Tech solutions/model PS-067/b - Office Equipment & Supplies
Do you sell the safety interlock switch for the TS4500, model no. PS-067/B?
http://shredderparts.com/tech-solutions-1.php
If you could take it apart, you could bypass the interlock. I would not do this if you have children, unless you buy a lockout box.
I would try and glue the pin with superglue.
Aug 16, 2015 | Tech Solution TS-4500 Shredder
What does the computor 067 code on my s-4o volvo mean
It means the passenger side airbag is off. Did you have something (or a child) in the passenger seat at the time?
Oct 19, 2014 | 2005 Volvo S40
I to updated firmware as directed by Tech Support at Lexmark , now my printer (impact s305) won't accept my non-Lexmark cartridge. Any solution?
if you can...please return your old firmware version and please don't listen to any official Tech support because they care only for taking your money:(
...P.S. Please by yourself a new LASER printer and stop using this kind of "INK SHITs)
pifonski
Feb 19, 2011 | Lexmark Interpret S405 Wireless All-in-One...
Need codes for jvc television .
The RCU404 codes for a JVC television are
008, 012, 013, 014, 054, 060, 065, 066, 067, 082, 091, 123, 157, 158, 159, 182
Please rate this solution. Thanks.
Jun 01, 2010 | RCA RCU404 Remote Control
My Magic Chef refrigerator model CTB1722GR is blowing nothing but warm air. Compressor failure???
Good day,
Four possibilities.
1. The condenser cooling fan motor located on the bottom back of the machine between the compressor, and box condenser has failed, and needs replaced. It should be running if the fan in the freezer is running.
2. Loss of refrigerant or a restriction in the system. Testing limited to a qualified tech only.
3. The combo relay overload mounted on the compressor( under a cover) has failed. Most appliance parts houses will be glad to test them for you.
4. Locked compressor. Tech only solution.
PS. If the machine is less than 5 years old, the compressor is under warranty. Contact your selling dealer.
Thank you for using FixYa
Dec 27, 2009 | Magic Chef Refrigerators
ERROR CODE 067
E067 Two or more faults in the primary/ pre (post)-transfer/ transfer/ separation high voltage are detected (including power output stoppage, electric leakage from the primary corona assembly).
Primary and/or transfer/sep unit leaking or arcing.
These are the units that have a very thin wire in them.
Nov 05, 2008 | Canon Office Equipment & Supplies
Drivers for Vista 64 bit
doesn't work, and canon tech support in Aus say they're not providing a driver - so the printer turns to scrap. What an arrogant response to win7 from canon,i'll not buy another canon printer, that's for sure!
Apr 15, 2008 | Canon LBP 2410 Laser Printer
A board
A-1298-067-A Your more than likely going to have a hard time finding this part with it being so old.
Nov 04, 2007 | Televison & Video
jasbo
jasbo
