Question about NEC Pinwriter P2X Matrix Printer
NEC pinwriter P20
Hi guys and girls my printer has decided to take 2 A4 sheets to print 1 A4 page !!! how can this be ? well quite simple , it prints every line twice !!! if it is a large heading of , say , 4 lines , then it overprints 2 lines any geniuses out there [ or should that be genii ] tia
  • lebesset Aug 12, 2007
    hi gerry ; tks for your rapid response
    seems I wasn't very clear !!!
    I put one sheet of paper in the hopper for a one page document ; it proceeds to print every line twice ,which is why it only half a page fits on the sheet ; looks like I stutter !!!
    after posting , did what you suggested and stripped and cleaned ; no change
    tried printing from word pad , just a few lines ...same
    tried another suggested driver ...same
    tried another computer ...same
    tried a self test with the printer unhooked from a computer , prints correctly !!
    maybe it just doesn't like my w2k when I try to print from my documents
    as they say where I live , m'aidez m'aidez
    if I don't give up trying to fix this soon , my wife is going to go find herself a toyboy :)
    Sergeant:
  • 390 Answers
Very funny. There are a number of things you can try. Start by checking for very small debris in paper feeder area and inside unit, especially around printhead carriages. Clean your unit thoroughly, including rollers and run allignment checks. Also check all printer settings for normality. Only load small amounts of paper at one time as this helps to avoid pressure on feeder rollers, and may alleviate 2 sheet feeding.
Posted on Aug 12, 2007
I need a user's manual for NEC Pinwriter P6300
Hi. i hope this finds you well.
Please see the following link for a Comprehensive Support Document for Nec Pinwriter P6300. http://support.necam.com/printers/csds/273916.pdf
I hope this will help you with your issue.
Thank You for using FixYa.
Dec 22, 2010 | NEC Office Equipment & Supplies
Hello sir, how to take print on A4 page? please help me
Hi The A4 paper size is an internationally used paper format. Although not often used in America, it is by far the most commonly and widely circulated paper size. At 8 1/4 inches by 11 3/4 inches, it is similar though not quite identical to the American standard U.S. letter size, which is 8 1/2 inches by 11 inches. Because of its ubiquity, all printers and programs have the ability to handle the size, and getting a printer to print to it is a matter of adjusting the settings.Put the A4 sized paper into the automatic feeder in the printer. You may have to adjust the tray guides to fit the paper in snugly. Close the tray firmly when finished.
  • Step 2.Set the printer to register the A4 sized paper inside the the tray. This varies from printer to printer but generally involves going into the print menu, scrolling to the automatic feeder and designating the tray as an A4 tray.Step 3.Select "File" and then "Page setup" in the program you are using.Step 4.lick on the drop down menumag-glass_10x10.gif next to paper size and choose "A4.Step 5.Select "File" and then "Print." Click the "Print Summary" button to ensure the file is set to print to the A4 size.
  • Step 6.Press "Print" to print the photograph.
  • Jul 31, 2010 | Toshiba e-Studio163 Copier
    Canon Manual 520a .
    Depending on the type of printer you have, you might be able to print multiple "digital" pages ("N-UP" is one way of describing it) per physical page.
    Basically that scales the output (makes it smaller) so that you can get more than one page per sheet of paper. The only drawback is that it might end up being too small to read.
    Not every printer has this feature, however. You can definitely use the "Print Preview" function to show you how many physical pages will be output before you actually print. That should let you know how many pages the manual will really use when it comes time to print.
    Good Luck!
    Jan 25, 2010 | Cameras
    Printing a full page 'background' (design) with no margins
    No. The official minimum print margins are as follows
    print margin specifications
    Top (leading edge)
    Bottom (trailing edge)1
    Left
    Right
    Sheet Paper
    U.S. letter
    .07 in. (1.8
    .46 in. (11.7
    .25 in. (6.4
    .25 in. (6.4
    mm)
    mm)
    mm)
    mm)
    U.S. legal
    .07 in. (1.8
    .46 in. (11.7
    .25 in. (6.4
    .25 in. (6.4
    mm)
    mm)
    mm)
    mm)
    U.S. executive
    .07 in. (1.8
    .46 in. (11.7
    .25 in. (6.4
    .25 in. (6.4
    mm)
    mm)
    mm)
    mm)
    ISO A4
    .07 in. (1.8
    .46 in. (11.7
    .13 in. (3.4
    .13 in. (3.4
    mm)
    mm)
    mm)
    mm)
    ISO A5
    .07 in. (1.8
    .46 in. (11.7
    .13 in. (3.4
    .13 in. (3.4
    mm)
    mm)
    mm)
    mm)
    Sep 30, 2009 | HP OfficeJet 6110 All-In-One InkJet...
    Older Xerox 5334 printing on 1/2 page on every other sheet.
    It is 99% of the time the print cartridge. If it is every other sheet on A4 then it is this.
    Dec 31, 2008 | Ricoh Aficio 450 Copier
    Problem printing multiple pages on one sheet!
    This is not the fault of the printer but the fault of word.
    The way I did it successfully was as follow:
    File > Page Setup > Layout = Landscape (sounds like you have already done this)
    In the print dialoge, instead of OK, click Properties. On the layout tab, select landscape and below that select pages per sheet = 4 and then click ok... Then click OK to print.
    May 22, 2008 | HP LaserJet 2200 Printer
    NEC Pinwriter P3300 Printing
    reinstall the driver.if not solved then your printer needs servicing
    Apr 03, 2008 | NEC Pinwriter P2X Matrix Printer
    Printing an A3 document on an A4 printer
    Set your paper size to A3 - it should print out the docs on two seperate sheets of A4.
    Oct 11, 2007 | Konica Minolta Magicolor 2450 Printer
    586 people viewed this question
    Top NEC Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
