Question about Mitsubishi CS-32509 TV
Picture with gray box
When I turn on the TV the picture is bright and looks normal. After about 5 seconds the screen changes and becomes less bright and a light gray box apperas in the middle but does not fill the full screen, about 75% . Any time you press a button on the reomote it switchs to the normal bright screen only to chnage back to the gray box screen after 5 seconds. What is going on?
  • Anonymous Mar 14, 2014
    On my Sansui HDLCD1912 tv the screen has become distorted, no sound, screen looks as if parts are switched around, screen then slowly becomes all white, which then switches to blue.
    Novelist:
  • 192 Answers
The text mode in the closed caption is turned on.Turn off the closed caption. I don't have the schematic in front of me, so, I will wing it. There may be a button on the remote that says CC, if so then use that button to turn it off, if not then go to the service menu and you may have to search a bit. Either way it's an easy fix and you can do it yourself. If you can't find it, then, reply and I will give better instructions when I get into my shop next week.
Posted on Aug 12, 2007
Problem with LED TV screen
Hi Dale, The link below is a YouTube video showing how to fix a Samsung television NO picture GOOD sound, Also there's videos down the right side of the link that may help as well........CHEERS..
https://www.youtube.com/watch?v=cI2L61dzj6k
Samsung UN46D6000 No picture Sound OK problem FIXED BN95 00497B BN41 01662A
May 11, 2016 | Samsung Televison & Video
How do I fix an LG TV that shows a gray screen for the first 10-20 minuets when it is turned on?
First, try to plug another source on your T.V. set and let see if it's gonna do the same trouble. If not, this is not the T.V. but the source,( cable box or other) that is defect. If not, Looks like a main board problem, or if you're lucky, a cold joint, (Which i doubt). Sometimes it could also be a bad piece in the power supply but i can not say like that. I would have to make test on it with the service manual. If changing source does not work, i suggest you to see a professionnel. Best of luck. Best regards,
Serge.
Apr 07, 2015 | LG 32LG30 32 in. LCD HDTV
Fading brightness of sharp 20v-l70m
pls. try adjusting screen control.
Jul 04, 2013 | Sharp 25R-S100 25" TV
My LG HD tv screen has a wide, gray band on either side of the picture
Try changing 'perspective' or screen ratio.
This may work, but could also stretch the picture too wide,
On my non-LG TV this is called 'aspect ratio' under the 'picture' menu.
Nov 20, 2017 | LG 42LB1DRA 42 in. LCD Television
Picture brightens then darkens
Trying with a DVD will rule the tuners in the set in or out and also suggest a setting in the set or a box if used is causing this issue.
Nov 03, 2012 | Samsung LN32C350 32 in. TV
Panasonic CT-27L8SG displays gray screen and white hoizontal line
Is it still under warranty?
If not I would find a good TV Service Shop and have them check out the power supply as there more than likely a 'Capacitor' much like a battery that is going bad.
Blessings,
A/V Media Guy
Nov 22, 2009 | Panasonic CT-27SL14 27" TV
Recommended best settings for the TH-50PZ700U Plasma TV
Try this one and see if you like it!
Normal: No
Picture mode: Custom
Picture: +22
Brightness: +9
Color: -3
Tint: 0
Sharpness: 0
Color temp.: Warm
Color mgmt.: Off
C.A.T.S.: Off
Zoom adjust: (grayed out)
PC adjust: (grayed out)
-- Other adjust menu
Video NR: Off
3D Y/C filter: Off (grayed out)
Color matrix: HD (grayed out)
Block NR: Off (grayed out)
Mosquito NR: Off
Black Level Light
3:2 pull-down: On
HD size: Size 2
Dec 26, 2007 | Televison & Video
The picture on my JVC TV is too dark
On the inside of the TV, on the flyback transformer there should be two controls. Turn the one that says "screen" very slowly clockwise while looking at the pix. The pix should get brighter as you turn it up- if you go to far you will see lines in the pix or the TV may shutdown.
Aug 30, 2007 | Televison & Video
JVC AV-27530 Sudden changes in brightness
This sudden changes in brightness are caused by the change in voltage inside the tv,not in the outlet in the wall but inside the set,The changes are an indication something is going wrong and it needs to be corrected,the set does have a brightness limiter but it only works when the set wants to get brighter than normal,You need the assitance of a servicer to correct this problem.
Oct 04, 2006 | JVC AV-27530 27" TV
Televison & Video Logo
106 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
