Question about Cell Phones
How do i charge this device?
All I see is a tiny hole. is this where I charge it? if yes, where do I get a charger that small?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 20 Answers
Is there a Model number on this bluetooth, can't find RoHs....
At Walmart and Stores like that they have different chargers that have different charger ends pieces, you can try to see if any of the ends fit in the charger slot at the end of the bluetooth. Most of these universal chargers have end pieces hanging out of the package, so take your bluetooth and try different ends. Example but do not know if its the right one is:
http://www.walmart.com/ip/Northwest-Charger-Pro-All-in-One-Charging-Kit/22426335
Posted on May 09, 2013
Charger fot my acer tablet only goes half way in and wont charge
The pin inside the charger port might be broken.
Look in the hole where you put the USB (on the device) there should be a tiny flat tongue sitting in the middle, if it's bent and touching the inside of the hole, it will need repairing. It's a very common fault.
You might be able to temporarily fix it yourself by trying to straighten it with a tooth pick. It's supposed to slot inside the micro USB plug.
Oct 20, 2016 | Acer Tablets & eReaders
How can I change the battery in m9100 kocaso
Try the follow to see if it will fix it:
There is a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
If your tablet does not have the reset button: With the tablet plugged into the charger, hold the power button for 10 seconds then click the volume up once. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
After performing the power reset on the device the device will behave in one of the following ways:
1. The tablet will turn on like normal.
2. The tablet will show the battery icon only.
3. The tablet will show nothing on the screen at all.
All of these are normal for the device and should not be cause for alarm. If the device still fails to power on after being left on the charger for 4-6 hours,
Then most likely the battery will need replacing.
Here is a link to where you might be able to get a new battery:
Replacement 4000mah Battery for Kocaso M9100 M9000 9 MID All Winner A13...
Jan 23, 2015 | Kocaso M M9100 9-Inch 8 GB Tablet
HOW TO UNLOCK A M736
Try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before.
Jan 28, 2014 | Kocaso Tablets & eReaders
The tablet keeps turning itself off
Jan 28, 2014 | Kocaso 7" Capacitive Touchscreen Tablet...
Kocaso m750
Try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. Support Troubleshooting Guide
Jan 25, 2014 | Kocaso Tablets & eReaders
Tablet will not turn on
Jan 24, 2014 | Kocaso Tablets & eReaders
Model 766 will not take a charge
Jan 24, 2014 | Kocaso M766 Dual Core 1.5Ghz Dual Camera...
My tom tom go 910 gps does not turn on after being charged for over 2 hours. there is a green light when i push buton to urn on but nothing appears on screen
HAVE YOU TRIED HOLDING DOWN THE RESET BUTTON WITH A PIN FOR ABOUT 15 SECONDS OR SO. IT IS A TINY HOLE LOCATED WHERE THE CHARGER PLUGS INTO THE DEVICE.
Aug 15, 2010 | Tomtom GO 910 GPS Receiver
Wont charge or shut down
There should be a reset button on the player. It will be a small pinhole usually near the power plug. You can use a paper clip or small stick pin to press the tiny button in the hole to reset your device.
Feb 26, 2010 | Audio Players & Recorders
My blackberry will not take a charge
Have a look at the pins on the mini-USB port on the side of the phone. The ends of the small wires should all be in a row resting on the bottom (towards the back side of the phone) of the tiny slots they are in. 2 of mine were not, and it would not charge because of this. I fixed mine with the following procedure (warning! semi-delicate surgery, but easy if you're near-sighted. Will void warranty, I'm sure, so just have it replaced if you're still covered by one):
Insert a small amount of the wire from a twist-tie into the slot, pushing the end of the offending USB wire down even with the others (if it doesn't fit snug, find bigger wire).
Snip off the twist-tie as close as you can with a small pair of nail clippers, then push the remaining wire in flush with a knife point.
Apply a *small* amount of super glue to the end of the wire you just pushed in flush to keep it in place.
Worked for me, your milage may vary depending on how good you are with maniplulating teeny things.
Jun 28, 2009 | RIM BlackBerry Curve 8310 Smartphone
Cell Phones Logo
140 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
