Question about Datamax I-CLASS DMX-I-4406 Thermal Label Printer
Ribbon fault Position faults and/or top of form fault. The manual is no help with his information.
    Scholar:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 52 Answers
Hold in the Feed button for 4-5 seconds, which causes the printer to attempt to "Auto-calibrate." If that doesn't solve it, then slide out the Media Sensor (green plastic bar that sticks out over the labels) about 1 inch from all the way in ("in" = left if looking from front). Then press Feed to clear errors. If still get same error, then look for piece of label or ribbon stuck in that error - ok to blow out with canned air. Then try holding in Feed again for 4-5 seconds to Auto-calibrate again.
Posted on Apr 29, 2014
Astinsan
  • 87 Answers
SOURCE: top of form fault
You need to calibrate the printer using the instructions located in the manual. This should be in area 5.2 of the manual. If you don't have the manual you can download them at this address along with software updates and firmware updates.
http://www.datamaxcorp.com/software/i-class/
Hope this helps you.
Posted on Nov 22, 2008
bartech9
  • 155 Answers
SOURCE: datamaxI class 4208 top of form fault
The printer must be calibrated or the type of sensor is wrong. Verify that the sensor type is correct for your label (gap or black mark) and you can calibrate it by pressing the FEED key for about 5 seconds approximately.
Posted on Mar 13, 2009
maosee
  • 4 Answers
SOURCE: I-4208 DataMax printer
We had the same error after labels got wrapped around the feed roller. When we were called to investigate the problem, the fault error was there. After 2 1/2 hours of troubleshooting both on the printer and online we came across this page. I took the roll of labels out, cleaned the media sensor and re-threaded the labels. Well, that didn't work too well as I still had the same error. Since we have 2 thermals setting side-by-side, I opened up both hoods and noticed that the "green" slider just beneath the sensor was slid all the way in. On the other printer however, the slider was slid out until a white etched line was at the tappered endpoint of the sensor. I slid out the other printer that had my error, hit the feed button, and whaaa-laaa, the error disappeared. There are some minor distance feed that we have to reset, but it is up and running! I hope this may help you out in your situation too.
Posted on Jun 12, 2009
  • 97 Answers
SOURCE: Top of Form Fault error
It means that the printer did not get a good calibration on the label. First make sure the label sensor is in the proper position. Look at the green bar that the label passes underneath and make sure that the white line (the sensor) is positioned over the label. Then calibrate by pressing and holding the FEED key for about 5 seconds until the labels start to feed. After a few labels feed out, the printer should now have a good read on the size of the label and be ready to go.
Hope that Helps !
Posted on May 14, 2010
printertech1
  • 96 Answers
SOURCE: hello, i have a datamax i
The error is indicating that it cannot calibrate the media. Try holding in the feed key for approx 10 seconds and see if it will calibrate. Experiment with the position of the media sensor. It will slide horizontally.
Posted on Oct 13, 2010
Right side of Samsung LN T4661F 46in LCD is blurry
hi this could be a tab/ribbon fault, there are ribbons attach to the screen at the top there's chips installed on them. when one is faulty they heat up and make the ribbon start to flex and move causing this fault, hope it helps
regards
shaun
May 16, 2014 | Samsung LN-T4661F 46 in. LCD HDTV
How to fix Toshiba Regza LCD TV when half the screen with vertical streaks?
hi this fault sounds like a bad tab/ribbon fault, at top of the tv are ribbons connector to the screen, when one is faulty the heat makes them flex causing this fault, you can bond the ribbon down with a bit of rubber to stop it flexing, but this not a permanent repair as it is a screen fault. hope it helps
regards
shaun
Apr 24, 2014 | Toshiba 42HP66 42 in. LCD Television
Ribbon fault error
First of all sorry for the problem.
It seems to be a logic card problem . Kindly contact with lipi for replacement of the logic card.
Aug 16, 2012 | Tally T6215 Matrix Printer
I have a Tally 6212. I'm using non Tally ribbons which is producing a ribbon fault. I'm told by my ribbon supplier that there is an override to keep the ribbon from causing the fault. Can you...
If the ribbon is causing the Ribbon Fault, they would not be very well made compatables I would suggest changing to one of the other brands available. I belive the T6215 senses the ribbon turning by having a silver strip stuck on a rotating disk on the back of the ribbon, if this strip is not present or is not being detected it will display a Ribbon Fault. You can check the ribbon to ensure it has a reflective strip by manually winding the ribbon and looking at the back side of the ribbon, you should see a rotating disk which is half silver and half black. If this disk is not present the compatable ribbons would not be that compatable. The T6215 does to have a fault over ride for the Ribbon Sensor on its own, you can only over ride all faults this may cause other problems as Paper Out, Paper Motion errors are also overridden. You can enable fault override in the following way; Press and hold down LINE FEED and ENTER for about 5 seconds untill the printer bleeps. Press and Hold down FORM FEED and ENTER for about 5 seconds untill the printer bleeps. The above actions enabls Fault Over rides temporarily if the printer is powered off or reset Thai setting will be lost.
Apr 21, 2011 | Tally T6215 Matrix Printer
Hello, i have a datamax i class he give a fault "top of form fault" i don't no what that is
Sep 25, 2010 | Datamax DMX-I-4212 Label Printer
Hope that Helps !
May 14, 2010 | Datamax DMX-I-4208 Label Printer
Top of form fault
Top of form fault - I assume you hit "Feed" button and still got the form fault... if so:
1. check paper sensor position, sometimes just 1/8" one way or the other will make a difference.
2. calibrate the printer to the stock you have loaded - calibration is EASY, just press and hold the feed button until the printer cycles 8-10 times. Let go, should say "Calibration Complete". Hit "Feed" again to see if your top of form fault is fixed.
Jun 10, 2009 | Datamax M-4208 Thermal Label Printer
Top of form fault
Nov 14, 2008 | Datamax DMX-I-4212 Label Printer
Line feeds
Hi-
When you said line feed do you mean the Top of form?
hope this helps
1. Make sure the printer is turned on and the desired tractor is selected (the corresponding tractor arrow should be lit).
2. Open the upper cover.
3. Press the Top of Form button to enter top-of-form mode. The printer beeps once, and the Top of Form light turns on.
4. Use the Micro Feed buttons to feed the paper to the desired top-of-form position. The “A” on the ribbon protector shows you where the bottom edge of your first line of text will print. This position is based on the first printable line of text. If your software inserts a top margin of five lines, your text will actually print five lines below the top-of-form position.
5. Press the Top of Form button again to exit and save your new top-of-form position. Then close the top cover.
Keep me posted if you have inquiries, thanks!
Jun 18, 2008 | Epson DFX-9000 Matrix Printer
Datamax I-CLASS DMX-I-4406 Thermal Label Printer Logo
635 people viewed this question
Top Datamax Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Kevin Brown
Level 1 Expert
Greg Cann
Greg Cann
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
