Question about Onkyo HT-RC460
Onkyo hookups I have an HDMI from tv to receiver and am not getting any sound?
SOURCE: No Video only sound with Onkyo TX-SR605 7.1, tried everything, HELP!!!!
same receiver same problem. at least ou're not alone.
Posted on Feb 24, 2008
SOURCE: new home theater setup- no signal at tv using onkyo tx=sr605
This might somewhat help. Today I went back .. I went HDMI out of the Cable box and DVD player into 2 of the TVs HDMI ins. The digital audio out from each, straight to the receiver and things are working ok. All speakers are working OK. Sound isnt as loud or crisp but unfortunately I found no other solution.
Posted on Jan 06, 2009
SOURCE: Onkyo TX-SR606 getting no sound from HDMI sources
Not sure if this is your fix, but I had what I thought was the same problem. I played with my Onkyo quite a bit ensuring the correct assignments for HDMI, audio and all that stuff. Turns out I neglected to make sure the output devices were properly assigned. Many devices aren't default to output sound over HDMI. I changed the audio out settings on the cable box to HDMI and suddenly the Onkyo worked great. I know, I'm an idiot for not checking that in the first place, but maybe someone out there is having the same trouble as well.
Posted on Apr 05, 2009
  • 137 Answers
SOURCE: Onkyo TX-SR606 HDMI Input
The problem is the hdmi board in the receiver .they are having trouble with the smd regulator and smd capactors that they are using on the board,they have updated the new boards as i have not got any back when replacing with the new boards. I have replaced at least 35 hdmi boards on this model. If you call Onkyo they will tell you that you have a hdmi board bad and take it to an onkyo dealer.
Posted on Apr 17, 2010
SOURCE: HDMI video not functioning on a new Onkyo TX-SR606
For me, it was the Monitor Out setting that had defaulted back to Component. I remembered to change the individual inputs to HDMI - but had forgotten to set the Monitor Out to be HDMI.
Posted on Apr 30, 2010
Hookup Blu ray player to Onkyo pre-amp for speakers
If you have audio out jacks from your tv, you would be better served hooking that up to the preamp. If you hook up the blu-ray player separately to both the tv and amp, the audio probably will not sync with the video correctly. The tv takes longer to decode the hdmi input and the audio will be ahead.
Jan 22, 2013 | Onkyo Audio Players & Recorders
Sound won't play through Onkyo TX-SR605 when using HDMI
The chances are that you have selected an incorrect sound setting or not switched it on, for the HDMI you are using. With Onkyo receivers each connection will have it own settings for video and sound. You just need to look in the manual as to how to select the settings.
May 08, 2017 | Onkyo TX-SR605 Receiver
Hookup the comcast hd box to my new lcd tv?
You can use either component (Red/Green/Blue video and red/white audio) or HDMI cables to connect the Comcast HD box to your TV. Most times you can get these cables for free at the Comcast front counter.
Sep 26, 2009 | Onkyo TX-SR606 Receiver
HDMI through - working, NO SOUND
try turning off HDMI Audio Out.
Jul 10, 2009 | Onkyo TX-SR875 Receiver
Onkyo TX-SR606 getting no sound from HDMI sources on speakers. I have a motorola cable box and a panasonic DMP BD-35K blueray player both attached to the SR606 via HDMI cables (HDMI3 and 1 respectively)...
Feb 20, 2009 | Onkyo TX-SR606 Receiver
Hooking up a sony playstation 3 with digital optical cable
Here's one solution, if you have an audio output from your tv, you can go from the audio output on your tv to the audio input on your receiver that way anything that is playing on your tv for example, playstation 3, dvd player etc. Anything playing on your tv will have audio on your onkyo home theater system. The other thing I would try if you want to hook ps3 directly to receiver is go to your connection settings on your ps3 menu and change your connection method to digital optical cable.
Dec 27, 2007 | Onkyo HT-S790S System
New home theater setup- no signal at tv using onkyo tx=sr605
Could well be the quality of your cables. if you have high end cables the consult a service agent. if you have the cables that came with the products, go and get some better ones.
Nov 04, 2007 | Onkyo TX-SR605 Receiver
Onkyo HT-RC460 Logo
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
