FixYa.com
Tags:
NEC Nefax 655E Plain Paper Laser Fax
Pagepro printer toner empty problem
posted by vakkil on Aug 11, 2007
I insert a new toner catridge in pagepro 9100laser printer after some copies it shows toner empty i fixed in other machines there also it shows toner empty
this is not first time because this is second attempt
1.Please tell the how machine sense the toner
2.How to rectify the problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 21, 2008
Not Rated (0)
clubJWP
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
i agree with boyrevel. shaking the toner hard will settle the toner, may be the cartridge is not used for long or it is quite old. the sensor has think ink on it, only hard shaking can slove it...or get a new one.
JWP
Don't waste money on Printer Ink. Save up to 65% on toner cartridges, ink cartridges and printer supplies. http://www.concordsupplies.com
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Aug 12, 2007
Not Rated (0)
boyrevel
Rank:Wiz Wiz
Rating: 89%, 52 votes
1. It tries to pump toner into a reservoir. If it doesn't activate a full sensor for the reservoir, it shows toner low.
2. Take the toner out and shake it hard about 10 times, this will make any settled toner loose, and should solve this. The problem is normally caused by old toner (your supplier might have had it on their shelf for a year or two).
Can you Help with these Fax Machines problems?
Fax Machines
Have a KL 2000 EZ
Have a KL 2000 EZ Label... Answer This...
Fax Machines
Canon PC 770 copier Copies
Canon PC 770 copier Copies out... Answer This...
Fax Machines
i want to program fax
i want to program fax numbers... Answer This...
Fax Machines
i have a canon copier
i have a canon copier (clc... Answer This...
Fax Machines
I was chatting with someone
I was chatting with someone but... Answer This...
Repair Service
Find Fax Machine Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
