I have an LG neo plasma inverter air conditioner, model S24AWN-N56, it displays CH8 on the LCD and turns itself off b4 it starts. How can I fix this problem again so that the unit will work again...? It won't either heat or cool at the minute...
2 Suggested Answers
SOURCE: Air conditioner is turning on
Hello Naeva
Plesae visit the link provided below :
http://www.mylg.co.uk/data%20for%20site/Multi%20F_dx_%20Fault%20Codes%20-%20Nov%2007.pdf
http://www.abacusairconditioning.co.uk/lg%20split%20codes.pdf
http://www.ehow.com/info_7983149_lg-air-conditioner-error-codes.html
Posted on May 01, 2011
INSTRUCTION OF USE OF LG NEO PLASMA AIR CONDITIONER MODEL NO S244HPND6
This is close, but I think it is Country specific, so click on top right and go to LG for your country and put in the model number ONLY. If that doesn't work, contact LG via their contact page.
Manuals & Documents - Support Search Results ' LG UK
www.lg.com > Home > Support > Support Home > Product Support
  1. Cached
Air Conditioning Systems; Residential Air Conditioners; S24AHP ... product, please refer to the Owner's Manual and other documents available for this product.
LG Support Search Results LG
Dec 13, 2016 | LG Heating & Cooling
I have a neo plasma lg 7kw will not heat LG Air conditioner
Make sure the setting on the remote is correct . Sun symbol for heating. Make sure the filters are clean. On heating, the indoor unit will 1/2 open the flap but the fan shouldn't start. The outdoor unit should start and if working properly, will be blowing cold air. The indoor unit will open the flap fully and the indoor fan will start once it gets hot then you should feel warm air. If the outdoor unit is blowing warmish air, I would say the reversing valve coil has failed or one of the indoor temp or pipe sensors are faulty. If a sensor fails, a "CH" error should appear on the display.
Mar 30, 2016 | LG Heating & Cooling
LG neo plasma error code
It means the lid is open OR it has a short circuit.
Jul 08, 2015 | LG Asmc183vm Neo Plasma Filter
LG neo plasma air conditioner does not blow cold air
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Thanks. Helpful?
Jan 04, 2011 | LG LS-J0910HL Heat & Cool Mini Split Air...
I have a lg neo plasma inverter ( s24awn-4) it turns off and comes up with a fault code (26ch) can any 1 help?
Inverter compressor seized. Check compressor windings all equal resistance 1 to 4 Ohms, check to earth 50 MOhm minimum, check run current and Inverter outputs. Helpful?
Dec 26, 2010 | Heating & Cooling
Need to find manual to download for LG 2.5 hp neo plasma wall mounted air conditioner
You can find it her, you just need to have the full model number, probably located in the control panel http://www.lge.com/us/support/product/support-product.jsp
Jun 11, 2009 | LG Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
