Question about Compaq Presario 5005 (470014-507) PC Desktop
System Error 32 on my Desktop Computer
I was just starting up my computer when, in the middle of booting up, it said system error 32 up in the left hand corner of the screen. I tried everything I could think of to fix it, from re-installing windows xp on my computer to just restarting the computer. No matter what I did the computer just didn't get past it. Can anyone please help me?
    Problem Solver:
  • 5 Answers
If you have tried everything, including reloading Windows, look inside the case and check the capacitors on the motherboard. The motherboard is the main circuitboard, and the capacitors look like little batteries. There are usually 10-20 capacitors on a typical PC motherboard. A healthy capacitor has a very flat top, but a "popped" capacitor is bulged top and bottom. Sometimes there is even a bit of residue leaking from the bottom of the capacitor. If you have popped capacitors and you are not handy with a soldering iron, it may be best just to replace the PC (seriously). If you can handle a soldering iron, you may have luck replacing the popped capacitors. They only cost about $1 each, and they are easy to pick up from a place like www.digi-key.com.
Posted on Aug 12, 2007
How to Resolve System 32 Error in Windows Operating System?
System 32 error is the most common error which can halt the smooth work flow and make you feel dejected. Most of the people are still searching about "What is System 32 error?" why it happens? How does it affect? And what you can do to eliminate it? If you are also one of them then your search ends here, in this article I will let you know about the answers of all your questions regarding the System 32 error. I have looked up several forums, tech blogs and well renowned websites to collect the information.
System 32 is the one of the most important file hidden inside your computer which contains vital information required to function your computer properly. System 32 files generally located in the system drive C:\Windows\System32 in my PC (location on your computer can be different).
Causes of System 32 error:
Check for a corrupted Windows registry. The most common reason of System 32 error is the corrupted registry which can lead to computer freeze. The most common affected files are Config.nt, autorun.inf and svchost.exe etc.
Check for malware and other "nasties" on your computer. It can also be caused due to malwares which causes your computer to respond in undesired ways. Most of the malware enters your computer through spam mails and adware's.
Check for bad system files downloaded via the Internet. System 32 error can be triggered when you update your system files via internet. Some of the sites which promise to provide full version of software contain corrupted files or even are the Trojans which causes lethal damage by uploading virus on your computer.
Check for hardware issues. When you replace or add any hardware then it may be possible that it's not compatible to your existing computer setup which can create problem in the operating system. This can result in the System 32 error or you may hear different types of sounds during booting period of computer. 26319222-bxzhjmonsmllydp0qa2riq2g-2-14.jpg Check for faulty software update issues. Any software update of your computer can also lead to unwanted changes in the registry which inhibits your computer to function properly.
Oct 20, 2016 | Microsoft Computers & Internet
NON SYSTEM DISC ERROR HP 6545B
Check the bios has the correct boot sequence. First boot should be the bootable drive, usually drive C.
Jul 14, 2016 | HEWLETT-PACKARD Hewlett Packard HP ProBook...
When start system show error
Does the system boot up? This does not seem like an error that would stop it from booting up, just an annoyance.
Click Start/Programs and look for the RUNcommand. You might see it anywhere once you click Programs, or it might beinside the Accessories folder. Click RUN and when it opens up type"msconfig.exe" (without the quotes) then hit ok.
When the System Configuration window opens click the Startup tab. In theStartup Tab we are only concerned with 2 columns, the first column which is theStartup Items and the column that says Command. You can put your mouse pointerbetween two column headings and it will turn into a +, then hold the left mousebutton and drag the column over to the right to expand it so you can readwhat's below it.
Now everything has a check mark beside it. This means that everytime youstart your computer, these items have to load and run.
Start with the first item listed under the startup item column and look at itand look at the command for it. We want to find the command that your system is having a problem with the script file. The command is C:\WINDOWS\system32\FAantivirus.vbs. When you see it under the command column take the check mark off over to the left next to the item column and this will keep it from running the next time you boot your system.
May 07, 2012 | HP Desktop Computers - Hewlett-Packard...
Compaq desktop persario xp non-system disk or disk error
This means that the system identifies the hard drive on your computer as one that is not bootable, in other words, it does not contain any operating system, or it does contain one, but the disk format is not recognized by the system. For example, Windows operating systems only identify two types of disks and that is DYNAMIC or BASIC. If a Hard disk has an operating system and has been converted to DYNAMIC, you can not start any operating system on it. Only BASIC disks can be used to start an operating system. Here is a solution for you... Get a copy of the operating system you are using and boot the computer from it. Press F2 when booting and go to the system BIOS where you are going to configure the boot order or the boot sequence and make the CD drive the first booting device, so that the system can boot from the CD. If you receive a message stating that the SETUP can not find any hard disk installed.... then there must be a problem with the Hard disk format. Remove the hard disk and connect it to a desktop computer as a slave. This will enable you to see the Hard disk as a removable device on the 'My computer" menu.Go to start, right-click on "My computer" and select "Manage". This will take you into computer management console, then select "Disk management" and this will bring all the disks and drives connected to that computer and all their respective information. Click of the drive that you just connected and check on the bottom middle column, the type of the disk whether it is DYNAMIC or BASIC. If it is Dynamic, then you have to covert it back to basic. Make sure you make a data backup before you do this. This is because the system will delete anything on the hard drive. When you are done, take the hard drive back to your computer and boot from the CD again and install a new operating system. You should be good after this...
Mar 23, 2012 | HP Presario Computers & Internet
Turn on my computer Inspiron 530S starts to boot up gives the dell booting page then goes to 0 Diskette error choose F1 to continue and F2 to start setup. I have tried F2 and change it to no floppy disk...
Sounds like someone may have left a non-bootable floppy disk in the drive. Check to be sure there isn't a floppy in the drive. Also, when in setup, it's the boot order that you'll want to change.
Nov 27, 2010 | Dell Inspiron 530s Desktop Computer
Cannot sign on my computer getting message windows could not start following is missing or corrupt <windows root>\system 32\ ntoskrnt.exe. reinstall a copy i dont have any of the...
If computer does not boot into Windows, turn on the power and press f8 . On the Windows Advanced Boot Option screen, select one or more of the following options. Select them one at a time and press the enter key to attempt a system restart.
  • Disable automatic restart on system failure to view error messages.
  • Repair Your Computer allowsUninstall recently installed software programs Windows to run diagnostic tests.
  • Last Known Good Configuration (Advanced) to return settings to an earlier point in time.
  • Boot into Safe Mode and then Uninstall recently installed software programs . When in the computer is running in the Safe mode, click Start , Control Panel , and select the Uninstall a program option. When the computer is operating again, go to program manufacturer's web site for support information.
In Windows XP Click Start , All Programs , Accessories , System Tools , System Restore . Select a windows restore point from a time when the computer operated properly, and then restart the computer. hpweb_1-2_plus.gifhpweb_1-2_minus.gif In Windows Vista or Windows 7 Click Start, type restore in the search field, and select System Restore from the list. Select a windows restore point from a time when the computer operated properly, and then restart the computer. If the computer does not boot into Windows, you can restore the computer settings to an earlier point in time. Turn on the power and press f8 . On the Windows Advanced Boot Option screen, select Safe Mode and boot into Windows.
Nov 11, 2010 | HP Compaq Business Desktop d220 Microtower...
The computer screen is black, and their is a
if that is the case you might need to reinstall windows on your computer and see if that works.
Dec 27, 2009 | Microsoft Windows Vista Ultimate with SP1...
ERROR LAODING OPERATING system
Please boot in safe mode and uninstall the driver.
To boot inn safe mode:
- Start your computer
- Press F8 ( Just before it start booting into windows)
- Select safe mode
Apr 19, 2009 | Microsoft Windows XP Professional
Computer will not start
When Windows crashes with blue screen, it writes a system event 1001 or 1003 and a minidump to the folder \windows\minidump. Check system event 1001 and 1003 and it has the content of the blue screen
Event ID: 1001
Source: Save Dump
Description:
The computer has rebooted from a bugcheck.The bugcheck was : 0xc000000a (0xe1270188, 0x00000002, 0x00000000, 0x804032100).
Microsoft Windows..... A dump was saved in: .......
Event Source: System Error
Event Category: (102)
Event ID: 1003
Description:
Error code 1000007f, parameter1 0000000d, parameter2 00000000, parameter3 00000000, parameter4 00000000
Control Panel -> Adminstrative Tools -> Event Viewer -> System -> Event 1001/1003. Copy the content and paste it back here
Aug 17, 2008 | HP Compaq Presario SR1230NX (PJ518AA) PC...
My sony has systm error 32
Hi, Can you pls give some more info: System 32 error after POST before Windows or System 32 error, after windows partially booted? Offhand, if the error is after POST before Windows boot, it is a hardware problem based on motherboard built-in diagnostic program: you may have to check/repalce reseat/connect memory, video card, hard drive; If it is after Windows partially boots, then chances are it is a driver problem; try running in safe mode and check at which points it stops or hangs. Hope this give you some idea. Pls post/comment back if you need further information. Good luck and kind regards.
Aug 12, 2007 | Sony VAIO PCV-E518DS PC Desktop
Compaq Presario 5005 (470014-507) PC Desktop Logo
57 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
