installed sensors or remotes, simply disconnecting power will not work. User must follow instructions in the manual to remove sensors or remotes from a zone.
Feb 19, 2011 | Skylink Group Skylink Sc-100 Security...
Setting garage door opener
You should be able to press the button on the receiver and then press the button on the remote if the batteries are good. The skylink group can be found at skylinkhome.com Thanks BB
Apr 21, 2010 | Skylink Group Skylink Door Window Sensor...
HTC Hero voice dialer does not recognize my
The Hero's voice dialer is a piece of ****. I would not use it at all. It defeats the purpose of voice dialing if you actually have to look at the phone to confirm who you want to dial.
I would see if there is another app that can do voice dialing that is better. I cannot give you any advice on that, since I don't use voice dialing.
Good luck.
Jan 29, 2010 | HTC Hero Smartphone
Skylink Group Ad433 - Skylink Voice Dialer Logo
83 people viewed this question
Top Skylink Group Home Security Experts
Lawrence Oravetz
Are you a Skylink Group Home Security Expert? Answer questions, earn points and help others
