Question about Bose 3 2 1 GSX System
Media centre control panel not working
Hi, the media centre control panel has stopped working. i cannot turn the system on or off or change volume without using the remote control. also the only eject buitton on this system is on the media centre, so i cannot play dvds or cds currently. any ideas?
  • cadete sr Jul 10, 2008
    New Friend:
Hi Just had this issue with one I have just bought it is the ribbon that had come adrift take the six screws out of the unit remove the top and push the ribbon back in to the slot in the front panel take care use a light to see what you are doing once pushed back in it should work ok.Hope this helps !!Cheers.Glyn.
Posted on Feb 27, 2012
You may be having the same problem I have. There is a ribbon cable that connects the front panel to the main control board. Mine has pulled loose where it connects to the printed circuit board that the buttons "connect" to. I would not suggest taking it apart. I'm in the process of trying to find someone who can repair mine.
Posted on Aug 27, 2007
SOURCE:
MKS Steering Wheel Audio controls
My MKS had this exact problem earlier this year. I took it in and they ordered and replaced the buttons. It worked fine for about three months and now is starting to act up again. Have you gotten any definitive answers?
Apr 02, 2012 | 2009 Lincoln MKS
Hi sir i have compeq 610 laptop .tell me it has
Hi lalit kumar. If both the speakers worked OK at first and not now then something has changed.
1. Check that the speakers are actually still set up to make sound out of both and not just one.If you open control panel > sound there is tabs that you can look at for sound settings.
2. VLC media player has its own settings for "adjustments and effects" You may have set these up in a way that is making the sound only appear to be out of one speaker. Set them to DEFAULT
Jul 04, 2010 | HP Compaq Computer Speakers
Change the volume in WMC doesn´t working...
If the remote control causes a visible change with the volume control display but no audible difference, there are only three possible fixes. 1.)Go to Windows "Start > Control Panel > Sounds > Advanced. Here you will find a set of several volume control slide bars each with a check box at the bottom for muting. Un-check any controls marked as muted and raise the volume to 50%. Exit Control Panel. 2.) Many P.C. speaker systems are self amplified and have their own volume controls which supercede anything you do through Windows. 3.)If the problem persists you most likely have a jack plugged into the wrong feed. Allways power OFF and ground yourself before fiddling with computer jacks.
Mar 12, 2009 | Dell XPS 420 PC Desktop
Television turns on and off, turns up volume and changes channels
Hi
Replace all tact switches at the control panel... all switches is have bad resistance thats why your system is abnormal!
Thanks!
Feb 24, 2009 | RCA 27V520T 27" TV
Volume control
I had the same problem as this, but have lost my remote, so the system is know useles. Any way back to the point if you wiggle the cable around that goes in the speaker zone port then turn it off and back on then it should work :-D.
Jan 18, 2009 | Bose LIFESTYLE 28 Series III System
How can i raise the volume on my dell inspiron 1525
Here's how I fixed mine with Win-VISTA:
1. Click START
2. Click CONTROL PANEL
3. (Switch to CLASSIC VIEW)
a. Click on SOUND
b. Click on PLAYBACK Tab
c. Click on SPEAKERS/HEADPHONES
d. Click on PROPERTIES
e. Click on CUSTOM Tab
i. Make sure PC SPK MUTE is NOT checked
f. Click on LEVELS Tab
i. Slide PC SPEAKER to 100%
ii. Don’t worry about the SPEAKER slider, it’s controlled by the keyboard buttons
g. Click on ENHANCEMENTS Tab
i. Make sure LOUDNESS EQUALIZATION is checked
h. Click OK
i. Click OK
4. Close CONTROL PANEL
Dec 07, 2008 | Dell Inspiron 1501 Notebook
Rear and Centre speakers not working
The system comes with l remote which provides controls for "Power", "Master Volume", "Bass (Subwoofer) Volume" and "Matrix Mode" . Matrix mode allows you to spread stereo sound to all speakers where your sound card may not have the ability to do so.
I find that the "Stereo Surround" setting works best as opposed to the recommended "CMSS" setting
Oct 22, 2008 | Logitech X-540 Multimedia Surround Sound...
My volume stopped working
Hi!
Have you tried doing the system restore? If yes, then try to do this ff steps:
1. Uninstall the sigmatel driver in add or remove programs
2. Uninstall the sigmatel driver in device manager (click the + sign under sound, video and game controllers)
3. Download and install the latest Sigmatel Driver at http://tinyurl.com/yo24rz
4. Reboot the system.
Please post if it works or not.
Thanks,
Karlox
Dec 04, 2007 | Dell Inspiron B130 Notebook
Cannot seem to calibrate.
Go to Control Panel, open device manager, and and check for any yellow checks for your
sound, video and game controllers. If there are none, your system is go. Then go to your audio manager on control panel, and set it up for whatever speaker configuration you have. I have realtec audio manager. This step is a must for configuring—you choose whether your laptop will use its own speaks or use your external speakers—you have to turn off the internal speakers and turn on the external manually. You can adjust volume there..
Oct 05, 2007 | Logitech Z-5300 Computer Speakers
Bose 3 2 1 GSX System Logo
172 people viewed this question
Top Bose Audio Players & Recorders Experts
Steve Allison
Steve Allison
Ekse
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
