Hey all, my Hotpoint Ultima WT640 will not stop on any cycle, the timer just keeps going back? Any ideas...
2 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: hotpoint ultima F-05 errorr appears on machine
Error F05 indicates pressure switch jammed on full.
Remove lower rear cover of washer.
Locate and remove large black hose fastened to drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should solve the problem.
Posted on Jan 10, 2010
Model number wt640 is flashing f-02
This is a overheated pump replace pump or clear blockage to let pump run faster as slow pump can give a f-02 fault
May 12, 2014 | Hotpoint Ultima WF865 Front Load Washer
Our hotpoint ultima wmd960 washing machine timer stops with one minute remaining, but continues the wash cycle on 'a loop', and does not pump the water from the drum. We turn it off and then put it...
Have a look at this and check if your pump is full of things lost from pockets:
How to remove and clean your Hotpoint washing machine pump filter
However, I suspect the problem is really that something is causing the controller to (falsely) register an unbalanced load, and continually running the wash to try and redistribute the items.
Sorry I'm not sure what the fix is for that - could be motor tacho, or could be controller itself.
Jan 30, 2018 | Hotpoint Washing Machines
What does the code f-05 for a hotpoint ultima WT640 1400 SPN
F05 measn some blockage, check and clean the filter at the front; remove the top cover of the machine,(power off) and disconnect the flexible hoses from the dispenser. Check if theyre blocked. The dispenser itself can be seperated - generally held together with plastic clips. Clean out any crud or hardened detergent.
Fabric conditioner is taken from the detergent tray by siphon action. Most likely flexible siphon pipe is blocked. Remove machine top, identify the pipe coming from the softener compartment, detach and clean.
Hope helps.
Apr 15, 2011 | Washing Machines
Hotpoint ultima wt640 am getting a flash code f-05 clothes still wet appears not to spin
Hi Error F5 means that the pressure switch is jammed on full. This may have happened due to blockage or obstruction in drain hose. To be sure check whether hose is plugged, if not then remove lower rear panel of the washer. Now you would be able to see drain pump and a large black hose on bottom of drum. Remove the hose from the pump; remember to keep a container near you to collect the water from the filter/pump. Remove and clean the drain filter connected with the pump and hose. Clean the pump and let it dry for a while. Now restart the washer after 2-5 minutes and your issue would be resolved. Please post back for further assistance. Hope this helps... Daniel
Mar 26, 2011 | Hotpoint Washing Machines
Keeps filling during wash cycle
If the machine des not stop filling and cycle hang in position, then it is a faulty water level switch.
If the machine does not stop filling , and the cycle goes on, then test that the inlet valve is not stuck in open position, if the inlet valve is OK, replace the timer control assembly.
Mar 07, 2009 | Hotpoint Ultima WD72 Front Load...
Ultima WF840 won't go from wash to rinse cycle
the pump is blocked, so the sensor detects that the machine has not emptied in the allocated time, so this will reset the time.... the pause is because it knows there is a probblem getting rid of water.
location: bottom right near the motor. ensure you tip the washer as far forward as you can so you can get a bucket under in order to prevent flooding.
hope this helps
Aug 17, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
Hotpoint Ultima WMA66. It goes thru the wash cycle but doesn't drain to go on to rinse/spin. It continues to turn and when the timer run's out it just stop's and is still full of water. Any ideas??
This must be a European model. If it wil not spin and water will not go out it has to be something stuck in the drain pump. You shoud have access through the bottom panel.If you have one remove it you should see drain pump.
Jul 24, 2008 | Washing Machines
My machine wont go passed the wash cycle and the timer goes down, it gets stuck at 1 minute then wont stop it just keeps going and going
Machine awaits for water temperature to rise but it never happens and that's why it "wont stop it just keeps going and going". It happens because the water heater is either dead or one of the two cables powering it are corroded or have fallen off from heater.
If you're experienced DIY guy than need to check if the both cables are properly attached if so than you need to test if the current goes trough the heater. If not than it needs to be replaced. If you're not DIY than call the repairman since messing with it can be dangerous.
Apr 10, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima 1200 washer/dryer
Have suffered the same problem. Suggest you remove back (after turning off electrical supply) and look at the water outlet pipe - you may have a sock or two in this - remember to reattach outlet and secure in position.
Aug 15, 2007 | Hotpoint Ultima WD72 Front Load...
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
